Firmware 1.20 released
I upgraded from 1.19 to 1.20. Now my BL Touch does not work correctly. It self tests fine, but when I home z, the probe does deploy, but now my printer tries to drive the nozzle through the heat bed. It does not stop.
If I down grade to 1.19 on the firmware, do I need to downgrade the wifi server also?
One way is to upload the new DuetWiFiFirmware.bin and DuetWiFiServer.bin files WITHOUT installing them (or copy them to the SD card on a PC). Also comment out the M552 S1 command in config.g. Then connect via USB and send M997 S0 to update the main firmware. You can watch the progress on PanelDue if you have one. After a minute you should be able to reconnect via USB, then send M997 S1 to update the WiFi firmware. Then follow the "getting connected" instructions for firmware 1.19 and later on the wiki.
did exactly that.. Uploaded and told it not to install. Turned off the wifi, disconnected everything and brought over to computer -
plugged into USB, connect with Printrun(pronto face) type in M997 S0,.. keep getting errors.. Remove SD card and plug in direct to computer.. Can't drag and drop the file won't let me. ?? now what? -
I seriously think my WiFi module is bad. this thing has been nothing but issues, drops connection. won't reconnect 1/2 the time with out a complete power down and restart and then I always had to go in and reconfigure the network info. Every single time. did everything you stated above ad it won't work. Now I can't even get the wifi to turn back on under 1.8.
M552 S1
SENDING:M552 S1
WiFi module started
Error: Failed to initialise WiFi module, code -10
[ERROR] Error: Failed to initialise WiFi module, code -10or,…
M552 S0
SENDING:M552 S0
WiFi module started
[ERROR] Error: Failed to initialise WiFi module, code -10 -
That error usually means that the main firmware and wifi firmware are out of step, i.e. one is pre-1.19 and the other is 1.19 or later. So use M115 to check that your main firmware is version 1.20; then use your PC to put a fresh copy of DuetWiFiServer.bin from the 1.20 release area of github into /sys on the SD card; put it in the Duet, start the Duet, connect via USB, and send M997 S1 to install it. If/when it reports success, try M552 S1 again.
seems to be working. thanks… so far anyway!! AWESOme!
Connecting...
Printer is now online.m115
SENDING:M115
FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23
Disconnected.
Connecting...
M997 S1
SENDING:M997 S1
Trying to connect at 230400 baud:
success
Erasing 4096 bytes...
Erasing 233472 bytes...
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
M552 S1
SENDING:M552 S1
WiFi module started
Wifi module is connected to access point ####, IP address ####### -
so it is working… I recorded this so I could show it if it didn't work and see if I was doing something wrong or it was omething that you guys could see I was missing, or what ever... anyway.. I'll post it for kicks.
https://youtu.be/ICiRkWutB2U -
I had problems installing newer versions than 1.19 on my Duet 0.6 - it would not run.
Can I use the 1.20 on this old board or is the board limited to 1.19?
Yes there is a build of 1.20 for the Duet 0.6 and 0.8.5.
Great! Thanks.
I'm still having problems I'm afraid. Cannot connect to my Duet 0.6 after upgrade to 1.20.1 (RepRapFirmware.bin). I can see that it boots up and runs for about 25 secs, then both ethernet connecor LEDs go out for 3-4 seconds and pattern repeats over an over.
I've installed manually the DuetWebControl associated with this firmware release.
Any ideas?
Regards /Thom
I tested 1.20 on a Duet 0.8.5 but not on a 0.6. You could try putting a minimal config.g file on the SD card, with the network parameters and not much else in it.
Version 1.19.2 was tested on a Duet 0.6.
This is my current config.g
[c]
; Configuration file for Duet 0.6 (firmware version 1.17 to 1.19)
; generated by RepRapFirmware Configuration Tool on Fri Nov 17 2017 18:51:38 GMT+0100 (Västeuropa, normaltid); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P1 ; Set firmware compatibility to look like RepRapFirmare;Delta parameters
M665 L190.000 R90 H236.8 B72.0 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Endstops
M208 Z-0.5 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
M558 P4 X0 Y0 Z0 H4 F120 T8000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
G31 P600 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height
M557 R78 S20 ; Bed mesh; Drives
M92 X100 Y100 Z100 E141.8 ; Set steps per mm
M566 X1200 Y1200 Z1200 E1500 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E12000 ; Set maximum speeds (mm/min)
M201 X2200 Y2200 Z2200 E2000 ; Set accelerations (mm/s^2)
M906 X960 Y960 Z960 E1600 I60 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B3950 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 (bed) to 130C
M305 P1 T100000 B4267 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PMy Mini Kossel ; Set machine name
M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency.
