Reboots/crashes - RRF ≤3.5.0-rc1
@dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
@Exerqtor thanks for those. I'll have another firmware build for you to test shortly.
The corrupt data appears to be 4 characters of ASCII text. In two cases it is
=0.1
and in one case=0.6
. Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?Sounds like progress
But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print. So all the crashes has happened with the printer in an idle state (unless otherwise mentioned).
@Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/y34newtid8z5zp7qa5ted/h?rlkey=i65uvg992k74vrgygg4rp4g98&dl=0.
Ok, I'll download and install it straight away!
@Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
=0.1
and in one case=0.6
. Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?Sounds like progress😁
But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print.So all the crashes has happened with the printer in an idle state(unless otherwise mentioned).I guess what
daemon.g
is doing still applies while the printer is idle, so here is how that looks as of now (just grabbed it straight of the printer):; /sys/daemon.g v2.4 ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again. ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ ; Loop, to be able to turn on/off daemon.g while global.RunDaemon ; Stuff goes here ; Resume after filament change if exists(global.FilamentCHG) if global.FilamentCHG = true && state.status="paused" M24 ; Resume the pause automatically now that the manual filament change is done set global.FilamentCHG = false ; Refresh chamber lights status if exists(global.chamber_leds) set global.chamber_leds = state.gpOut[0].pwm * 100 ;Check sb_leds status var SB_LEDS = true ; Turn on(true) / off(false) the Stealthburner led "system" if var.SB_LEDS if fileexists("/sys/lib/led/sb_leds-state.g") M98 P"/sys/lib/led/sb_leds-state.g" ; Check if global.sb_leds has changed since last run/loop ; Print acceleration & input shaping control if global.accel_control ; Low accel on the whole first layer so that it gets good adhesion if global.layer_number = 1 M204 P500 ; Set printing acceleration(mm/s�) ; Everything else else if global.line_type = "External perimeter" if move.printingAcceleration != global.low_accel M204 P{global.low_accel} ; Set printing acceleration(mm/s�) ;if move.shaping.type != global.input_shaper ;M593 P{global.input_shaper} ; Configure input shaping elif global.line_type = "Perimeter" if move.printingAcceleration != 2000 M204 P2000 ; Set printing acceleration(mm/s�) ;if move.shaping.type != global.input_shaper ;M593 P{global.input_shaper} ; Configure input shaping elif global.line_type = "Solid infill" if move.printingAcceleration != 2000 M204 P2000 ; Set printing acceleration(mm/s�) ;if move.shaping.type != "none" ;M593 P"none" ; Configure input shaping elif global.line_type = "Top solid infill" if move.printingAcceleration != global.low_accel M204 P{global.low_accel} ; Set printing acceleration(mm/s�) ; When none of the above line extrusion types else if move.printingAcceleration != global.def_print_accel M204 P{global.def_print_accel} ; Set printing acceleration(mm/s�) ;if move.shaping.type != "none" ;M593 P"none" ; Disable input shaping ; ----------------- ; Daemon loop delay G4 S1 ; Delay running again or next command for at least 1 second
And
sb_leds-state.g
:; /sys/lib/led/sb_leds-state.g v2.0 ; Created by sb_leds.g to store the current/active LED colors ; Called by daemon.g to check if global.sb_leds status has changed since last run var sb_leds = "boot" if var.sb_leds = global.sb_leds ; Same status, do nothing else ; New status, change colors M98 P"/sys/lib/led/sb_leds.g"
And while the printer is idle
global.sb_leds
don't change value.So as far as i can see it shouldn't be any
=0.1
or=0.6
anywhere. -
First M122 report after a crash on that build (also in a idle state when crashing) :
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 11 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 122152 of which 0 recycled Never used RAM 13564, free system stack 186 words Tasks: NETWORK(1,ready,1687.6%,203) HEAT(3,nWait,2.1%,330) Move(4,nWait,0.2%,351) CanReceiv(6,nWait,4.3%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.6%,350) TMC(4,nWait,60.6%,108) MAIN(1,running,1092.0%,670) IDLE(0,ready,21.0%,29) AIN(4,delaying,73.1%,264), total 2941.7% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 04:49:41 ago, cause: software Last software reset at 2023-12-08 01:28, reason: AssertionFailed, Platform spinning, available RAM 12356, slot 2 Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001af 2002c100 20031d10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 20031d1c 00000800 20035a10 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 17381709, completed 17381709, timed out 0, errs 0 MCU temperature: min 34.2, current 34.8, max 38.2 Supply voltage: min 22.7, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/492/96, gc cycles 783 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-08 06:17:56 Cache data hit count 4294967295 Slowest loop: 12.85ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.2ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 156442, received 356364, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6042, peak Tx sync delay 275, free buffers 26 (min 25), ts 86907/86906/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 24.24ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42964 WiFi IP address 192.168.10.x Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor do you get crashes if you disable daemon.g?
