Random Hard Fault resets on Duet 3 Mini WiFi
@dc42 Here is a "clean" Network error
9/29/2024, 8:51:57 PM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3 (2024-09-18 11:25:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: UF2UK-QQ6KL-K65J0-409NA-L7X1Z-Z1P2J Used output buffers: 15 of 40 (36 max) === RTOS === Static ram: 103368 Dynamic ram: 124556 of which 0 recycled Never used RAM 10972, free system stack 192 words Tasks: NETWORK(2,nWait 7,15.3%,228) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,341) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(1,running,82.9%,665) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,259), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 02:21:45 ago, cause: software Last software reset at 2024-09-29 18:30, reason: HardFault imprec, Gcodes spinning, available RAM 10972, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012020 Task NETW Freestk 488 ok Stack: 2002c658 20032820 200014e4 00000000 200339bf 0003039d 000302b4 610f6000 20036538 2002c640 2001882c 2002c496 2001882c 2001ea80 00030523 00000000 00000000 00000000 200120b8 00000014 b5ddb6d6 00000002 19e40050 1b03a8c0 08000163 00000001 00034c99 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 6379360, completed 6379360, timed out 0, errs 0 MCU temperature: min 40.5, current 40.7, max 42.6 Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1028/204, gc cycles 141 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 153, reads 54428, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 378, read errors 0, write errors 1, ifcnt 187, reads 54427, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 256, read errors 0, write errors 1, ifcnt 234, reads 54427, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 238, read errors 0, write errors 1, ifcnt 228, reads 54428, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 152, reads 54428, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-09-29 20:51:55 Cache data hit count 4294967295 Slowest loop: 10.03ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 76586, received 348775, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 272, free buffers 26 (min 25), ts 42529/42528/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 10.66ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(2) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address c4:5b:be:46:4f:6c Module reset reason: Power up, Vcc 3.43, flash size 2097152, free heap 37744 WiFi IP address 192.168.3.139 Signal strength -51dBm, channel 11, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 9/29/2024, 8:52:42 PM M122 P106 Platform 2001d138-2001e737 SbcInterface 2001e740-2001ea70 Network 2001ea80-2001eb67 GCodes 2001eb70-2001ff6f Move 20023ff8-20024d33 Heat 20025110-20025237 PrintMonitor 20025240-2002544f FansManager 20025458-200254d7 PortControl 200254e0-2002550f Display 20025518-20025533 ExpansionManager 20025540-200282f7 9/29/2024, 8:53:38 PM M122 P1007 A{0x2001ea80+8} 2001ea88: 2002c420 9/29/2024, 8:54:06 PM M122 P1007 A{0x2002c420+136} 2002c4a8: 20033850
Hi, I have a Big Dipper board with 3.5.3 installed
In case it will be of any help
m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3 (2024-09-18 11:25:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: RHYS5-6J9MK-K65J0-40TK2-JRW2Z-ZLX8A Used output buffers: 3 of 40 (18 max) === RTOS === Static ram: 103368 Dynamic ram: 121908 of which 12 recycled Never used RAM 16460, free system stack 206 words Tasks: NETWORK(2,nWait 7,14.4%,217) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,1.4%,110) MAIN(1,running,83.4%,665) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:16:28 ago, cause: software Last software reset at 2024-10-12 09:04, reason: HardFault invState, Gcodes spinning, available RAM 13464, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00489803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 482 ok Stack: 0000017d 00000002 200014e4 00000000 20032fe9 000a0f9f 00000000 600f0000 00000000 00000000 00000000 00000000 20031e34 00000800 2002c640 2002c640 00000001 2002c496 2001882c 2001ea80 00030523 00000000 00000000 00000000 200120b8 00000014 b5dd500a Error status: 0x00 MCU revision 3, ADC conversions started 741990, completed 741988, timed out 0, errs 0 MCU temperature: min 29.1, current 31.6, max 31.8 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 38, read errors 0, write errors 1, ifcnt 36, reads 24344, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 6, read errors 0, write errors 1, ifcnt 36, reads 24343, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 24343, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24343, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24344, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 24343, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24343, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-10-12 09:20:57 Cache data hit count 1872586024 Slowest loop: 7.85ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 1.4ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 8900, received 0, lost 0, errs 4675536, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 4945/0/0 Tx timeouts 0,0,4944,0,0,3954 last cancelled message type 4514 dest 127 === Network === Slowest loop: 5.85ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address 08:3a:8d:eb:24:44 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42932 WiFi IP address 192.168.1.69 Signal strength -48dBm, channel 7, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 m122p106 Platform 2001d138-2001e737 SbcInterface 2001e740-2001ea70 Network 2001ea80-2001eb67 GCodes 2001eb70-2001ff6f Move 20023ff8-20024d33 Heat 20025110-20025237 PrintMonitor 20025240-2002544f FansManager 20025458-200254d7 PortControl 200254e0-2002550f Display 20025518-20025533 ExpansionManager 20025540-200282f7 m122p1007 a{0x2001ea80+8} 2001ea88: 2002c420 m122p1007 a{0x2002c420+136} 2002c4a8: 20032e60
Update: had another one. The printer was heating up an extruder and the bed
