dozuki.com
I am so far now, that I have the Z-Probe kind a working...
but it does not stop Z-movement but WLAN and fans.I am sure, that I will get this working somehow. But oh boy...
This is not fun.Doing everything by gcode and then not getting a gcode syntax and some examples when searching but long text that have nothing to do with figuring out what the existing commands mean...
The only thing that I do like, is the wifi and web interface.
It may be nice, once the printer is configured to just send the files, without having to target small sd card slots.Also the editor inside and the refresh is nice to have.
But it would even be nicer if you could mark a gcode number and get the syntax with description of the parameters like in a programming interface.
It takes minutes to google the commands each time and scroll to the relevant part of information.
Back to the endstop... go through every file to find something suspicous connected to e0-stop that may be changed to something with Z instead of Fan and Wifi...
@MartinMV Gcode dictionary: https://docs.duet3d.com/en/User_manual/Reference/Gcodes
Follow the guides on the left hand side of the wiki pages, eg:
Wiring your Duet 2: https://docs.duet3d.com/en/How_to_guides/Wiring_your_Duet_2
Configuring Firmware: (This is out of date, as the firmware configuration tool has been updated recently, but all the concepts are the same) https://docs.duet3d.com/en/How_to_guides/Configuring_firmware
Testing everything works: https://docs.duet3d.com/en/How_to_guides/CommissioningIf you type a gcode into the search bar of the wiki, it will take you straight to it. Integrating the lookup in DWC has been requested, but it can't be implemented using the current wiki software.
@MartinMV said in dozuki.com:
Back to the endstop... go through every file to find something suspicous connected to e0-stop that may be changed to something with Z instead of Fan and Wifi...Sounds more likely that you have connected the probe between +V and Ground, so it's shorting out the board when triggered.
I had reverted it and now fan and wifi stay on.
But still even with
M574 Z1 P"e1_stop" S2 ; Z-Probe
or
M574 Z2 P"e1_stop" S2 ; Z-Probethe probe does not stop Z-movement in any way...
maybe this behaviour is defined somewhere else... -
e1stop or e1_stop
documentation... no info on the wiring documentation... -
interesting: there is a dedicated probe slot on the board but with four pins... which means crimping
probably then it will work without all that defining of e1_stop or e1stop to a probe. Which I could not figure out if it is with _ or not with the documentation.
homing moves are defined in your homing files. homex.g homey.g homez.g homeall.g which get executed when G28 X, G28 Y, G28 Z, or G28 is sent, respectively.
The probe will be used when G30 is sent.
Endstops are used when G1 H1 moves are sent.See here:
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_cartesian -
Duet 2 pin names are here: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-names
There's a link to the pin name format: https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3#pin-namesA pin name is a string of characters enclosed in double quotation marks. It is not case sensitive. All instances of _ and - characters are stripped from pin names before comparing them.
So either e1stop or e1_stop are acceptable.
What type of probe are you trying to connect?
crimped it for the other slot but does not work either...
by the way I could not even google anywhere if green or blue is grnd.I think I had it wrong.
days of work - if I give me a low salary of 20 bucks for every hour spend on this, I better buy a bambolab now... it will be cheaper -
@MartinMV Did you change the config? What probe is it, sounds like an inductive probe?
As @Phaedrux said, there's a fundamental difference between an endstop and a probe. You can have both on the Z axis, with your homing macros determining which is used to set Z0.
An endstop is usually a simple switch, it is defined by M574, and is triggered by moving the axis with a G1 H1 homing command. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops
A probe can can also be a simple digital switch, but can also have an analogue output. The way it is integrated into the firmware is different, and has multiple functions and uses. A probe is defined by M558, and controlled by a number of different commands, depending on what function is required, including acting as an endstop to set the Z0 position. eg G30 (single probe), G29 (bed mesh), G38.2/3/4/5 (various workpiece probing commands). Probes that need to be deployed before use and retracted after are also supported. See the links @Phaedrux provided earlier.
anyway what ever it is, it needs to stop the movement if installed. And i find no solution for this.
Also the printer does not move up when running as a probe and just stays down and forces the probe along the bed
I just want to install a firmware not learn a complicated, non or bad documented ecosystem made by people who do not care about customer experiences.
@MartinMV maybe you'll do everyone a favour by installing klipper?
@MartinMV I think you have chosen the wrong hobby. You have the strangest attitude, being rude to people who have been nothing but professional and helpful with you. You fail to provide information for us to help you. You moan about documentation and customer experience, but you have been supplied with fast and accurate responses, and plentiful documentation links. If you have questions, ask them. Being negative doesn't help you.
I assume you are installing a Duet board on a printer that has a broken controller board; again, some explanation of what you're trying to do would be helpful. Maybe you should have replaced it with the same board, from the manufacturer. Otherwise, any controller board/firmware is going to need configuration. Duet boards probably have the most in-depth documentation of ANY controller board, being open source, and a strong community around using them. Try doing this with a Chinese board.
Until I get any substantive, specific information from you, there is little point in replying to you.
EDIT: Also, read the forum rules: https://forum.duet3d.com/topic/20759/forum-rules
And guide for requesting help: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help -
I am sure that I will not stick with Duet3d hardware. Reprap firmware is so convoluted that I must admit it was a mistake trying to install.
At no point I was so rude to argue ad personam like you.
And everything you say about me, tells people a lot about you but nothing about me.
I had not the best days recently.
And my original board is fully functioning and I can turn back any day, if I like.
But I wanted to install that super firmware on one of the extremly good Duet3d boards to see, my printer functioning much better.I fell for a guy, who did clickbait on youtube.
@MartinMV Best of success in your future endeavors!
I'm locking this thread as it has strayed a long way from the original subject.
undefined droftarts locked this topic
