3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2
@tas Like @gloomyandy said, just for troublesbooting purposes try setting the current high. Try with 1400milliamps just for one print and check if it makes a difference.
M906 X1400 Y1400 Z800 E300 I30;
M593 P"zvdd" F45.7 S0.0 L0.25;
Test print running now.
The test print worked perfectly.
So the Y shifts were due to a configuration error on my part. The motors do need more current to meet the demands of input shaping.
The motors got a bit hotter than I would like by the end of the print but most people would call them warm so that is interesting for me. I will bump up the current in my configs.
Thank you both for the suggestions.
@tas with input shaping enabled, do the motors sound normal? I get a slight clunking sound when some types of IS are enabled on one of my machines. However, as the IS code is being rewritten I decided not to investigate this before releasing RC2.
You might like to run M122 after doing one of these prints. It has a new field that lists the maximum number of overdue steps encountered, and that may be related.
@dc42 I can't say I noticed a noise difference but I will do some testing today and report back.
I did a test 'print' without filament using the Klipper ringing part in vase mode at 100mm/s. I tried none, zvd, zvdd, zvddd and with IS off.The noise sounded 'silkier' with IS enabled and to my ear is the same no matter which type was used.
I did not hear any clunks, clicks or other unusual noises. The highest value for max steps late was 1. I hope that is the new value you are referring to.
Using a speed of 100mm/s I tried all Input Shapers starting with IS disabled. I did M122 at random times during each 'print' to get the following info.
No IS:
M122 Move:
DMs created 83, segments created 9, maxWait 1020ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.89, ebfmax 0.98
next step interrupt due in 28 ticks, disabled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0IS "zvd":
M122 Move:
DMs created 83, segments created 22, maxWait 881ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.79, ebfmax 0.98
next step interrupt due in 6 ticks, disabled
Moves shaped first try 34, on retry 18, too short 63, wrong shape 4, maybepossible 1IS "zvdd":
M122 Move:
DMs created 83, segments created 33, maxWait 17471ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.97, ebfmax 0.99
next step interrupt due in 49 ticks, disabled
Moves shaped first try 73, on retry 25, too short 112, wrong shape 9, maybepossible 0IS "zvddd":
M122 Move:
DMs created 83, segments created 38, maxWait 2364ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.95, ebfmax 1.00
next step interrupt due in 12 ticks, disabled
Moves shaped first try 114, on retry 65, too short 189, wrong shape 20, maybepossible 0Let me know if you need any other info or other tests done and I can do them later today.
@dc42 said in 3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2:
With RC2 I get clunking bad enough that it causes layer shifts. I would get slight clunks on RC1 but RC2 is a whole other level... I'm to the point that I'm starting to try to figure out how to get back to RC1 with SBC. I can't downgrade to stable because I'm running RRF-36's. ZVD seems to be the mildest for me and ZVDDD is just plain awful.
@edsped What are your M593 settings?
@edsped
It may be an SBC issue then. I heard no clunks at all. -
@gloomyandy said in 3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2:
M593 P"ZVDDD" F60 L0.8 S0
I changed the L value because lower values cause the print head to slow down quite a bit at start and stop areas during infill.
@edsped Did you specify an L value in your RC1 settings? If so what was it? There have not been a lot of changes to IS since RC1 so it is interesting that you are having issues.
@gloomyandy I did not, was getting weird slowdowns in small areas and a little digging around led me to the L value.
@edsped I'll try lowering the L value to the default .25 and test again but it may take a couple of hours.
Reverting to default for L value solved it. Thank you!
