Unexpected M568 Results
If tool 1 is active but turned off and M568 sets temperatures for tool 0 and turns it off, then a T0 command activates tool 0, tool 1 unexpectedly goes to standby rather than staying off. This seems like logical behavior if tool 1 was active, but not if it's off. I assume it's based on tool 1 being "active" despite being turned off, because it was the last one activated.
T1 ; Activate tool 1 M568 P1 A0 ; Tool 1 heater off M568 P0 R145 S245 A0 ; Set tool 0 temps to 145 & 245, heater off T0 ; Activate tool 0
@DonStauffer I guess there are default values for standby temperature?
You'd have to overwrite it to "0" in your tool1 definition to be off or explicitly do that in the toolchange macros. -
@DonStauffer said in Unexpected M568 Results:
That's correct. Currently, when a tool is freed, RRF always put it into standby. There is perhaps a case for not doing this if the tool was off.
@dc42 I can work around it. It just took me a while to figure out what was happening. I ended up with 2 tools heating at the same time unexpectedly.
