How to Monitor MCU Temperature on 3HC?
Good morning everyone,
I’m trying to set up two thermostatic fans to ventilate the MCU and electronics, based on the MCU temperature, using the following code:
M308 S10 Y"mcu-temp" A"MCU" ; Set or report sensor parameters M950 F13 Q500 C"1.out4" ; Configure MCU fan M950 F14 Q500 C"1.out5" ; Configure MCU fan M106 P13 S1 T25:70 C"MCU Fan" H10 ; Set fan configuration M106 P14 S1 T25:70 C"MCU Fan" H10 ; Set fan configuration
The issue I’m facing is that I don’t have any available outputs on the Duet 6HC, so I have no choice but to use the last two outputs on the Duet 3HC. I understand that the problem is that since I’m monitoring the MCU temperature of the Duet 6HC, I should be using outputs from the 6HC and not the 3HC.
So, my question is: how can I monitor the temperature of the 3HC instead of the 6HC? I’ve tried M308 S10 Y"1.mcu-temp" A"MCU", but, as expected, it didn’t work.
Best regards,
@Aitor add parameter
P"1.dummy"
to your M308 command. This will cause the M308 command to be routed to board 1. [Edited] -
Thank you very much, @dc42. I’ll try it out next time. Wishing the whole team a Merry Christmas!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
