Slow Upload speeds using Web Interface
@MCRikki upload it to system
@Phaedrux Replaced the SD Card and still having the same issue. Went with a Class 10 card. The weird part is that downloads are going at a normal speed (about 200kb/s). And when I try to push an upload to it, it starts around 150kb/s, and then just tanks down to about 12kb/s. It has a good connection to the access point, as the AP is right next to it.
To eliminate the access point as a possible issue, can you test the Duet in Access Point mode, where it creates its own network that you connect to directly?
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
@MCRikki to see whether the network speed or the SD card writing speed is the problem, run these tests:
Send M122 P104 to test the SD card write speed. You can if you wish add another parameter to specify the file size.
Take a copy of one of your large GCode files, rename it to end with ".dummy" and upload it, looking at the reported upload speed just before it completes. The file will be uploaded to the Duet but not written to the SD card.
I'm having the same problem, duet 2wifi, it's been going on for a long time and I've tried a lot of things to no avail, so I saw your reply here today so I thought I'd ask again. I prepared a 12mb file and changed it to .dummy and on the first two seconds the upload speed was 200kb/s then immediately went to 10kb/s then to 1-2kb/s. I've changed many class 10 memory cards and all new ones from sandisk, every time the same upload speed is only 1kb/s and the motherboard is right next to my router 0.5m with no cover in between. I've tried many versions of firmware and flashed the motherboard but still have the problem.m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
Board ID: 0JD0M-9P61A-J8PS8-6JTD6-3SJ6L-TUSGU
Used output buffers: 3 of 24 (13 max)
Static ram: 23876
Dynamic ram: 75820 of which 12 recycled
Never used RAM 14708, free system stack 176 words
Tasks: NETWORK(notifyWait,14.0%,244) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,85.8%,413) IDLE(ready,0.1%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:12:17 ago, cause: power up
Last software reset at 2024-02-25 23:34, reason: User, GCodes spinning, available RAM 14708, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 32.7, current 39.2, max 39.7
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0, standstill, SG min/max not available
Driver 6: position 0, standstill, SG min/max not available
Driver 7: position 0, standstill, SG min/max not available
Driver 8: position 0, standstill, SG min/max not available
Driver 9: position 0, standstill, SG min/max not available
Driver 10: position 0
Driver 11: position 0
Date/time: 2024-02-26 18:39:18
Slowest loop: 8.41ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.9ms, write time 6.7ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== DueX ===
Read count 1, 0.08 reads/min
=== Network ===
Slowest loop: 72.81ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.21RC2
WiFi MAC address 10:5:eyeglasses: ..........
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 12168
WiFi IP address 192.16 ........
WiFi signal strength -43dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
Socket states: 4 0 0 0 0 0 0 0
m122 P104
2024/2/26 18:41:13 SD read speed for 10.0Mbyte file was 1.42Mbytes/sec
2024/2/26 18:41:05 SD write speed for 10.0Mbyte file was 3.33Mbytes/sec
Testing SD card read speed...
2024/2/26 18:41:03 m122 P104
Testing SD card write speed...If you need any more information please talk to me, I would very much like you to help me with this long-standing problem. Thank you!
- WiFi -
@Yapeng maybe update the RRF and WiFi firmware versions to the latest ones. 3.3 and 1.21 are old now
@jay_s_uk
Thanks so much for the advice, I've upgraded but the problem persists!
I also tried uploading a gcode file of less than 1mb, and although the speed was still only 1kb/s, I found that when it showed uploading to 100%, it started uploading from 1% again and by then the speed had dropped to 500b/s. Then after a few tens of seconds it showed that the upload had failed! I have not been able to use my printer for a long time because this motherboard has not been able to upload my files, It used to work fine and to my great satisfaction, I don't know why all of a sudden it started not uploading files!m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later + DueX5
Used output buffers: 1 of 26 (12 max)
Static ram: 23896
Dynamic ram: 75728 of which 144 recycled
Never used RAM 12312, free system stack 184 words
Tasks: NETWORK(ready,12.1%,246) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,408) IDLE(ready,2.7%,30), total 100.0%
Last reset 00:00:27 ago, cause: software
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 39.1, current 39.9, max 40.1
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7: standstill, SG min n/a
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2024-02-26 19:00:21
Cache data hit count 991818318
Slowest loop: 6.39ms; fastest: 0.18ms
=== Storage ===
SD card longest read time 2.3ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Code queue is empty
=== DueX ===
Read count 1, 2.20 reads/min
=== Network ===
Slowest loop: 62.05ms; fastest: 0.00ms
= WiFi =
Interface state: active
Module is connected to access point
WiFi firmware version 1.27
WiFi flash size 4194304, free heap 21976
WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
@Yapeng check your SD card for free space and possibly other problems: see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
If in doubt, replace the SD card for a higher performance one. See our recommendation here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#specification
@droftarts thanks, I've changed many class 10 memory cards and all new ones from sandisk, every time the same upload speed is only 1kb/s and the motherboard is right next to my router 0.5m with no cover in between. I've tried many versions of firmware and flashed the motherboard but still have the problem.
@Yapeng the slow upload when you change the file extension to .dummy indicates that the issue is nothing to do with the SD card.
My guess is that there is an incompatibility between WiFi module on the Duet and your WiFi router/access point. Here are some things you can try:
- Try upgrading the WiFi module firmware to 2.1beta6 from https://github.com/Duet3D/WiFiSocketServerRTOS/releases/tag/2.1beta6
- Try a different router/access point
- Check which channel your router/access point is using. You router WiFi configuration or status page may tell you, if it doesn't then use a WiFi scanner app on a smartphone. If it's operating on channel 1 then change it to a different channel, e.g. 7 or 11.
