Accelerometer not found.
Got a "new" duet accelerometer from Oozenest.. version 0.2 (which i think is actually the old version) dead too. No LED nothing (with the provided cable) but yet I can plug in a generic accelerometer and it works and detects it fine.
That's quite strange. Can you send some photos of your setup?
@Phaedrux Will do ill take some later. Its an e3d tool changer and im plugging it into the main board with the supplied cable. As I said before I managed to get a no brand accelerometer to work by using the same supplied duet 3d cable then just branching off some duponts. But when I try to plug either duet 3d accelerometer into the cable nothing happens no lights, and a message saying it cannot find the accelerometer
Ill take some pics and upload them later.
@Festivejelly you need to be running 3.5RC1 (I think) or later for the new accelerometer too
Hello all, I am having the same issue. I have done everything above. I have a green light thought. Tried it on both Duet 2 wifi and Duex 5. I've also tried a 1k resistor, different cable same length and shorter about 12" and still not found.
@myersm1234 Best to start a new thread for your issue.
Will do. Thanks
@Festivejelly Can you confirm what firmware version you are using? Please send M115 in the console and paste the response. If you are still on 3.4.5, neither a v0.2 nor v1.0 accelerometer will work. Thought the lack of green power LED does indicate it's not getting power.
@Festivejelly Can you have a look at the tests I posted here https://forum.duet3d.com/post/337624, and see if it helps? Otherwise, I think a(nother) warranty replacement is in order.
If so, please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@droftarts Its 3.4.6 i notice 3.5 was release today so ill upgrade to that to see if that helps. Ill also try your tests.
@Festivejelly Have you made any progress on getting your accelerometer connected? Do you have a PanelDue connected? If so, are you using both cables (ie ribbon and 4-wire)? @myersm1234 found in his thread https://forum.duet3d.com/topic/35460/accelerometer-not-found-on-specified-port/33 that disconnecting the PanelDue ribbon cable fixed it for him, though I was not able to replicate the problem in my bench setup.
