Wiring a Duet 3 Scanning Z-Probe v1.0 to a Toolboard v1.3
@WOPR73 you can't connect the can connections of the SZP to the io connection on the tool board. They need to connect to CAN, either from the tool board or back to the distribution board
@WOPR73 If you are only using one toolboard and and one SZP with the SZP on the same toolhead as the toolboard then jay has already provided the best solution for wiring them together. The can bus runs as described above: Mainboard -> 1LC->1LC->SZP and terminate at the SZP.
If you intend to have more CAN boards then you may wish to use the distribution board but things get a little more complex. You will need to loop the CAN bus out to the 1LC (so four wires plus power) then take a spur (or drop) from the CAN bus at the 1LC to the SZP. Do not install any terminators on either the 1LC or SZP.
If you want an all in one solution then take a look at the roto toolboard (which in effect combines a 1LC with SZP). There are also other (3rd party) CAN-RD toolboards that also combine a toolboard with SZP in different form factors. See: https://forum.duet3d.com/topic/35357/rrf-compatible-stealthburner-can-fd-board-finally-released?_=1712991999323
This post is deleted! -
@gloomyandy Thank you for the information. I am not that great at wiring things at my age... But, I will take a closer look at the possible replacement for the probe and maybe tool board by the looks of it. Just was hoping to stay with all Duet on this build. But, it seems that is not possible due to design oversight. Thanks for the link.
@jay_s_uk Yeah, thanks. I figured that would be the case. Running a bunch of CAN wires from the hotend seems like such a waste. One for the Toolboard and another for the Z-Probe. I hope that will be it... because the lack of my due diligence seems to be costing me in the end. Welp! I guess I will have to either run multiple CAN lines to the distribution board or just configure an inductive probe and attach that to the tool board... and on a 500x500mm heat bed that will take a while. lol Well thank you for your help it means a lot.
@WOPR73 yeah, the toolboard only has the "in" if you will for the CAN to control the rest of the items connected to it. the board doesnt have an "out" for additional CAN connections. The distribution board does have 3 more CAN connections. So, there is that if you do not mind running multiple CAN wires from the same location back to the distro board.
@WOPR73 You do not need to run multiple CAN wires to the toolhead nor do you need to replace the boards you already have. Please re-read the posts above. The solution provided by jay offers the simplest solution and requires just 4 wires (two CAN wires plus power) from your mainboard to the 1LC and then four wires from the 1LC to the SZP.
The second solution I provided will require the standard distribution board wiring to the 1LC (so 4 CAN wires in a loop plus power) then an additional 4 wires (two can plus power) wires to the SZP the CAN wires to the SZP would be spliced on to the CAN wires close to the 1LC.
I don't have access to a drawing program at the moment to provide a diagram of the above, perhams some that does can provide something that will help explain the proposed solutions.
@WOPR73 said in Wiring a Duet 3 Scanning Z-Probe v1.0 to a Toolboard v1.3:
The 1LC toolboard has two pairs of can wires to allow the CANBUS to be looped through it
<img src="blob:chrome-untrusted://media-app/4cf83316-03f3-41a1-8da0-dcd169dcd8fb" alt="Screenshot 2024-04-13 08.46.42.png"/>
These can also be used as described by Jay above to connect to the SZP board.
@gloomyandy So if I understand this correctly. From the Distribution Board run CAN and Power to the 1LC, But only use 1) CAN_L and 2) CAN_H to control the 1LC. Then use 3) CAN_L and 4) CAN_H from the Distribution Board for connecting to the SZP and pull +v5 and GND from the 1LC. Correct? Is this because 3) CAN_L and 4) CAN_H are not use due to 1LC not having a CAN_OUT?
No, like this.
- From the distribution board run a single pair of CAN wires from CAN1_L and CAN1_H (see https://docs.duet3d.com/duet_boards/duet_3_can_expansion/duet_3_tool_distribution_board_v0.5_wiring.png) to one pair of the the tool board CAN_L and CAN_H connections
- Connect the other pair of tool board CAN_L and CAN_H connections to the CAN_L and CAN_H connections of the SZP
- Connect +5V and GND of the tool board IO0 connector to +5V and GND on the SZP.
- Make sure that the termination resistor is enabled on the SZP, and disabled on the tool board.
@dc42 Does the OP need to remove the optional terminator from the distribution board in this configuration?
@gloomyandy the CAN bus won't proceed beyond the first of the four tool outputs on the distribution board if it is wired like this, so it doesn't matter whether the termination jumper is fitted or not,
@dc42 So, I can do all of this from Tool 0 CAN-FD on the distro board(remove jumpers). I am just splitting the two pairs of CAN, One to the Toolboard and the other pair to SZP.
@WOPR73 yes that's correct. The CAN bus will run from the main board to the distribution board, from that to the tool board, and from the tool board to the SZP. It will be terminated with 120 ohm resistors at both ends i.e. at the Duet 3 Mini and the SZP.
@WOPR73 wait. what? 120 ohm resistors at both ends? Duet 3 mini? Mini what?
@WOPR73 I think you have a 6HC, not a Mini 5+. The mainboard has built in 120ohm resistor for termination, so you don't have to worry about terminating that end. At the other end of the CAN bus, the SZP provides the termination.
@droftarts yeah, I have a 6HC. I bought the distribution board after I saw that in one of the documents stating I would have to use a resistor in able to connect them. One would think that Duet would have some kind of unified standard of conformity for the connection between components that they have created. I am new to wiring up my own 3D printer and have to research a lot of this stuff to make sure I don't make a mistake. This is by no means close to plug-and-play. Welp, lesson learned I guess.
The Tool Distribution Board came with 4 premade CAN wires. I am not sure what would be easier or cleaner.
- Using 2 premade CAN wires running back to the Tool Distribution board. One from the SZP and the other one from the 1LC, both being plugged in at the Distribution board.
or - trying to undo one pair of the wires on the 1LC CAN connection and run it to the SZP.
Would have been nice to just have a CAN out on the 1LC. Either way I still need to take the 5v+ and GND from the tool board so it wont be clean looking. I really wish I would have seen this coming.
Any thoughts?
@dc42 Sorry, But I have a 6HC and a Tool Distribution board. So, I should not need the resistor. With splitting the CAN pair from the Distribution board and one pair going to the 1LC and the other pair going to the SZP. Still unable to M115 or M122 to either. And yes I do have the jumper removed on the distribution board. Using the same connection on the 24v power supply that is being used on the 6HC. Then running power from the distribution board to the 1LC and a blue light is on. But, no response.
4/25/2024, 10:41:36 PM M122 B121
CAN response timeout: board 121, req type 6024, RID 84/25/2024, 10:41:11 PM M115 B121
CAN response timeout: board 121, req type 6024, RID 7i've tried B20, B21 B10, etc; as referred to in some of the duet documents. I went back to the basics and I'm just using the 6HC, Tool Distribution Board and 1LC with supplied CAN cables that came with the Tool Distribution Board. Plus a default config from the RFF config tool.
I was able to upgrade to latest:
Duet Web Control 3.5.1
Panel Due 7i 3.4.1 -
Can you share some photos of your wiring setup?