; thermostatic control is turned off; Read in calibration override settings
M501
G29 S1 ; Read in bed height correction map; Miscellaneous
T0 ; Select first tool
[/c]I'm going to try the network parameters only and then if I manage to connect to it, I'll uncomment paragraphs
step by step./Thom
Any ideas?
Regards /Thom
This sounds exactly like my problem with 0.85 too.
I did not think about simplifying the config.g, since this is not an option to my opinion, but I am curious to see the results. I am still on 1.18.1 because of that. The 1.19 does run, but it is very unstable, and the 1.20 will not start up at all with my config. -
I'm able to make connection via the USB port using Repetier-Host V2.05. A short clip from the serial log:
[c]22:27:09.813 : RepRapFirmware for Duet is up and running.
22:27:09.816 : N10 M111 S686
22:27:09.816 : FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.20.1RC2 ELECTRONICS: Duet 0.6 FIRMWARE_DATE: 2018-01-01
22:27:09.816 : N11 T010
22:27:09.847 : X:0.000 Y:0.000 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 Count 0 0 0 User 0.0 0.0 0.0
22:27:09.847 : serial: T0
22:27:09.847 : serial: M20
22:27:09.847 : Begin file list
22:27:09.849 : Enclosures
22:27:09.849 : Kossel
22:27:09.849 : Art
22:27:09.849 : Supports and mounts
22:27:09.849 : X5S
22:27:09.849 : Couplings
22:27:09.849 : MK PLA L015 N035 (Noraft) PrtAlignmentModel.gcode
22:27:09.849 : Diverse
22:27:09.849 : Gee(i3)
22:27:09.849 : Alu profile 20x20
22:27:09.852 : End file list
22:27:09.852 : serial: M80
22:27:09.852 : serial: M105
22:27:09.853 : serial: M111 S6
22:27:09.853 : serial: T0
22:27:12.803 : N12 M10520
22:27:12.805 : serial: M105
22:27:15.863 : N13 M10521
22:27:15.864 : serial: M105
22:27:18.929 : N14 M10518
22:27:18.930 : serial: M105
22:27:21.989 : N15 M10519
22:27:21.990 : serial: M105
22:27:25.048 : N16 M10516
22:27:25.049 : serial: M105
22:27:28.114 : N17 M10517
22:27:28.114 : serial: M105
22:27:31.174 : N18 M10530
22:27:31.175 : serial: M105
22:27:34.240 : N19 M10531
22:27:34.241 : serial: M105
22:27:37.300 : N20 M10521
22:27:37.301 : serial: M105
22:27:40.367 : N21 M10520
22:27:40.368 : serial: M105
22:27:43.426 : N22 M10523
22:27:43.428 : serial: M105
22:27:46.492 : N23 M10522
22:27:46.493 : serial: M105
22:27:49.552 : N24 M105*17
22:27:49.553 : serial: M105
[/c]However, if I connect the Ethernet cable, Repetier-Host gets disconnected and the Reboot pattern starts to run again. The current config.g:
[c]
;M111 S0 ; Debugging off
;M83 ; ...but relative extruder moves
;M555 P1 ; Set firmware compatibility to look like RepRapFirmare;Delta parameters
;M665 L190.000 R90 H236.8 B72.0 ; Set delta radius, diagonal rod length, printable radius and homed height
;M666 X0 Y0 Z0 ; Endstops
;M208 Z-0.5 S1 ; Set minimum Z; Endstops
;M574 X2 Y2 Z2 S1 ; Set active high endstops
;M558 P4 X0 Y0 Z0 H4 F120 T8000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
;G31 P600 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height
;M557 R78 S20 ; Bed mesh; Drives
;569 P0 S1 ; Drive 0 goes forwards
;569 P1 S1 ; Drive 1 goes forwards
;M569 P2 S1 ; Drive 2 goes forwards
;M569 P3 S1 ; Drive 3 goes forwards
;M92 X100 Y100 Z100 E141.8 ; Set steps per mm
;M566 X1200 Y1200 Z1200 E1500 ; Set maximum instantaneous speed changes (mm/min)
;M203 X18000 Y18000 Z18000 E12000 ; Set maximum speeds (mm/min)
;M201 X2200 Y2200 Z2200 E2000 ; Set accelerations (mm/s^2)
;M906 X960 Y960 Z960 E1600 I60 ; Set motor currents (mA) and motor idle factor in per cent
;M84 S30 ; Set idle timeout; Heaters
;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
;M305 P0 T100000 B3950 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 0
;M143 H0 S130 ; Set temperature limit for heater 0 (bed) to 130C
;M305 P1 T100000 B4267 C0 R1000 H10 ; Set thermistor + ADC parameters for heater 1
;M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Tools
;M563 P0 D0 H1 ; Define tool 0
;G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
;G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency.