@droftarts said in Reboots/crashes - RRF 3.5.0-rc1:
As in setting the global to false disable, or have a empty daemon.g?
I can try both, i just set the global to false (i'm pretty sure we tested this earlier, but it's been such a long time since this all started I have a hard time keeping up).
@Exerqtor better to have a daemon.g file with just a very long G4 command in it.
In general you mean? Or could elaborate on that a little bit?
I have alot of crap in daemon.g currently, it's mostly disabled since i ditched what i was trying to do with it. Just haven't gotten around to cleaning it up yet.
Guess i could do that now
@Exerqtor what I meant was that a daemon.g file with just a long G4 delay in it would result in less S card access than no daemon.g at all. The maximum value for a G4 delay command is about 2 million seconds.
Conversely, if you try reducing the G4 S1 delay in your current daemon.g file (e.g. try G4 P10) then this will result in more SD card reads. It would be interesting to see if that results in more frequent resets. Please try that.
Another thing you could do at the same time is to pad out the end of daemon.g with a few long comment lines something like this:
;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
This might indicate whether the data that overwrites the return address comes from the residue of the sector of daemon.g that is currently past the end of the file. The sector size is 512 bytes so the number of comment characters in total shod be at least that.
Gotcha!I just did the much needed cleanup in my daemon.g, but I've now added what you said mentioned.
This is how it looks as of now:
; /sys/daemon.g v2.5 ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again. ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ ; Loop, to be able to turn on/off daemon.g while global.RunDaemon ; Stuff goes below this line ; --------------------------------------------------------------------------- ; Resume after filament change if exists(global.FilamentCHG) if global.FilamentCHG = true && state.status="paused" M24 ; Resume the pause automatically now that the manual filament change is done set global.FilamentCHG = false ; -------------------- ; Refresh chamber lights status if exists(global.chamber_leds) set global.chamber_leds = state.gpOut[0].pwm * 100 ; -------------------- ;Check sb_leds status var SB_LEDS = true ; Turn on(true) / off(false) the Stealthburner led "system" if var.SB_LEDS if fileexists("/sys/lib/led/sb_leds-state.g") M98 P"/sys/lib/led/sb_leds-state.g" ; Check if global.sb_leds has changed since last run/loop ; --------------------------------------------------------------------------- ; Daemon loop delay G4 P10 ; Delay running again or next command for at least 1 second (was S1) ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
@Exerqtor thanks, let's see if that resets more often than before.
