3.5.0rc1: Input shaping causes layer shifts!?
@oliof thanks. Can you try a print with IS enabled and PA disabled? I'm interested n the "min interval" field in the Move section, but currently the combination of IS and PA causes this value to be wrong for extruders. I'd like to see what this value is when that interaction isn't present.
@dc42 Will do that tomorrow.
Here goes
M122 === Diagnostics === RepRapFirmware for STM32H7 based Boards (fly_super5_h723) version 3.5.0-rc.3+102 (2024-02-05 10:38:45) running on STM32H723 (standalone mode) Board ID: V1001-042KA-D43WN-6R1DU-YF6XX-70000 Used output buffers: 3 of 40 (29 max) === RTOS === Static ram: 44872 Dynamic ram: 100024 of which 0 recycled Never used RAM 98056, free system stack 102 words Tasks: NETWORK(2,nWait 7,10.7%,197) HEAT(3,nWait 1,0.0%,321) Move(4,nWait 6,1.4%,247) CanReceiv(6,nWait 1,0.0%,427) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,331) TMC22xx(4,delaying,0.7%,113) FSWRITE(2,nWait 4,0.0%,508) MAIN(1,running,86.7%,1094) IDLE(0,ready,0.4%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:20:59 ago, cause: power on/off Last software reset at 2024-02-08 19:58, reason: User, Gcodes spinning, available RAM 109544, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04454000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU temperature: min 38.2, current 39.2, max 39.3 Supply voltage: min 23.9, current 24.3, max 24.4, under voltage events: 1, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/188/188, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill 2209, SG min 2, reads 19879, writes 2 Driver 1: standstill 2209, SG min 14, reads 19879, writes 2 Driver 2: standstill 2209, SG min 4, reads 19880, writes 2 Driver 3: standstill 2209, SG min 0, reads 19880, writes 2 Driver 4: Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Driver 12: Driver 13: Date/time: 2024-02-09 10:43:20 Slowest loop: 211.78ms; fastest: 0.02ms === Storage === Free file entries: 20 SD card 0 detected SD card longest read time 1.6ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 51, maxWait 1582ms, bed compensation in use: mesh, height map offset 0.014, max steps late 1, min interval -3183, bad calcs 0, ebfmin -0.91, ebfmax 1.00 no step interrupt scheduled Moves shaped first try 174, on retry 19, too short 924, wrong shape 16866, maybepossible 250 === DDARing 0 === Scheduled moves 20612, completed 20612, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 2148, received 0, lost 0, errs 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0 free buffers 50 (min 50), ts 1193/0/0 Tx timeouts 0,0,1193,0,0,955 last cancelled message type 0 dest 1 === Network === Slowest loop: 202.51ms; fastest: 0.07ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) HTTP sessions: 1 of 8 Uploads/Errors: 0/0 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Bad header: 0/0 Firmware version 2.1beta6-01 MAC address 54:43:b2:4a:17:90 Module reset reason: Power up, Vcc 0.00, flash size 4194304, free heap 184580 WiFi IP address 192.168.86.46 Signal strength -55dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00003043 Socket states: 0 0 0 0 0 0 0 0
Note that with more appropriate current setting for the motor, I don't observe any layershifts anymore.
@NeoDue @oliof please try the new firmware at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0. This fixes the interaction between extruder PA and IS.
If you get any layer shifts or hear any strange noises (e.g. bangs) from the motion motors, please run M122 and post the report here. Note, each time you run M122 it clears the accumulated debug data after reporting it, so only the first M122 report taken after a layer shift or strange noises contains useful data - although of course if you get another layer shift or strange noises after running M122 then you can run M122 again to report data relevant to those events.
@dc42 I will do so next weekend, unfortunately no play time beforehand.
@dc42 Great! I hope I can manage to test tomorrow or wednesday!
@dc42 I'm still getting layer shifts.