;M501
;G29 S1 ; Read in bed height correction map; Miscellaneous
;T0 ; Select first tool
[/c] -
As I work with embedded systems myself I see the typical symptoms of a stack crash. While watching the output from the serial line I could observe some kind of "hartbeat" messages from classes running inside the Duet. All seems normal until I plug the ethernet cable in. Then everything just stops.
If you run M122 from USB, how much free memory does it report?
I'm not sure wich number you're after so I copied the entire response:
[c]17:34:17.138 : serial: M122
17:34:17.143 : LINK
17:34:17.145 : xmit: 0
17:34:17.145 : recv: 0
17:34:17.145 : fw: 0
17:34:17.145 : drop: 0
17:34:17.145 : chkerr: 0
17:34:17.145 : lenerr: 0
17:34:17.145 : memerr: 0
17:34:17.145 : rterr: 0
17:34:17.145 : proterr: 0
17:34:17.145 : opterr: 0
17:34:17.145 : err: 0
17:34:17.145 : cachehit: 0
17:34:17.145 : ETHARP
17:34:17.146 : proterr: 0
17:34:17.146 : opterr: 0
17:34:17.146 : err: 0
17:34:17.146 : cachehit: 0
17:34:17.146 : IP_FRAG
17:34:17.146 : xmit: 0
17:34:17.146 : recv: 0
17:34:17.146 : fw: 0
17:34:17.146 : drop: 0
17:34:17.146 : chkerr: 0
17:34:17.146 : lenerr: 0
17:34:17.146 : memerr: 0
17:34:17.146 : rterr: 0
17:34:17.146 : IP
17:34:17.147 : memerr: 0
17:34:17.147 : rterr: 0
17:34:17.147 : proterr: 0
17:34:17.147 : opterr: 0
17:34:17.147 : err: 0
17:34:17.147 : cachehit: 0
17:34:17.147 : IGMP
17:34:17.147 : xmit: 0
17:34:17.147 : recv: 0
17:34:17.147 : drop: 0
17:34:17.147 : chkerr: 0
17:34:17.147 : lenerr: 0
17:34:17.147 : rx_v1: 0
17:34:17.147 : rx_group: 0
17:34:17.147 : rx_general: 0
17:34:17.147 : rx_report: 0
17:34:17.147 : tx_join: 0
17:34:17.148 : tx_leave: 0
17:34:17.148 : tx_report: 0
17:34:17.148 :
17:34:17.148 : ICMP
17:34:17.148 : xmit: 0
17:34:17.148 : recv: 0
17:34:17.148 : fw: 0
17:34:17.148 : drop: 0
17:34:17.148 : chkerr: 0
17:34:17.148 : lenerr: 0
17:34:17.148 : memerr: 0
17:34:17.148 : rterr: 0
17:34:17.148 : proterr: 0
17:34:17.148 : opterr: 0
17:34:17.148 : err: 0
17:34:17.148 : cachehit: 0
17:34:17.148 : UDP
17:34:17.149 : rterr: 0
17:34:17.149 : proterr: 0
17:34:17.149 : opterr: 0
17:34:17.149 : err: 0
17:34:17.149 : cachehit: 0
17:34:17.149 : TCP
17:34:17.149 : xmit: 0
17:34:17.149 : recv: 0
17:34:17.149 : fw: 0
17:34:17.149 : drop: 0
17:34:17.149 : chkerr: 0
17:34:17.149 : lenerr: 0
17:34:17.149 : memerr: 0
17:34:17.149 : MEM HEAP
17:34:17.149 : avail: 1024
17:34:17.150 : used: 0
17:34:17.150 : max: 0
17:34:17.150 : err: 0
17:34:17.150 : MEM UDP_PCB
17:34:17.150 : avail: 5
17:34:17.150 : used: 2
17:34:17.150 : max: 2
17:34:17.150 : MEM TCP_PCB
17:34:17.150 : avail: 16
17:34:17.150 : MEM TCP_PCB_LISTEN
17:34:17.151 : avail: 4
17:34:17.151 : used: 0
17:34:17.151 : max: 0
17:34:17.151 : err: 0
17:34:17.151 : MEM TCP_SEG
17:34:17.151 : avail: 16
17:34:17.151 : MEM REASSDATA
17:34:17.151 : avail: 2
17:34:17.151 : MEM FRAG_PBUF
17:34:17.151 : avail: 8
17:34:17.151 : MEM IGMP_GROUP
17:34:17.152 : avail: 8
17:34:17.152 : used: 0
17:34:17.152 : max: 0
17:34:17.152 : err: 0
17:34:17.152 : MEM SYS_TIMEOUT
17:34:17.152 : used: 6
17:34:17.152 : max: 6
17:34:17.152 : MEM PBUF_REF/ROM
17:34:17.152 : avail: 4
17:34:17.152 : MEM PBUF_POOL
17:34:17.152 : avail: 5
17:34:17.152 : === Diagnostics ===
17:34:17.153 : Used output buffers: 1 of 32 (15 max)
17:34:17.153 : === Platform ===
17:34:17.153 : RepRapFirmware for Duet version 1.20.1RC2 running on Duet 0.6
17:34:17.153 : Static ram used: 44836
17:34:17.153 : Dynamic ram used: 40508
17:34:17.153 : Recycled dynamic ram: 672