Only one new crash since the
daemon.g
changes was done:M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123212 of which 12 recycled Never used RAM 12492, free system stack 182 words Tasks: NETWORK(1,ready,1204.8%,209) HEAT(3,nWait,1.4%,353) Move(4,nWait,0.1%,357) CanReceiv(6,nWait,2.7%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.4%,350) TMC(4,nWait,38.1%,108) MAIN(1,running,3867.8%,670) IDLE(0,ready,269.7%,29) AIN(4,delaying,46.5%,264), total 5431.5% Owned mutexes: === Platform === Last reset 01:37:14 ago, cause: software Last software reset at 2023-12-08 18:27, reason: AssertionFailed, Gcodes spinning, available RAM 11400, slot 1 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001a7 2002c100 20031510 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 2003151c 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 5834478, completed 5834477, timed out 0, errs 0 MCU temperature: min 35.9, current 36.3, max 39.1 Supply voltage: min 22.2, current 24.1, max 26.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/27, heap memory allocated/used/recyclable 2048/1544/1192, gc cycles 11635 Events: 0 queued, 0 completed Driver 0: standstill, SG min 256, read errors 0, write errors 1, ifcnt 39, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 240, read errors 0, write errors 1, ifcnt 39, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 85, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-08 20:05:11 Cache data hit count 4294967295 Slowest loop: 12.91ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.7ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P10" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 52517, received 119640, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 278, free buffers 26 (min 25), ts 29171/29170/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 5.96ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960 WiFi IP address 192.168.10.x Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
So i guess that didn't do much
And more:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123248 of which 0 recycled Never used RAM 12468, free system stack 180 words Tasks: NETWORK(1,ready,38.7%,232) HEAT(3,nWait,0.2%,328) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.4%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.1%,350) TMC(4,nWait,6.2%,108) MAIN(1,running,2.9%,670) IDLE(0,ready,43.9%,29) AIN(4,delaying,7.6%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 08:58:00 ago, cause: software Last software reset at 2023-12-09 01:46, reason: AssertionFailed, Platform spinning, available RAM 11580, slot 2 Software reset code 0x4920 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001a7 2002c100 20030440 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 2003044c 00000800 20035988 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 32280441, completed 32280439, timed out 0, errs 0 MCU temperature: min 35.7, current 36.6, max 39.1 Supply voltage: min 22.3, current 24.1, max 26.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/26, heap memory allocated/used/recyclable 2048/1936/1596, gc cycles 64514 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 63, reads 60543, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71 Driver 1: standstill, SG min 228, read errors 0, write errors 1, ifcnt 62, reads 60541, writes 13, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x6c Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 60544, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 103, reads 60544, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 60545, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-09 10:44:02 Cache data hit count 4294967295 Slowest loop: 12.87ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.8ms, write time 4.4ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 290534, received 661804, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 344, free buffers 26 (min 25), ts 161403/161402/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 5.80ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39348 WiFi IP address 192.168.10.x Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor thanks. The text that is overwriting the return address s now "0.6<CR>". The fact that is includes a <CR> suggests that this text comes from a job file or macro file, not from RRF itself, because RRF uses <LF> as a line terminator and almost never generates <CR>.
Please can you insert command G4 S10000 at the start of daemon.g and restart, to see if it still crashes.
@Exerqtor which browser are you using, and what version? That text ""0.6<CR>" could be the end of a browser version in a HTTP header.
PS - also, what language settings do you have in your browser? That text could be the end of an Accept-Language HTTP header.
@Exerqtor one more data point please: have you always been running a 2.1beta version of DuetWiFiServer when you had these errors, or did you have them when using version 1.27 also?
Ok let's see if I'm able to answer all that somewhat effectively🤣
First off, is this what you had in mind?:
; /sys/daemon.g v2.5 ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again. ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ G4 S10000 ; As per David's instructions ; Loop, to be able to turn on/off daemon.g while global.RunDaemon ; Stuff goes below this line ; --------------------------------------------------------------------------- ; Resume after filament change if exists(global.FilamentCHG) if global.FilamentCHG = true && state.status="paused" M24 ; Resume the pause automatically now that the manual filament change is done set global.FilamentCHG = false ; -------------------- ; Refresh chamber lights status if exists(global.chamber_leds) set global.chamber_leds = state.gpOut[0].pwm * 100 ; -------------------- ;Check sb_leds status var SB_LEDS = true ; Turn on(true) / off(false) the Stealthburner led "system" if var.SB_LEDS if fileexists("/sys/lib/led/sb_leds-state.g") M98 P"/sys/lib/led/sb_leds-state.g" ; Check if global.sb_leds has changed since last run/loop ; --------------------------------------------------------------------------- ; Daemon loop delay G4 P10 ; Delay running again or next command for at least 1 second (was S1) ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
Or would you want it within the "RunDaemon" loop, and remove/comment out the one in the bottom @dc42 ?
This is somewhat difficult to answer
since i have no ideawhat Orca Slicer v1.8.1 (English language settings) runs under the hoodedit
Orca Slicer is running WebView2/edit
(and I have the "Device" tab open within Orca Slicer). For my desktop browser i'm currently using "Chrome x64 version 119.0.6045.200"(Norwegian language settings), but that's being updated all the time.