m122p1007 a{0x2002c420+136} 2002c4a8: 20032e60 m122p1007 a{0x2001ea80+8} 2001ea88: 2002c420 m122p106 Platform 2001d138-2001e737 SbcInterface 2001e740-2001ea70 Network 2001ea80-2001eb67 GCodes 2001eb70-2001ff6f Move 20023ff8-20024d33 Heat 20025110-20025237 PrintMonitor 20025240-2002544f FansManager 20025458-200254d7 PortControl 200254e0-2002550f Display 20025518-20025533 ExpansionManager 20025540-200282f7 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3 (2024-09-18 11:25:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: RHYS5-6J9MK-K65J0-40TK2-JRW2Z-ZLX8A Used output buffers: 3 of 40 (18 max) === RTOS === Static ram: 103368 Dynamic ram: 121884 of which 12 recycled Never used RAM 16484, free system stack 202 words Tasks: NETWORK(2,nWait 7,9.8%,217) HEAT(3,nWait 1,0.0%,333) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,1.4%,110) MAIN(1,running,86.0%,665) IDLE(0,ready,1.9%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:00:11 ago, cause: software Last software reset at 2024-10-12 19:13, reason: HardFault invState, Gcodes spinning, available RAM 16484, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 482 ok Stack: 0000017d 00000002 200014e4 00000000 20032fe9 000a0f9f 00000000 600f0000 00000000 00000000 00000000 00000000 20031e34 00000800 2002c640 2002c640 00000001 2002c496 2001882c 2001ea80 00030523 00000000 00000000 00000000 200120b8 00000014 b5dd500a Error status: 0x00 MCU revision 3, ADC conversions started 8945, completed 8943, timed out 0, errs 0 MCU temperature: min 38.0, current 38.4, max 38.4 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 35, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 1024, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 226, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 4, read errors 0, write errors 1, ifcnt 49, reads 1025, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-10-12 19:13:30 Cache data hit count 22185019 Slowest loop: 4.54ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 0.7ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 103, received 0, lost 0, errs 55179, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 58/0/0 Tx timeouts 0,0,57,0,0,44 last cancelled message type 4514 dest 127 === Network === Slowest loop: 5.72ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address 08:3a:8d:eb:24:44 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41020 WiFi IP address 192.168.1.69 Signal strength -38dBm, channel 7, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
If anyone who experiences this issue would like to help track down this issue, I have put a build of RRR 3.5.3 for the Duet 3 Mini with extra debugging info at https://www.dropbox.com/scl/fo/vp24fllwuua9yejr8pej1/ANRHyUhbMU5DRTJBNeF1sKg?rlkey=97mm1rpm4h0m22bjalgxmrrwq&dl=0. Please install this, connect a PC running a terminal emulator to the USB port, and leave it running with at least one DWC session connected to it. If you see any "Memory difference" messages on the terminal then please report them here, and if you get any resets then please post a M122 report.
@dc42 Build installed and running.
and I've logged a message in the console already:
*** Memory difference at offset 24: was a5a5a5a5 now 00000000
That was the final message in the console before the reset. The printer was idle. DWC was open in Chrome.
No reset to report.
M122=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3+1dbg (2024-10-14 09:45:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: NTK2Z-J196U-D65J0-40KMN-1V03Z-ZJMGF Used output buffers: 3 of 40 (26 max) === RTOS === Static ram: 103368 Dynamic ram: 124576 of which 0 recycled Never used RAM 10952, free system stack 156 words Tasks: NETWORK(2,nWait 7,8.3%,228) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,361) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,798) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait 6,1.5%,101) MAIN(1,running,87.7%,665) IDLE(0,ready,1.6%,29) AIN(4,delaying,0.8%,259), total 100.0% Owned mutexes: === Platform === Last reset 00:00:18 ago, cause: software Last software reset at 2024-10-17 18:07, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 7892, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20012008 Task NETW Freestk 482 ok Stack: 00000165 00000002 200014e4 00000164 20033af1 000a102f 0003041a 810f0000 00030411 00000000 00000000 00000000 2003111c 00000800 20036670 2002c5d8 2001882c 2002c42e 2001882c 2001ea80 000305ab 00000000 00000000 00000000 200120b8 00000014 b5ddddb2 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 14510, completed 14510, timed out 0, errs 0 MCU temperature: min 33.7, current 33.7, max 35.1 Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/10, heap memory allocated/used/recyclable 2048/304/132, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 47, reads 1693, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 47, reads 1693, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 1696, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 51, reads 1692, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 51, reads 1693, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 47, reads 1693, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 1696, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-10-17 18:07:41 Cache data hit count 35094639 Slowest loop: 5.03ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 0.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 181, received 573, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6060, peak Tx sync delay 90, free buffers 26 (min 25), ts 95/94/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 4.31ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address d8:bf:c0:14:e5:fc Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 42932 WiFi IP address 192.168.2.8 Signal strength -47dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
And a second reset about an hour later.
