Duet 2 v1.02 not responding
@thomasvanderwal Which set of files did you flash to the Duet? RRF v3.0 is very old. You're probably using a newer version of DWC in the /www folder.
I suggest you
- go to the latest release version of RRF here: https://github.com/Duet3D/RepRapFirmware/releases/latest
- Download "Duet2and3Firmware-3.5.4.zip" and "DuetWebControl-SD.zip"
- Unzip the first file, and copy " Duet2CombinedFirmware.bin ", "Duet2_SDiap32_WiFiEth.bin" and " DuetWiFiServer.bin " to the /sys folder on the SD card, AND the /firmware folder. Overwrite the files already there.
- Connect to the Duet with YAT via USB, send M997 to update the firmware
Once it restarts, check if you can connect via DWC. If you can, upload the "Duet2and3Firmware-3.5.4.zip" to the Duet again. It will ask you if you want to do the firmware updates, press cancel.
If you can't connect (still wrong DWC version):
- unzip "DuetWebControl-SD.zip"
- copy contents to a new /www folder on the SD card
- replace SD card in Duet and restart
Then RRF and DWC should be the same version. I don't know what version you were running before, so your config.g may need changing. Sort this out first!
Web control is working!
Now the last 2 challenges :- On the PanelDue->In screen control the button sd card gives error : error 2 accessing sd card
- Homing failed. With motor phase A may be disconnected reported by driver(s) 1
number 2: I may find in this forum?
@thomasvanderwal Have you put an SD card in the PanelDue slot? How is the PanelDue connected to the Duet? To be able to use the SD socket on the PanelDue, it needs to be connected with the ribbon cable. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue
Also, update the PanelDue firmware to the latest: https://github.com/Duet3D/PanelDueFirmware/releases/latest
For instructions, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDueFor the homing error, you're going to need to tell us more about your machine. Send M122 and post the full response. Post your config.g and homeall.g. Post a picture of your printer, and the wiring. Most likely the wiring is not connected, so check the motor wires for driver 1, which is most likely to be the Y axis.
@droftarts Sd card reading works!
motor phase problem solved. Wiring was wrong.
But homing is not going well.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet Ethernet 1.02 or later
Board ID: 08DDM-9FAM2-LW4SD-6JKDL-3SJ6N-KJZBY
Used output buffers: 3 of 24 (6 max)
Static ram: 30516
Dynamic ram: 91292 of which 0 recycled
Exception stack ram used: 248
Never used ram: 9016
Tasks: NETWORK(ready,1040) HEAT(blocked,1240) MAIN(running,3740) IDLE(ready,156)
Owned mutexes:
Last reset 00:03:54 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8748 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 46.8, current 48.0, max 48.5
Supply voltage: min 24.6, current 24.8, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 422922851
Slowest loop: 3.14ms; fastest: 0.09ms
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.60ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex -
@droftarts ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Feb 11 2025 11:12:26 GMT+0100 (Midden-Europese standaardtijd)
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Feb 11 2025 11:12:26 GMT+0100 (Midden-Europese standaardtijd); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M553 P192.168.0.102
M554 P192.168.0.1
M553 P255.255.255.0
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M84 S30 ; Set idle timeout -
@droftarts ; Axis Limits
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z -
@droftarts Tractus 3d T650P is my printer
A part of the config.g couldn't be copied (2 reputations or something error)
@thomasvanderwal Your Tractus is a delta printer, but your config.g is set up for a Cartesian printer? Do you have an old config that worked?
Otherwise, see https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_linear_delta
@droftarts no, a colleque got this printer from a company. He's gone
I am a educator at a technical school. -
@thomasvanderwal Okay. I think start again with the configuration tool, but this time select "Linear Delta" for Kinematic type. https://configtool.reprapfirmware.org/Configuration#kinematics
Tractus3D have renamed/been taken over by https://nexum3d.com/. You may be able to contact them and get them to send you a standard configuration for your machine. They are a Dutch company based in Amsterdam, i believe.
@thomasvanderwal said in Duet 2 v1.02 not responding:
Now that you're seeing some progress it may be a good time to update your firmware before you get too far with configuring. 3.0 is quite old now.