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-12 16:39:08) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6J1F8-3S06Q-1U86S Used output buffers: 9 of 40 (40 max) === RTOS === Static ram: 155208 Dynamic ram: 124316 of which 592 recycled Never used RAM 62228, free system stack 132 words Tasks: NETWORK(1,ready,138.6%,172) ETHERNET(5,nWait 7,0.3%,117) ACCEL(6,nWait 6,0.0%,344) HEAT(3,nWait 1,0.2%,321) Move(4,nWait 6,10.1%,218) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.1%,334) TMC(4,nWait 6,49.4%,54) MAIN(1,running,291.4%,103) IDLE(0,ready,0.5%,30), total 490.5% Owned mutexes: === Platform === Last reset 01:59:53 ago, cause: software Last software reset at 2024-02-12 18:35, reason: User, Gcodes spinning, available RAM 62948, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 33.2, current 34.3, max 35.2 Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.7, current 12.1, max 12.7, under voltage events: 0 Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/56/32, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, mspos 516, reads 45133, writes 19 timeouts 0 Driver 1: ok, SG min 0, mspos 632, reads 45133, writes 19 timeouts 0 Driver 2: ok, SG min 0, mspos 913, reads 45134, writes 19 timeouts 0 Driver 3: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Driver 4: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Driver 5: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Date/time: 2024-02-12 20:35:21 Slowest loop: 235.39ms; fastest: 0.05ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 19.1ms, write time 12.9ms, max retries 0 === Move === DMs created 125, segments created 33, maxWait 279212ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval -1929, bad calcs 0, ebfmin -1.00, ebfmax 1.00 next step interrupt due in 7 ticks, disabled Moves shaped first try 11539, on retry 6730, too short 23478, wrong shape 45756, maybepossible 2855 === DDARing 0 === Scheduled moves 101367, completed 101335, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.3 Heater 2 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X164.421 Y253.435 E.11265" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 64737, received 0, lost 0, errs 34184089, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 35966/0/0 Tx timeouts 0,0,35965,0,0,28770 last cancelled message type 30 dest 127 === Network === Slowest loop: 216.55ms; fastest: 0.03ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 3 of 8 = Ethernet = Interface state: active Error counts: 0 0 11 1 0 0 Socket states: 5 2 2 2 2 0 0 0 === WiFi === Interface state: disabled Module is disabled Failed messages: pending 0, notrdy 0, noresp 0 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0 2/12/2024, 8:35:23 PM m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-12 16:39:08) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6J1F8-3S06Q-1U86S Used output buffers: 9 of 40 (40 max) === RTOS === Static ram: 155208 Dynamic ram: 124316 of which 592 recycled Never used RAM 62228, free system stack 132 words Tasks: NETWORK(1,ready,138.6%,172) ETHERNET(5,nWait 7,0.3%,117) ACCEL(6,nWait 6,0.0%,344) HEAT(3,nWait 1,0.2%,321) Move(4,nWait 6,10.1%,218) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.1%,334) TMC(4,nWait 6,49.4%,54) MAIN(1,running,291.4%,103) IDLE(0,ready,0.5%,30), total 490.5% Owned mutexes: === Platform === Last reset 01:59:53 ago, cause: software Last software reset at 2024-02-12 18:35, reason: User, Gcodes spinning, available RAM 62948, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 33.2, current 34.3, max 35.2 Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.7, current 12.1, max 12.7, under voltage events: 0 Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/56/32, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, mspos 516, reads 45133, writes 19 timeouts 0 Driver 1: ok, SG min 0, mspos 632, reads 45133, writes 19 timeouts 0 Driver 2: ok, SG min 0, mspos 913, reads 45134, writes 19 timeouts 0 Driver 3: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Driver 4: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Driver 5: ok, SG min 0, mspos 1000, reads 45134, writes 19 timeouts 0 Date/time: 2024-02-12 20:35:21 Slowest loop: 235.39ms; fastest: 0.05ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 19.1ms, write time 12.9ms, max retries 0 === Move === DMs created 125, segments created 33, maxWait 279212ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval -1929, bad calcs 0, ebfmin -1.00, ebfmax 1.00 next step interrupt due in 7 ticks, disabled Moves shaped first try 11539, on retry 6730, too short 23478, wrong shape 45756, maybepossible 2855 === DDARing 0 === Scheduled moves 101367, completed 101335, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.3 Heater 2 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X164.421 Y253.435 E.11265" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 64737, received 0, lost 0, errs 34184089, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 35966/0/0 Tx timeouts 0,0,35965,0,0,28770 last cancelled message type 30 dest 127 === Network === Slowest loop: 216.55ms; fastest: 0.03ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 3 of 8 = Ethernet = Interface state: active Error counts: 0 0 11 1 0 0 Socket states: 5 2 2 2 2 0 0 0 === WiFi === Interface state: disabled Module is disabled Failed messages: pending 0, notrdy 0, noresp 0 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
@adrian thanks. Your M122 report contains useful data. Please can you share your config.g file and any other macros it calls, daemon.g if you.use it, and the print file. Also the approximate height at which the first layer shift occurs.
