1XD misuse to trigger an Arduino
Hello together.
Here is what i am trying to do:
I am developing a Special Tool, which is build around an Arduino taking Measurements.
To sync it up with the Motion precisely my Plan is to use a Step Signal connected to an Interrupt on the Arduino. This way i can calculate the precise location. By assigning it an Axis and setting it to 1Step/mm I can drive it from within Gcode like this to get for Example 10 measurements: G1 U10.The System is based around the CAN Bus, so it seemed obvious to get a 1XD Board for this.
However now I am not sure how I'd need to connect it.From the documentation I was under the Impression I could just use an GPIO utilizing the Arduino's Internal Pullup Resistors and connect the Pin to STEP- .
What do you think?
@theBohnanza the 1XD board has 5V differential STEP outputs with active pullup and pulldown. So you can connect it more or less directly to a 5V Arduino. If the 1XD and Arduino use different power supplies then common the grounds (i.e. negative outputs) of both power supplies, and put a series resistor of about 10K between the 1XD STEP output and the Arduino input to prevent excessive current flow when only one of them is powered.
Thank you, that's the Info I needed.
