Mesh bed and bltouch
I don't know the BLTouch, but i agree, F2000 is rather high. Try 300 or 600.
Hello i will try F3 a 600. Towmorrow. Thanks for the advise
Hey,
I ran the macro,
see here what came out
F300
G32 bed probe heights: -0.007 -0.002 0.000 -0.020 -0.010 0.010 0.007 0.007 0.010 0.010 -0.007 -0.012 -0.007 -0.012 -0.007 -0.002 -0.007 -0.012 -0.010 -0.010 -0.010 -0.012 -0.012 -0.015 -0.002 -0.020 -0.025 0.002 -0.007 0.002 0.042 0.023, mean -0.004, devi
I do not think this is all right, I see the same value a number of times but also many different ones
does anyone have an idea where it can be,F100
M98 P0:/macros/test
G32 bed probe heights: -0.060 -0.035 -0.032 -0.062 -0.032 -0.040 -0.037 -0.047 -0.037 -0.062 -0.040 -0.030 -0.060 -0.055 -0.045 -0.067 -0.045 -0.060 -0.062 -0.060 -0.060 -0.062 -0.065 -0.060 -0.060 -0.070 -0.050 -0.060 -0.055 -0.060 -0.053 -0.037, mean -0 -
Here's mine with:
F100:
G32 bed probe heights: 0.038 0.041 0.042 0.048 0.040 0.043 0.039 0.040 0.040 0.038 0.043 0.040 0.039 0.033 0.036 0.016 0.033 0.040 0.041 0.041 0.041 0.041 0.042 0.038 0.040 0.048 0.043 0.040 0.039 0.046 0.039 0.042, mean 0.040, deviation from mean 0.005F150:
G32 bed probe heights: 0.039 0.041 0.044 0.043 0.038 0.039 0.040 0.041 0.040 0.042 0.042 0.040 0.040 0.044 0.038 0.043 0.044 0.038 0.041 0.045 0.048 0.042 0.039 0.041 0.044 0.043 0.044 0.043 0.046 0.044 0.044 0.039, mean 0.042, deviation from mean 0.003I also did some testing with higher F values, however, as my Z speed wax maxed at 200mm/min, the higher F values were also maxed at 200mm/min and not being used.
@gideon, it looks like your bltouch (or clone) isn't giving reproducible results. Some other users have reported this problem too.
with you the differences are less great than with me I see,
I am thinking about testing one with the ininductive sensor
see what it does,
whether the differences are still so great -
see what it does,
whether the differences are still so greatif you want accurate, repeatable probing, just use a piezo sensor, I can assure you, I tried all other options, but nothing beats its performance and ease of use (not even close).
https://www.precisionpiezo.co.uk/ -
@dc42 Hey,
I am now going to try to see a proximity sensor to see if it works better,
if not, I will order the ir probe -
The BLtouch should be more than accurate enough. Of course, it depends how rigidly you have mounted it. Another good test it to check how mechanically sound your machine is. Set your height a sheet of paper using the nozzle, raise and lower the head by 5mm, check if you still get the same gap between the bed with the paper;.
I have now even mounted a proximity sensor, I think this is better. or is it still nothing
M98 P0: / macros / test
G32 bed probe heights: -0,600 -0,600 -0,600 -0,602 -0,602 -0,608 -0,605 -0,605 -0,602 -0,602 -0,602 -0,605 -0,600-0,602 -0,605 -0,605 -0,605 -0,605 -0,608 -0,600-0,600 -0,602 - 0.605 -0.608 -0.608 -0.605 -0.605 -0.608 -0.605 -0.602 -0.605 -0.605, mean -0 -
That looks a lot better.
I just re-run one of my tests with the bltouch, as probing at higher speeds made no sense as my z speed in config.g was limiting the probing speed. So I now set my Z speed and probe speed to 250. This was the result:
G32 bed probe heights: -0.001 0.003 0.003 0.007 0.001 0.005 0.002 0.006 0.003 0.004 -0.001 -0.004 0.001 0.004 0.003 0.001 0.001 0.005 0.005 0.003 0.004 0.006 0.007 0.009 0.000 0.009 0.003 0.003 0.009 0.003 0.003 0.001, mean 0.003, deviation from mean 0.00
12:06:43M98 P0:/macros/test white F100
G32 bed probe heights: -0.205 -0.200 -0.200 -0.200 -0.203 -0.203 -0.203 -0.200 -0.200 -0.198 -0.200 -0.198 -0.200 -0.200 -0.203 -0.203 -0.200 -0.198 -0.203 -0.200 -0.200 -0.200 -0.205 -0.200 -0.203 -0.200 -0.200 -0.203 -0.200 -0.200 -0.200 -0.200, mean -0
