Duet not connect in anyways - Clue: nozzle fan always on
@droftarts this is what happened
M552 S-1
WiFi module stopped
ok
M552
WiFi module is disabled
ok
M552 S0
ok
M552
WiFi module is being started
ok
M552
ok
M552 S1
Turn off the current WiFi mode before selecting a new one
ok
M552 S-1
WiFi module stopped
ok
M552 S0
ok
M552
ok
M587 S"Ditaranto_living" P"mozzarella55"
Error: M587: Failed to add SSID to remembered list: SPI timeout
ok
M20 P"/firmware"
Begin file list
Duet2CombinedFirmware.bin
Duet2Firmware_SBC.bin
Duet2_SDiap32_Maestro.bin
Duet2_SDiap32_WiFiEth.bin
Duet3Firmware_EXP1HCL.bin
Duet3Firmware_EXP1XD.bin
Duet3Firmware_EXP3HC.bin
Duet3Firmware_MB6HC.bin
Duet3Firmware_MB6XD.bin
Duet3Firmware_Mini5plus.uf2
Duet3Firmware_TOOL1LC.bin
Duet3_SDiap32_MB6HC.bin
Duet3_SDiap32_MB6XD.bin
Duet3_SDiap32_Mini5plus.bin
DuetMaestroFirmware.bin
DuetWiFiModule_32S3.bin
DuetWiFiServer.bin
End file list
ok
M20 P"/sys"
Begin file list
bed.g
cancel.g
config-override.g
config.g
config.g.bak
config.json
deployprobe.g
Duet2CombinedIAP.bin
Duet3_SDiap_MB6HC.bin
DuetMaestroIAP.bin
DuetWiFiServer.bin
dwc-settings.json
favicon.ico.gz
heightmap.csv
homeall.g
homedelta.g
homex.g
homey.g
homez.g
iap4e.bin
index.html.gz
manifest.json.gz
pause.g
precache-manifest.319c6f973151dddcc9a89a7350cae2bc.js.gz
resume.g
retractprobe.g
service-worker.js.gz
sleep.g
stop.g
tfree0.g
tpost0.g
tpre0.g
resurrect.g
End file list
ok
M997 S1
T:180.0 /0.0 T0:180.0 /0.0 B:50.0 /0.0
Trying to connect at 230400 baud: failed
Trying to connect at 115200 baud: failed
Trying to connect at 74880 baud: failed
Trying to connect at 9600 baud: failed
Error: Installation failed due to comm write error
ok
M997 S1 P"/sys/DuetWiFiServer.bin"
T:144.0 /0.0 T0:144.0 /0.0 B:47.4 /0.0
ok -
The .bin is in the SD card but the command I sent didn't produce the expected result
@genioluiz7 The last command you sent was M552 S0, which tries to turn the WiFi module on but in idle mode. You need to turn it off again with
M552 S-1
, then runM997 S1
.Ian
@droftarts said in Duet not connect in anyways - Clue: nozzle fan always on:
You need to turn it off again with M552 S-1, then run M997 S1.
I do it. Tell me what you think
This the results:
M552 S-1
WiFi module stopped
ok
M552
ok
M552 S0
ok
M552
ok
M552 S-1
WiFi module stopped
ok
M997 S1
T0:21.5 /0.0 B:23.0 /0.0
ok -
@genioluiz7 Can you comment out the M552 in config.g? I think it's stuck trying to start the WiFi module. Then reset the Duet, connect via USB and serial terminal, then send M997 S1 without sending any other M552 commands.
where I have to insert the comment M552? Please, can you specify more prcisely what I've to edit in config.g?
I'll post you my config.g here; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Aug 04 2023 19:59:42 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"Chiron" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X80.00 Y100.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z10.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M906 X1000 Y1000 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S0 ; Disable motor idle current reduction; Axis Limits
M208 X-15 Y-15 Z0 S1 ; set axis minima
M208 X400 Y400 Z440 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop+e1stop" ; configure active-high endstop for low end on Z via pin zstop and e1stop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:385 Y15:385 S120 ; define mesh grid; Heaters
M143 H1 S285 ; set temperature limit for heater 1 to 285C; Fans
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@genioluiz7 said in Duet not connect in anyways - Clue: nozzle fan always on:
By comment out, I mean 'stop that command running'. So here:
... ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ...
put a
at the beginning of the M552 line, eg:... ; M552 S1 ; enable network ...
@droftarts
Many thanks. Ok. Is it correct? (See the code below)After do that, how can I upload the edited config.g from the SD card to the board?
M586 P2 S0 ; disable Telnet -
@genioluiz7 Yes, that's correct. If you edited it on the SD card, that's all you need to do. If you edited config.g on your PC, then you need to copy it to the SD card. Then replace the SD card in the Duet and reset.
The config.g file is read by the Duet at start up. It shouldn't now try to turn on. Connect via USB and send M997 S1.
If the WiFi updates correctly, and sending M552 S1 turns it on (check with M122), then you will need to edit config.g to enable networking at start up, by removing the
from the M552 S1 line.Ian
@droftarts nothing. It didn't work. How we proceed now?
M997 S1
T0:20.6 /0.0 B:20.9 /0.0
ok
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SN-6J1DG-3SD6J-TUT3L
Used output buffers: 1 of 26 (2 max)
Static ram: 23896
Dynamic ram: 75148 of which 0 recycled
Never used RAM 13036, free system stack 193 words
Tasks: NETWORK(ready,26.2%,384) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,73.2%,460) IDLE(ready,0.5%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:02:30 ago, cause: reset button or watchdog
Last software reset time unknown, reason: User, GCodes spinning, available RAM 9748, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 29.7, current 34.6, max 34.9
Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 14.09ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.9ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 1001.24ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
= WiFi =
Interface state: disabled
Module is disabled
ok -
@genioluiz7 I'm not sure. Try sending
M552 S0
to put it in idle mode, thenM997 S1
.If that doesn't work, I think whatever event caused the firmware to be deleted in the first place may have damaged the WiFi module. Looking back at the first M122 report you posted, it says:
Last software reset at 1988-01-29 20:06, reason: HardFault undefInstr, Platform spinning, available RAM 106152, slot 0
We have found "HardFault undefInstr" (undefined instructions) are quite often associated with ESD (static discharge) events.
@droftarts So, how can I verify this?
I saw during the tests that the blu led on the wifi module sometimes flashes. Maybe is a signal that it is still alive
There is somenthing else we can try to do? -
@genioluiz7 did you try using M997 S1 to reinstall the WiFi firmware?
@dc42 yes I tried but nothing happened. What do you think?
@genioluiz7 I've read back through the forum thread, and it does seem that the WiFi module has failed. Because the firmware on the Duet was also erased, I'd suspect either a wiring short or ESD "static electricity" shock has caused it to fail. The way that the Duet circuit is designed is that short circuits to the 3.3V rail are first absorbed by the SD card holder and WiFi module, hopefully before the main processor, so that they fail first. They are easier to replace than the main processor.
Most likely you will need to replace the WiFi module. If you can't do this yourself, there may be others local to you that can help, see https://forum.duet3d.com/topic/13875/community-repairs. Unfortunately Duet3D does not carry out these repairs itself. Otherwise, I think you will need to replace the Duet board.