@NeoDue @oliof @adrian I have identified and corrected another step timing anomaly. Please try the updated files at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
As before, if you get any layer shifts or hear any strange noises (e.g. bangs) from the motion motors, please run M122 and post the report here. Note, each time you run M122 it clears the accumulated debug data after reporting it, so only the first M122 report taken after a layer shift or strange noises contains useful data - although of course if you get another layer shift or strange noises after running M122 then you can run M122 again to report data relevant to those events.
@dc42 I am afraid your last changes might have made things worse: one slight "bang" noise already layer 3, and layer shift at height 1.4mm.
The test part is the same as in my previous tests.
Here is the M122 readout of the bang:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-13 13:34:06) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6JTDL-3SN6L-998UU Used output buffers: 3 of 40 (33 max) === RTOS === Static ram: 155208 Dynamic ram: 123408 of which 0 recycled Never used RAM 63896, free system stack 134 words Tasks: NETWORK(2,nWait 7,16.3%,172) HEAT(3,nWait 1,0.0%,323) Move(4,nWait 6,2.2%,227) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,9.5%,56) MAIN(1,running,70.6%,103) IDLE(0,ready,1.3%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:15:37 ago, cause: software Last software reset at 2024-02-13 18:34, reason: User, Gcodes spinning, available RAM 64248, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 36.5, current 43.8, max 44.0 Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.3, max 12.7, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/1612/1560, gc cycles 2 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, mspos 623, reads 19231, writes 29 timeouts 0 Driver 1: standstill, SG min 0, mspos 232, reads 19231, writes 29 timeouts 0 Driver 2: standstill, SG min 0, mspos 424, reads 19238, writes 23 timeouts 0 Driver 3: ok, SG min 0, mspos 840, reads 19238, writes 23 timeouts 0 Driver 4: standstill, SG min 0, mspos 746, reads 19242, writes 19 timeouts 0 Driver 5: ok, SG min 0, mspos 46, reads 19242, writes 19 timeouts 0 Date/time: 2024-02-13 18:49:49 Slowest loop: 212.35ms; fastest: 0.05ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 5.1ms, write time 2.7ms, max retries 0 === Move === DMs created 125, segments created 26, maxWait 145311ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00 next step interrupt due in 480 ticks, disabled Moves shaped first try 6, on retry 81, too short 745, wrong shape 6305, maybepossible 347 === DDARing 0 === Scheduled moves 24526, completed 24466, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.3 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 3 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 15, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 10347352 clear 326009 Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 8429, received 0, lost 0, errs 4443556, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 4686/0/0 Tx timeouts 0,0,4685,0,0,3742 last cancelled message type 30 dest 127 === Network === Slowest loop: 11.99ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = Interface state: disabled Error counts: 0 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address 70:04:1d:be:ad:b8 Module reset reason: Power up, Vcc 0.00, flash size 4194304, free heap 225152 WiFi IP address 192.168.178.31 Signal strength -57dBm, channel 2, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
And this is the one taken after the layer shift occurred:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-13 13:34:06) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6JTDL-3SN6L-998UU Used output buffers: 5 of 40 (35 max) === RTOS === Static ram: 155208 Dynamic ram: 123408 of which 0 recycled Never used RAM 63896, free system stack 134 words Tasks: NETWORK(2,nWait 7,16.5%,172) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,3.2%,227) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,9.7%,56) MAIN(1,running,70.5%,103) IDLE(0,ready,0.1%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:23:52 ago, cause: software Last software reset at 2024-02-13 18:34, reason: User, Gcodes spinning, available RAM 64248, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 43.7, current 45.1, max 45.6 Supply voltage: min 23.6, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.3, max 12.7, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/628/576, gc cycles 4 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 296, reads 39704, writes 0 timeouts 0 Driver 1: standstill, SG min n/a, mspos 232, reads 39705, writes 0 timeouts 0 Driver 2: standstill, SG min 0, mspos 936, reads 39704, writes 0 timeouts 