I'm quite positive that I tried several DuetWiFiServer releases once i started having these issues, trying to pinpoint where they came from. But since the crashes also kept happening on 1.27 i updated to the newest 2.1 beta again (if my memory serves right).
Other than that it had another crash now while i was about to deploy the changes to
daemon.g
, so i'll post that first:M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123200 of which 0 recycled Never used RAM 12516, free system stack 182 words Tasks: NETWORK(1,ready,19.9%,211) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,71.7%,670) IDLE(0,ready,6.8%,29) AIN(4,delaying,0.9%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:08:56 ago, cause: software Last software reset at 2023-12-09 11:38, reason: HardFault bfarValid precise, Platform spinning, available RAM 11420, slot 0 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x0d362e38 SP 0x20011f48 Task NETW Freestk 466 ok Stack: 0d362e30 20032cac 000001bf 00000000 0d362e30 20032cac 000043a8 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd33 2002bed4 2002be01 000001bf 2002c100 20031c70 2002c118 2001e888 362e303d a5a5a5a5 0002ff41 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 536827, completed 536827, timed out 0, errs 0 MCU temperature: min 36.8, current 36.8, max 37.2 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/27, heap memory allocated/used/recyclable 2048/384/32, gc cycles 1064 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 86, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 246, read errors 0, write errors 0, ifcnt 85, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 117, reads 652, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 122, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 117, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-09 11:47:28 Cache data hit count 922088436 Slowest loop: 8.47ms; fastest: 0.15ms === Storage === Free file entries: 17 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.0ms, write time 4.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 112, received 251, lost 0, errs 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 3, free buffers 26 (min 26), ts 62/62/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 21.95ms; fastest: 0.07ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43140 WiFi IP address 192.168.10.x Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
I did a little change to
daemon.g
to avoid "hammering" RRF with a newglobal.chamber_leds
value change every time it's ran, unless the value has changed from last time it was ran. Don't know if this will help this issue, but it should offload RRF a tiny bit at least:; Refresh chamber lights status if exists(global.chamber_leds) if global.chamber_leds != {state.gpOut[0].pwm * 100} set global.chamber_leds = state.gpOut[0].pwm * 100
Another crash btw, it happened while the machine was idle but i pulled the report while printing (if that matters):
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 13 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 126540 of which 12 recycled Never used RAM 7980, free system stack 136 words Tasks: NETWORK(1,ready,18.2%,195) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,244) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,74) MAIN(1,running,80.1%,580) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:59:00 ago, cause: software Last software reset at 2023-12-09 15:05, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 6040, slot 2 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x362e303d SP 0x20011f60 Task NETW Freestk 472 ok Stack: 362e303d 20032cfd 00000047 362e303c 20032ebc 0002dd33 00004434 210f0000 0002dce5 2002bed4 2002be01 000001c0 2002c100 200314b0 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0002ff41 00000000 00000000 00000000 362e303d 00000800 200359c8 2002c100 20018678 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 3541025, completed 3541025, timed out 0, errs 0 MCU temperature: min 35.9, current 40.2, max 41.2 Supply voltage: min 22.9, current 24.2, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/22, heap memory allocated/used/recyclable 2048/2008/1700, gc cycles 7 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 179, reads 55243, writes 31, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 177, reads 55243, writes 31, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 172, reads 55253, writes 20, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 176, reads 55252, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 171, reads 55253, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-09 16:04:56 Cache data hit count 4294967295 Slowest loop: 223.45ms; fastest: 0.09ms === Storage === Free file entries: 15 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 5.0ms, write time 4.6ms, max retries 0 === Move === DMs created 83, segments created 16, maxWait 3438848ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 20, on retry 14, too short 0, wrong shape 7, maybepossible 0 === DDARing 0 === Scheduled moves 129, completed 129, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.6 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "M116 H1" in state(s) 0 0, running macro USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10000" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 31998, received 72814, lost 0, errs 1, boc 0 Longest wait 6ms for reply type 6013, peak Tx sync delay 265, free buffers 26 (min 25), ts 17705/17704/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 71.81ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42944 WiFi IP address 192.168.10.x Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