M122
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3+1dbg (2024-10-14 09:45:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: NTK2Z-J196U-D65J0-40KMN-1V03Z-ZJMGF Used output buffers: 3 of 40 (28 max) === RTOS === Static ram: 103368 Dynamic ram: 124564 of which 12 recycled Never used RAM 10952, free system stack 156 words Tasks: NETWORK(2,nWait 7,15.5%,241) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,335) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,1.5%,101) MAIN(1,running,82.1%,665) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,259), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:14:36 ago, cause: software Last software reset at 2024-10-17 19:14, reason: HardFault bfarValid precise, none spinning, available RAM 10952, slot 1 Software reset code 0x0073 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x0000001c SP 0x20012008 Task NETW Freestk 482 ok Stack: 2002c5f0 200328a0 200014e4 00000000 ffffffff 00030425 00030338 610f0000 00030411 00000000 00000000 00000000 200328ac 00000800 200365c0 2002c5d8 2001882c 2002c42e 2001882c 2001ea80 000305ab 00000000 00000000 00000000 200120b8 00000014 b5ddddb2 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 3357571, completed 3357570, timed out 0, errs 0 MCU temperature: min 30.2, current 30.7, max 32.1 Supply voltage: min 24.3, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/10, heap memory allocated/used/recyclable 2048/304/132, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 61, reads 13726, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 61, reads 13726, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 13729, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 13726, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 13726, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 61, reads 13726, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 13729, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-10-17 20:29:25 Cache data hit count 4294967295 Slowest loop: 9.45ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.7ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 40299, received 127619, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6031, peak Tx sync delay 282, free buffers 26 (min 25), ts 22384/22383/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 7.94ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address d8:bf:c0:14:e5:fc Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 42772 WiFi IP address 192.168.2.8 Signal strength -48dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@omtek thanks for your feedback. Please continue to report any instances of this message and resets (whether associated with a debug message or not).
Please note, if you are using YAT on a PC as the terminal emulator, then after any reset of the Duet you need to tell YAT to disconnect and then reconnect. Older versions of YAT used to reconnect automatically, but sadly the current version does not.
FWIW I have been running this and similar debug builds since the start of this week, and I have seen messages giving memory differences at offsets 32, 24 and 16 although in most cases they did not result in a reset.
@dc42 Logged another message. Printer was idle at the time, and this was the first memory difference message since my last post. There haven't been any resets since my last post, either.
*** Memory difference at offset 20: was 2001ea80 now 00000000
Had another reset this morning. I didn't record any additional memory difference messages. The printer was sitting idle, cooling down after completing a print about 35-40 minutes prior.
M122
m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.3+1dbg (2024-10-14 09:45:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: NTK2Z-J196U-D65J0-40KMN-1V03Z-ZJMGF Used output buffers: 3 of 40 (28 max) === RTOS === Static ram: 103368 Dynamic ram: 124564 of which 12 recycled Never used RAM 10952, free system stack 156 words Tasks: NETWORK(2,nWait 7,15.5%,240) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,341) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,delaying,1.5%,101) MAIN(1,running,82.1%,665) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,259), total 100.0% Owned mutexes: === Platform === Last reset 03:15:48 ago, cause: software Last software reset at 2024-10-20 05:47, reason: HardFault bfarValid precise, Expansion spinning, available RAM 7204, slot 0 Software reset code 0x4072 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00446803 BFAR 0x00000004 SP 0x20012008 Task NETW Freestk 482 ok Stack: 00000167 00000002 200014e4 00000166 20033af3 000a102f 0003041a 810f0000 00030411 00000000 00000000 00000000 20032964 00000800 20036670 2002c5d8 2001882c 2002c42e 2001882c 2001ea80 000305ab 00000000 00000000 00000000 200120b8 00000014 b5ddddb2 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 8811290, completed 8811289, timed out 0, errs 0 MCU temperature: min 33.0, current 33.3, max 35.4 Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/10, heap memory allocated/used/recyclable 2048/304/132, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 19406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 113, reads 19406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 19409, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 120, reads 19406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 119, reads 19406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 2, read errors 0, write errors 1, ifcnt 113, reads 19406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 19409, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-10-20 09:02:56 Cache data hit count 4294967295 Slowest loop: 9.39ms; fastest: 0.16ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.8ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 105742, received 334856, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6060, peak Tx sync delay 284, free buffers 26 (min 25), ts 58741/58740/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 13.05ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address d8:bf:c0:14:e5:fc Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 42764 WiFi IP address 192.168.2.8 Signal strength -51dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@omtek thanks again. Based on your results and some messages from my own system, I have built up a picture of what is happening.