0 Driver 3: ok, SG min 0, mspos 532, reads 39704, writes 0 timeouts 0 Driver 4: standstill, SG min n/a, mspos 746, reads 39704, writes 0 timeouts 0 Driver 5: ok, SG min 0, mspos 178, reads 39704, writes 0 timeouts 0 Date/time: 2024-02-13 18:58:05 Slowest loop: 6.91ms; fastest: 0.07ms === Storage === Free file entries: 17 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 5.2ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 26, maxWait 226ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00 next step interrupt due in 143 ticks, disabled Moves shaped first try 2, on retry 108, too short 1478, wrong shape 13289, maybepossible 867 === DDARing 0 === Scheduled moves 42846, completed 42786, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.3 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 3 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 30, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 15731742 clear 326009 Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 4463, received 0, lost 0, errs 2356269, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2479/0/0 Tx timeouts 0,0,2479,0,0,1984 last cancelled message type 4514 dest 127 === Network === Slowest loop: 20.79ms; fastest: 0.07ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = Interface state: disabled Error counts: 0 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address 70:04:1d:be:ad:b8 Module reset reason: Power up, Vcc 0.00, flash size 4194304, free heap 225152 WiFi IP address 192.168.178.31 Signal strength -59dBm, channel 2, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
@dc42 Out of curiosity, I also tested what @oliof mentioned. Increasing currents to the maximum did not change anything either, however, layer shift at 1.75mm:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-13 13:34:06) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6JTDL-3SN6L-998UU Used output buffers: 7 of 40 (32 max) === RTOS === Static ram: 155208 Dynamic ram: 123544 of which 0 recycled Never used RAM 63760, free system stack 128 words Tasks: NETWORK(2,nWait 7,16.0%,172) HEAT(3,nWait 1,0.0%,323) Move(4,nWait 6,2.9%,239) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,9.7%,56) MAIN(1,running,70.1%,103) IDLE(0,ready,1.2%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:22:55 ago, cause: software Last software reset at 2024-02-13 19:10, reason: User, Gcodes spinning, available RAM 64672, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 43.9, current 46.4, max 46.6 Supply voltage: min 23.6, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.3, max 12.6, under voltage events: 0 Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/248/196, gc cycles 4 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, mspos 750, reads 57987, writes 27 timeouts 0 Driver 1: standstill, SG min 0, mspos 264, reads 57987, writes 27 timeouts 0 Driver 2: standstill, SG min 0, mspos 504, reads 57991, writes 23 timeouts 0 Driver 3: stalled, SG min 0, mspos 53, reads 57989, writes 25 timeouts 0 Driver 4: standstill, SG min 0, mspos 466, reads 57995, writes 19 timeouts 0 Driver 5: ok, SG min 0, mspos 238, reads 57996, writes 19 timeouts 0 Date/time: 2024-02-13 19:33:15 Slowest loop: 816.19ms; fastest: 0.05ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 4.3ms, write time 102.7ms, max retries 0 === Move === DMs created 125, segments created 26, maxWait 117938ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00 next step interrupt due in 64 ticks, disabled Moves shaped first try 7, on retry 280, too short 2460, wrong shape 21310, maybepossible 1427 === DDARing 0 === Scheduled moves 45790, completed 45740, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.4 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 3 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 10, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 14945236 clear 310047 Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 12375, received 0, lost 0, errs 6525776, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 6878/0/0 Tx timeouts 0,0,6877,0,0,5496 last cancelled message type 4514 dest 127 === Network === Slowest loop: 784.06ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = Interface state: disabled Error counts: 0 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address 70:04:1d:be:ad:b8 Module reset reason: Power up, Vcc 0.00, flash size 4194304, free heap 220536 WiFi IP address 192.168.178.31 Signal strength -59dBm, channel 2, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
But I also tried a print where I switched between IS on and off every couple of layers - and I finally could see one of the blobs you were talking about. I could directly turn blob occurrance (and therefore rumbling on the next layer) and off by switching between IS on and IS off.