If you have access to DWC, you should upload the following zip files one at a time. It will prompt to install the firmware and restart. Then upload the next version, etc.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/Duet2and3Firmware-3.5.4.zipThe reason for uploading 3.0 again is to ensure all of the required files are present.
I'm getting no response from the company. Can a new firmware work with a duet 2 wifi/ethernet?
I made a homedelta.g and a config.g with RepRapfirmware config tool. I selected delta printer and I think made the right choices with the parameters (sensors). But still homing is going bizar. How can I fix this? My rods are 230mm.
At what starting point do I have to position the nozzle? A message G28 0 0 gets a response that axes are not sufficient.
I put this in my config.g: M665 L230 R165 B100 H315 ; set delta radius, diagonal rod length, printable radius and homed height
Maybe this is wrong or my endstops are at another sensor or so? -
@thomasvanderwal we'd need to see your complete config.g and homedelta.g files to help. However, firmware 3.0 is very old now and it would be easier for us to help you if you upgrade to 3.5.4 or 3.6.0-beta.4.
@dc42 I upgraded to 3.5.4. I have adjusted the homedelta.g many times. This was my last.
; homedelta.g
; called to home all towers and extra axes
; generated by RepRapFirmware Configuration Tool v3.5.10 on Mon Feb 24 2025 14:22:27 GMT+0100 (Midden-Europese standaardtijd); home linear delta
G1 H1 X650 Y650 Z650 F3000 ; move all towers to the high end stopping at the endstops
G1 H2 X-3 Y-3 Z-3 ; go down a few mm
G1 H1 X6 Y6 Z6 F250 ; move all towers to the high end once more stopping at the endstops
G1 Z-5 F2000
G1 X0 Y0 F2000 ; move X and Y to the centre -
I got reputations error. So I send the file as attachment
; homedelta.g
G1 Z-5 F2000
G1 X0 Y0 F2000 ; move X and Y to the centreSo what happens when you send G28 to home all axis? (which will run the homedelta.g macro)
; Configuration file for RepRapFirmware on Duet 2 WiFi ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Mon Feb 24 2025 14:22:26 GMT+0100 (Midden-Europese standaardtijd) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"my printer" ; set hostname ; Accessories M575 P1 S0 B57600 ; configure PanelDue support ; Network M552 S1 ; configure WiFi adapter M586 P0 S1 ; configure HTTP ; Smart Drivers M569 P0 S1 D2 ; driver 0 goes forwards (X axis) M569 P1 S1 D2 ; driver 1 goes forwards (Y axis) M569 P2 S1 D2 ; driver 2 goes forwards (Z axis) M569 P3 S1 D2 ; driver 3 goes forwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0 Y1 Z2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z800 ; set axis driver currents M92 X80 Y80 Z80 ; configure steps per mm M566 X1200 Y1200 Z1200 ; set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 ; set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 ; set accelerations (mm/s^2) ; Extruders M584 E3 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E663 ; configure steps per mm M566 E1200 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E1000 ; set accelerations (mm/s^2) ; Kinematics M665 L230 R165 B100 H315 ; set delta radius, diagonal rod length, printable radius and homed height M208 Z0 S1 ; set minimum Z M666 X0 Y0 Z0 A0 B0 ; endstop adjustments and XY tilt, can be determined using auto calibration as well ; Probes M558 K0 P1 C"zprobe.in" H5 F120 T6000 ; configure analog probe via slot #0 M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Endstops M574 X2 P"xstop" S1 ; configure X axis endstop M574 Y2 P"ystop" S1 ; configure Y axis endstop M574 Z2 P"zstop" S1 ; configure Z axis endstop ; Sensors M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"e0temp" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1 ; Heaters M950 H0 C"bedheat" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 M950 H1 C"e0heat" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"fan0" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"fan1" ; create fan #1 M106 P1 S0 B0.1 H1 T45 ; configure fan #1 ; Tools M563 P0 D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
@Phaedrux It's going towards me. Then up. Finally it get some kind of stuck en going to make a noise like it's wants to go outside the printer
M119 gives the following message: endstops- X not stopped: Y not stopped: Z not stopped, Z probe not stopped
@Phaedrux
The endstops work when they are triggered. But I'm now looking for the z-probe -
@dc42 I am getting no where. Which board get I buy that is compatible for my tractus 3d t650P? The Duet 3 ?