17:34:17.153 : Stack ram used: 3520 current, 5528 maximum
17:34:17.153 : Never used ram: 6760
17:34:17.154 : Last reset 00:07:46 ago, cause: power up
17:34:17.154 : Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 8620 bytes (slot 2)
17:34:17.154 : Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087e6c
17:34:17.155 : Stack: 000bfb1f 01c8a8c0 fffffff9 00ffffff 20087ebc 20070fe8 01c8a8c0 20087ebc 000a6221 000a6220 21000000 20087ea0 2007a938 00000000 2007376c 200737a8 20087ebc 0000012c 2007aea8 75207369 01c8a8c0 2007376c 000a5b1d 2001376c
17:34:17.155 : Error status: 0
17:34:17.155 : Free file entries: 10
17:34:17.155 : SD card 0 detected, interface speed: 21.0MBytes/sec
17:34:17.155 : SD card longest block write time: 0.0ms
17:34:17.155 : MCU temperature: min 26.2, current 27.3, max 27.8
17:34:17.156 : Date/time: 1970-01-01 00:00:00
17:34:17.156 : Slowest main loop (seconds): 0.009165; fastest: 0.000104
17:34:17.156 : === Move ===
17:34:17.156 : MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
17:34:17.156 : Scheduled moves: 0, completed moves: 0
17:34:17.156 : Bed compensation in use: none
17:34:17.157 : Bed probe heights: 0.000 0.000 0.000 0.000 0.000
17:34:17.157 : === Heat ===
17:34:17.157 : Bed heaters = 0, chamberHeaters = -1 -1
17:34:17.157 : === GCodes ===
17:34:17.157 : Segments left: 0
17:34:17.157 : Stack records: 1 allocated, 0 in use
17:34:17.157 : Movement lock held by null
17:34:17.157 : http is idle in state(s) 0
17:34:17.157 : telnet is idle in state(s) 0
17:34:17.157 : file is idle in state(s) 0
17:34:17.157 : serial is ready with "M122" in state(s) 0
17:34:17.158 : aux is idle in state(s) 0
17:34:17.158 : daemon is idle in state(s) 0
17:34:17.158 : queue is idle in state(s) 0
17:34:17.158 : autopause is idle in state(s) 0
17:34:17.158 : Code queue is empty.
17:34:17.158 : === Network ===
17:34:17.158 : Free connections: 16 of 16
17:34:17.158 : Free transactions: 24 of 24
17:34:17.158 : Locked: 0, state: 2, listening: 0x0, 0x0, 0x0
[/c] -
The "heartbeat" message
[c]17:36:25.475 : N151 M10534
17:36:25.476 : serial: M105
17:36:28.535 : N152 M10533
17:36:28.537 : serial: M105
17:36:31.062 : Class GCodes spinning
17:36:31.062 : Class Move spinning
17:36:31.062 : Class Platform spinning
17:36:31.062 : Class Network spinning
17:36:31.064 : Class Heat spinning
17:36:31.064 : Class PrintMonitor spinning
17:36:31.601 : N153 M10532
17:36:31.602 : serial: M105
17:36:34.660 : N154 M10539
17:36:34.661 : serial: M105
17:36:37.720 : N155 M10538
17:36:37.721 : serial: M105
17:36:40.786 : N156 M10537
17:36:40.787 : serial: M105
[/c] -
I upgraded my Duet WiFi firmware from 1.19 to 1.20 yesterday. All seems to be working but I'm getting strange error messages when I start a print. They start at layer 0 but I was slow to capture them - each layer gives an error like this:
[c]17:34:59Error: Bad command: // starting layer 19 at 2.47368mm
17:34:47Error: Bad command: // starting layer 18 at 2.4mm
17:34:35Error: Bad command: // starting layer 17 at 2.2mm
17:34:24Error: Bad command: // starting layer 16 at 2.18947mm
17:34:12Error: Bad command: // starting layer 15 at 2mm
17:34:01Error: Bad command: // starting layer 14 at 1.90526mm
17:33:49Error: Bad command: // starting layer 13 at 1.8mm
17:33:37Error: Bad command: // starting layer 12 at 1.62105mm
[/c]The print worked OK but layer height was 0.2mm so I'm a little surprised by some of the layer heights.
What does this mean, please?
Richard
(edited to correct the starting layer from 1 to 0)