Edit: In case it matters: the "test-blob" I found occurs on layer 2, 4 and 6 in the middle of the last line of the solid infill of my test part. Prusaslicer decided in its wisdom to split this line into two long pieces which are connected by two very short ones. This is the gcode that causes the blob:
; (tool position before this snippet begins: X-7.877 Y28.826) G1 X-7.823 Y28.723 E.00266 G1 X-7.815 Y-7.037 E.75823 G1 X-7.867 Y-7.142 E.00277 G1 X-7.919 Y-7.246 E.00303 G1 X-7.922 Y-42.252 E.91196
@dc42 Here is my config
; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.1+1 on Mon Dec 11 2023 18:26:16 GMT-0600 (Central Standard Time) ; General M550 P"SeaMonster" ; set hostname ; Accessories M575 P1 S0 B57600 ; configure PanelDue support ; Network M552 P0.0.0.0 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP ; LED Strips M950 E0 C"led" T2 U3 ; LEDs on SB Toolhead (3) (LED 0) M950 E1 C"io7.out" T2 U25 ; Left Overhead LEDs (25) (LED 1) M950 E2 C"io8.out" T2 U25 ; Right Overhead LEDs (25) (LED 2) ; ====================--------------------------------------------------------- ; Driver config ; ==================== ; --- Drive map --- ; (While looking at the printer top down) ; B A ; 0.0-----0.1 ; | 0.5 | ; |-------| ; |0.3|0.4| ; ---+--- ; Front ; Smart Drivers M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis) M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S0 D2 ; driver 0.2 goes backwards (extruder 0) M569 P0.3 S0 D2 ; driver 0.3 goes backwards (Z axis) (Front Leftt) M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Z axis) (Front Right) M569 P0.5 S0 D2 ; driver 0.5 goes backwards (Z axis) (Rear Center) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1 Z0.3:0.5:0.4 ; set axis mapping (Front Left, Rear Center, Front Right) M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X1500 Y1500 Z1200 ; set axis driver currents (xy1300) M92 X160 Y160 Z800 ; configure steps per mm M208 S1 X13 Y-5 Z0 ; set axis minima M208 S0 X350 Y350 Z215 ; set axis maxima M566 X720 Y720 Z30 ; set maximum instantaneous speed changes (mm/min) (700) M203 X36000 Y36000 Z900 ; set maximum speeds (mm/min) (X9000 Y9000 Z900) M201 X6000 Y6000 Z150 ; set accelerations (mm/s^2) (X6000 Y6000) ; Extruders M584 E0.2 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E724.1379 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E7200 ; set maximum speeds (mm/min) (3600) M201 E2000 ; set accelerations (mm/s^2) (250) ; Kinematics M669 K1 ; configure CoreXY kinematics ; Bed Level M671 X-35:175:390 Y3:420:3 S10;S0.5 ; position of leadscrew/bed pivot point at front left, rear middle and front right ; Probes M558 P5 C"!io3.in" H10 F300 T6000 ; configure digital probe via slot #0 G31 P500 X0 Y0 Z-0.352 ;-0.269 ;-0.330 ; -0.346 ; -0.345 ; set Z probe trigger value, offset and trigger height ; Endstops M574 X2 P"io4.in" S1 ; configure X axis endstop M574 Y2 P"io5.in" S1 ; configure Y axis endstop ;M574 Z2 S2 ; configure Z axis endstop ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"temp1" Y"pt1000" A"Nozzle" ; configure sensor 1 as PT1000 on pin temp1 M308 S2 P"temp2" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8 ; configure sensor #2 ; Chamber (Fake) M950 H2 C"out4" T2 ; create a heater, but not actually anything connected to this output M141 H2 ; set this to be chamber M141 S0 ; set chamber to 0 - normal dont get too hot temperature ; Heaters M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0 M950 H1 C"out1" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"out2" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"out3" ; create fan #1 M106 P1 S0 B1.1 H1 T45 ; configure fan #1 M950 F7 C"out7" ; create fan #7 M106 P7 C"Exhaust Fan" S0 L0 X1 B0.1 ; configure fan #7 M950 F8 C"out8" ; create fan #8 M106 P8 C"Electronics 1" S0 L0 X1 B0.1 ; configure fan #8 M950 F9 C"out9" ; create fan #9 M106 P9 C"Electronics2" S0 L0 X1 B0.1 ; configure fan #9 ; Mesh Grid M557 X15:335 Y15:335 P7 ; define mesh grid 7x7 ; Accelerometer M955 P0 C"spi.cs1+spi.cs0" I56 ; configure accelerometer on board #0 ; Input Shaping ;M593 P"MZV" F37.6 S0.0 ; Taper M376 H10 ; Pressure Advance M572 D0 S0.055 ; 0.04 ; Tools M563 P0 S"StealthBurner" D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ; Miscellaneous M501 T0 ; select first tool
