Homeall.g fails when homing all axes
; Home X-Axis G91 ; relative positioning G1 H2 X0 ; set axes position explicitly to Zero i.e move X and Y-axis Minimum Homing endstop and stop there G1 H2 X40 F10000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X-40 F10000 ; go back a few mm G1 H2 X0 ; move X and Y-axis Minimum Homing endstop and stop there (first pass) G90 ; absolute positioning
G1 H2 doesn't do what you think it does here.
G1 H2 X0 means to do a zero movement move regardless if the axis is homed or not. G1 H2 moves are meant to leat you move the axis away from an endstop slightly before a homing move, or to raise the z axis before making an X Y move to prevent scraping.
An actual homing move is done with a G1 H1 movement which needs to be long enough to strike the endstop even from the farthest opposing position. It also must be in the direction of the endstop.
You are using H2 instead of H1.
You posted that the X endstop is at the low end.
I don't know how long the X axis is but you need something like...
G91 G1 H1 X-999 F5000 ; use a value large enough to move the entire length of the X axis G1 X10 G1 H1 X-15 F500
...then based on what the physical position is when stopped by the endstop being triggered
G1 Xnnn ; move to some known position on the axis - note this is a relative move still G92 Xppp ; set the X axis logical position to match the physical position
@fcwilt
X-axis = 340 mm and Y-axis = 447mm.I think i only have extra additional of -2.0516mm on X-axis on the low end and -4.0244mm on Y-axis
@developeralgo222 said in Homeall.g fails when homing all axes:
@fcwilt
OK then your first G1 H1 move would be
G1 H1 X-345 F5000
You can pick a speed (the F parameter) that works best for you - it's not critical but you can go too fast.
At what position does the X endstop trigger? Are you treating that as X=0?
@fcwilt said in Homeall.g fails when homing all axes:
Yes at X=0. Do i need to test this on the command console or just put them in a homing file and test on DWC ?
something like this on homex.g ?
G91 G1 H1 X-345 F5000 ; use a value large enough to move the entire length of the X axis G1 X10 G1 H1 X-15 F500 G1 X0 G92 X0 G90
As I mentioned if the endstop triggers at the end of the axis travel and you are treating that as X=0 then you don't need the following:
G1 Xnnn G92 Xppp
They are ONLY needed when the endstop is not triggering at X=0
In your case this should work for you:
G91 G1 H1 X-345 F5000 G1 X10 G1 H1 X-15 F500
Now if you have specified your X axis with M208 -170:170, meaning X=0 is at the center of the axis you could add the following:
G90 G1 X0 F5000
i have M208 X0:340 Y0:447
That is fine - you don't have to have X=0 at the center of the bed. Some folks just prefer it that way - I am one of them.
@fcwilt
That worked for X &Y and Z , i am going through all the axes one-by-one following your insights .How do you configure the endstops of a shared z-axis cam based
i have to configure endstops for 6-Nozzles ( 2 Nozzles share a single Z-axis based Stepper motor ) so that they trigger correctly
i.e 3 Stepper Motors for Z, U, V axis but each axis shared with 2 nozzles each with a Z-axis type.
That is not a setup I have seen or heard of.
Does the "Z stepper" turn the cam to raise/lower the nozzle?
Does each nozzle have it's own endstop sensor?
Yes, Each Nozzle has its own endstop . With CAM kind of shared axis when it moves down 1 nozzle the other stays at zero or is lifted back to zero point by the spring to where there is a stopper to prevent it from flying over.
OK.
Since you are using NPN sensors the outputs pull the inputs they are connected to to ground (GND)
I'm assuming only one of the sensors has the beam of light blocked when the nozzle is down.
If I am reading the spec sheet correctly the white wire is pulled to ground when the beam is blocked.
If so, you would want to connect both of the white wires to the Duet input and use the ! prefix character to treat the low input signal as active.
As before you would have a G1 H1 move in the direction of the sensor.
Are these nozzles simply up or down OR do they move over a range of vertical travel?
They move over a vertical range of travel actually from 0 to -/+ 70 before they trigger the endstop . all have a range of -90:90 but technically
so
(1) On Z-Axis Motor , Z1 has a move range from 0 to -90 and Z2 has a move range from 0 to +90. When one is down , then other is always at zero
(2) On U-Axis Motor , Z3 has a move range from 0 to -90 and Z4 has a move range from 0 to +90. When one is down , then other is always at zero
(3) On V-Axis Motor , Z5 has a move range from 0 to -90 and Z6 has a move range from 0 to +90. When one is down , then other is always at zero