@omtek @Exerqtor @wschadow @Maurits @Inlinebrother please install the new 3.5.3 debug firmware that I have just put at https://www.dropbox.com/scl/fo/vp24fllwuua9yejr8pej1/ANRHyUhbMU5DRTJBNeF1sKg?rlkey=97mm1rpm4h0m22bjalgxmrrwq&dl=0. Like the previous version, this will print a debug message to USB when it detects that something is amiss. This build also attempts to recover from the situation in order to avoid a reset.
As before, please leave this running on your machine with a PC running a terminal emulator connected to the Duet USB port, and at least one instance of DWC connected to it via WiFi. Please report any "Memory difference" messages appearing on that terminal, also the M122 report if you are unlucky enough to have a reset.
Based on your reports and any further messages that my own system produces, I will evaluate whether this code with the debug removed can form the basis of a solution to this annoying issue.
@dc42 Logged a memory difference message with the new build. Printer was idle. No reset as of yet.
*** Memory difference at line 2228 offset 12: original 0d0a0d39 copy 20032958, original changed, copy ok, fix=yes
Logged another memory difference message. Still no reset.
*** Memory difference at line 2228 offset 60: original 2001882c copy 0d0a0d39, original ok, copy changed, fix=no
@dc42 Haven't had time to look at this before now (like I mentioned in the email), but do you have a debug version based on 3.6 as well?
@Exerqtor I'll prepare a 3.6 version with the debug in it today.
@Exerqtor I've put a 3.6.0-beta.1+debug build for the Duet 3 Mini at https://www.dropbox.com/scl/fo/01s6pikmcusa2e3vu0rkh/APdYxDkXDSIWqeQl0R__Gag?rlkey=iwd3zb2dk3ggjw7ihcy2whg5h&dl=0. The instructions are slightly different from the 3.5.3 version:
- Install it
- Preferably, connect a PC running a terminal emulator to the USB port, check it is communicating with the Duet, and execute M111 P8 S1 to enable debug messages
- Leave it running with at least one DWC session connected
- Report any "Mem diff" messages that are displayed on the terminal emulator
- If you get any unexpected resets, post a M122 report
If you don't wish to connect a terminal emulator, then don't run M111 P8 S1 and it won't attempt to output the debug messages to USB. It will still log up to 4 memory difference reports internally, but only if the board doesn't reset. Running M122 will report these messages just before the "Storage" section of the report, and clear them.
@omtek thanks, that's useful information. The first memory difference would likely have resulted in a reset in previous firmware versions, but the memory check detected and fixed it. The second memory difference was harmless.
@omtek said in Random Hard Fault resets on Duet 3 Mini WiFi:
Out of curiosity, how long had you had the logging going before it threw these messages?
@Exerqtor With both debug builds I logged a memory difference message within a couple of hours. The first debug build was under an hour, the second took maybe 1-2 hours to show up.
For comparison, my system has logged anything from 0 to 4 memory differences in 24 hours. I have two instances of DWC connected (from Firefox and Chrome running on the same PC) and I reduced the DWC polling interval to 100ms.
@dc42 said in Random Hard Fault resets on Duet 3 Mini WiFi:
Hmm ok, in that case my machine is either really good behaved or I've setup something wrong
- Installed the 3.6-debug fw.
- Hooked a computer with USB.
- Installed the newest YAT from sourceforge.
- Connected it to the printer (tested by sending G28 in the termnial and the printer homed).
- After testing connection I sent
M111 P8 S1
through YAT. - Opened three instances(not three tabs, if thats any difference) or DWC in chrome + one instance of OrcaSlicer on one pc, plus i check in on my phone every once i a while too.
It's now been sitting for roughly 22 hours without anything happening. No output in YAT, and no reboot/reset.
@Exerqtor Did you...
I think DC42 said he had two DWC instances running (in different browsers).
@gloomyandy Added that info to the previous post
@Exerqtor have you ever had one of these resets since you upgraded to 3.6 beta 1?