@NeoDue thanks for testing the latest firmware. TBH I wasn't really expecting this latest change to fix bangs and/or layer shifts, because it shouldn't directly affect axis motors. However, the anomalies reported by the "min interval" report in the Move section have disappeared in your latest M122 reports, also the ebfmin value is now zero as expected instead of -1.
I ran your compete print (without filament) on my bench system, apart from the first few layers which I had previously removed because no anomalies were detected in them. The print completed without incident. I didn't hear any bangs, but I can't say whether there were any layer shifts because the motors were not connected to axes.
I would love to have a print in which bangs always occur at the same places, because that would give me a chance to replicate the issue. However, the impression I have from the reports in this thread is that the bangs and layer shifts are somewhat random, because they don't consistently occur at the same places in the print. Would you agree?
Are you still confident that the bangs and layer shifts don't occur when IS is not enabled?
@dc42 said in 3.5.0rc1: Input shaping causes layer shifts!?:
Are you still confident that the bangs and layer shifts don't occur when IS is not enabled?Yes, to doublecheck that was the intent behind the test I mentioned in my second post today.
The blob I mentioned there seems to reliably be created with IS on even if it is obviously not large enough to create a layer shift every time. The randomness of the layer shifts (edit: except the one at 5.65mm, which seems to be reliable so far!) might indicate that these are created by such blobs as well - there are numerous occurrances of such short moves in the code file.
Edit: Maybe one more question...: let's assume my thought above is correct. On the other hand, I am confident that you dug out and eliminated all the issues of the code.
Can you think of a setting or a combination of settings that - with the RRF input shaping code working as intended - might be responsible for creating a larger blob with IS enabled for this given gcode snippet than it does with IS off? I am thinking of things like "IS changes Pressure Advance which may have such an effect on very small moves if PA is not 100% correctly calibrated" or such.
In addition, I would assume it should be something that does not happen in the Marlin implementation of IS since I did not have any of such issues prior to switching to the Duet. -
My layer shifts are in random places and directions. Mine seem like it decides randomly to turn early. -
@adrian Can you place the gcode file on a file sharing service and make it available via that?
Have you confirmed that if you print the same part with input shaping turned off (and no other changes), that you do not see any layer shifts?
@NeoDue I would like to check whether extrusion issues (blobs and similar) are responsible for the layer shifts or not. This is what I propose:
- Adapt the attached macro for your machine and test it. It measures where the homing switches are found and compares this with where they should be. It doesn't seem to work very well when using stall homing, but I am hopeful that it will work fairly well on a machine with real homing switches.
- Edit your print file if necessary to remove any homing command at the end
- Remove the filaments from your machine
- Home the printer and run this macro to check it is working as expected
- Disable your filament monitors (M591 D0 S0 M591 D1 S0)
- Run the print like that, using your usual IS and PA parameters that provoke layer shifts
- When it has finished, make sure that the print head is clear of the print, then run this macro again to check whether either X or Y has shifted.
@gloomyandy
I’ll work on getting that code shared out.It works fine without IS on.
@adrian please can you do the same test that just asked NeoDue to do, i.e. run the same print without filament and use the macro to see whether either X or Y has shiftted.
