1LC toolboard doesn´t connect to Duet 3 6HC
Can you test the boards together on a test bench outside of the machine with short cables?
@Phaedrux
I rewired all the can bus thing, and disconnected anything else from the two boards, and nothing happened, it only shows a blue VIN led. I reinstalled the firmware, but one thing, how I have to install the firmware? I installed it with the SD card which has all the files of the configurator, excepting the .json, including the 3 .bin, I think that the 1LC is not doing nothing, it doesn’t flash. -
@Panachampu if it shows only a blue LED with everything except CAN and power disconnected, then there is no 5V power on the board (there is a red LED to indicate 5V power). Please email warranty@duet3d.com with a link to this thread.
It now works, I connected the power from the 24V power source and it now works, thanks to everyone. I have another question, the hotend doesn’t work, after clicking on dwc to activate it, it shows an error: Heater 1 fault: monitor 0 was triggered -
@Panachampu please share your config.g file.
@Panachampu
I also have a problem with the limit switches. They make short circuit -
@Panachampu if the limit switches are shorting +3.3V or +5V to ground then they are wired incorrectly. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops.
@Panachampu I don't see anything wrong with your tool heater configuration in config.g. Heater 1 monitor 0 is set to 280C in the M143 H1 command, so it will trigger when that temperature higher than that is reported.
Please check the following:
- Does the hot end temperature read sensibly, i.e. room temperature when the hot end is cold, rising when you turn the heater on?
- As it heats up, does the temperature reading rise smoothly, or are there spikes in the temperature reading? Look at the temperature graph in DWC to check.
- Is the heater fault reported after the desired temperature has been reached and overshot, or earlier than that?
@dc42 Hello, when I tell DWC to heat up the hotend, the heater turns on and two seconds after that it shows the fail
undefined Phaedrux marked this topic as a question
