Reboots/crashes - RRF ≤3.5.0-rc1
@dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
@Exerqtor are you using the USB port on that Duet 3 Mini?
Nope the USB port haven't got anything plugged in.
@Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/1r49rb2x3jsn1az0jdu1j/h?rlkey=xke2yefix0hyp5dioxa58pgtp&dl=0 and post a M122 after any crash.
OK, i'll install it right away.
Hopefully this shines some more light on it:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 10 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123360 of which 0 recycled Never used RAM 12356, free system stack 188 words Tasks: NETWORK(1,ready,18.8%,239) HEAT(3,nWait,0.0%,336) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,79.3%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:26:31 ago, cause: software Last software reset at 2023-12-05 09:59, reason: HardFault imprec ibus, Gcodes spinning, available RAM 10968, slot 1 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000500 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f48 Task NETW Freestk 466 ok Stack: 0d362e30 20032dec 000001bf 00000001 0d362e30 20032dec 000043ae 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd0f 2002bed4 2002be01 000001bf 2002c138 20031db0 2002c150 2001e888 a5a5a5a5 a5a5a5a5 0002ff15 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 1591912, completed 1591912, timed out 0, errs 0 MCU temperature: min 33.2, current 34.0, max 36.2 Supply voltage: min 22.0, current 24.1, max 27.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1172/736, gc cycles 74 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 150, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18223, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-05 10:26:25 Cache data hit count 2710632535 Slowest loop: 9.77ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.1ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 14337, received 32674, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 260, free buffers 26 (min 25), ts 7960/7959/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 7.91ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor interesting, that one is a different sort of reset but in the same function. Please send M122 P500 S0, then wait for it to reset again and send the M122 report as usual.
Here you go ( i did a print or two after sending
M122 P500 S0
, hope that don't mess anything up):=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 6 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123360 of which 0 recycled Never used RAM 12356, free system stack 196 words Tasks: NETWORK(1,ready,19.1%,239) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.0%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:09:12 ago, cause: software Last software reset at 2023-12-06 08:16, reason: AssertionFailed, Gcodes spinning, available RAM 5824, slot 2 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 0000090f 000af3c8 0002de29 2002bed4 2002be01 000001b0 2002c100 20031550 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 2003155c 00000800 20035a68 2002c100 20018678 2002bf9d 20018678 2001e888 000300af 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 4152839, completed 4152837, timed out 0, errs 0 MCU temperature: min 33.8, current 34.0, max 36.9 Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1248/812, gc cycles 193 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 89, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 248, read errors 0, write errors 1, ifcnt 88, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 52, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 50, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-06 09:25:54 Cache data hit count 4294967295 Slowest loop: 12.98ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.9ms, write time 4.8ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 37382, received 85164, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 20763/20762/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 5.88ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor thanks, that's back to normal. Please install the firmware from https://www.dropbox.com/scl/fo/pj3pphcoi373dtlcbsrao/h?rlkey=w3hwi2n2l51bywl0773j9uo6a&dl=0 (ignore all the other files there, you only need the .uf2 file) and again send M122 P500 S0 after it starts up. That command will persist until the next reset, so no problem if you do several prints.
"Normal" lol. Ok i'll install it once the current print finishes, and addM122 P500 S0
at the bottom of config.g. -
Here we have one:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-06 12:09:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 123360 of which 0 recycled Never used RAM 12356, free system stack 194 words Tasks: NETWORK(2,nWait,18.3%,228) HEAT(3,nWait,0.0%,355) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.9%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:05:36 ago, cause: software Last software reset at 2023-12-07 02:46, reason: AssertionFailed, Gcodes spinning, available RAM 5440, slot 0 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001b0 2002c100 20031598 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 200315a4 00000800 20035ab0 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 336854, completed 336854, timed out 0, errs 0 MCU temperature: min 35.1, current 35.7, max 38.4 Supply voltage: min 22.4, current 24.1, max 26.6, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/640/204, gc cycles 16 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 207, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 206, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 111, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 112, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 109, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-07 02:51:52 Cache data hit count 560391083 Slowest loop: 12.95ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.9ms, write time 4.6ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 3040, received 6936, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6031, peak Tx sync delay 253, free buffers 26 (min 25), ts 1684/1683/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 8.87ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948 WiFi IP address 192.168.10.x Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
And another:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-06 12:09:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 122128 of which 0 recycled Never used RAM 13588, free system stack 198 words Tasks: NETWORK(1,ready,18.3%,203) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,116) MAIN(1,running,79.7%,670) IDLE(0,ready,0.4%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:03:15 ago, cause: software Last software reset at 2023-12-07 06:59, reason: AssertionFailed, Gcodes spinning, available RAM 13540, slot 0 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001a8 2002c100 20031d28 2002c118 2001e888 a5a5a5a5 a5a5a5a5 362e303d 00000000 00000000 00000000 20031d34 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 195496, completed 195496, timed out 0, errs 0 MCU temperature: min 34.2, current 34.8, max 37.3 Supply voltage: min 22.6, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1524/1128, gc cycles 8 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 249, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 248, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 153, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 154, reads 10256, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 151, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-07 07:03:01 Cache data hit count 327929753 Slowest loop: 8.69ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.8ms, write time 3.7ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 1768, received 4041, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 345, free buffers 26 (min 25), ts 977/976/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 6.88ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948 WiFi IP address 192.168.10.x Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor thanks for those. I'll have another firmware build for you to test shortly.
The corrupt data appears to be 4 characters of ASCII text. In two cases it is
=0.1
and in one case=0.6
. Does that text appear in the file you printed, or in any of your macro files that the print may be invoking? -
@Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/y34newtid8z5zp7qa5ted/h?rlkey=i65uvg992k74vrgygg4rp4g98&dl=0.
=0.1
and in one case=0.6
. Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?Sounds like progress
But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print. So all the crashes has happened with the printer in an idle state (unless otherwise mentioned).
Ok, I'll download and install it straight away!
@Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
=0.1
and in one case=0.6
. Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?Sounds like progress😁
But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print.So all the crashes has happened with the printer in an idle state(unless otherwise mentioned).I guess what
daemon.g
is doing still applies while the printer is idle, so here is how that looks as of now (just grabbed it straight of the printer):; /sys/daemon.g v2.4 ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again. ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ ; Loop, to be able to turn on/off daemon.g while global.RunDaemon ; Stuff goes here ; Resume after filament change if exists(global.FilamentCHG) if global.FilamentCHG = true && state.status="paused" M24 ; Resume the pause automatically now that the manual filament change is done set global.FilamentCHG = false ; Refresh chamber lights status if exists(global.chamber_leds) set global.chamber_leds = state.gpOut[0].pwm * 100 ;Check sb_leds status var SB_LEDS = true ; Turn on(true) / off(false) the Stealthburner led "system" if var.SB_LEDS if fileexists("/sys/lib/led/sb_leds-state.g") M98 P"/sys/lib/led/sb_leds-state.g" ; Check if global.sb_leds has changed since last run/loop ; Print acceleration & input shaping control if global.accel_control ; Low accel on the whole first layer so that it gets good adhesion if global.layer_number = 1 M204 P500 ; Set printing acceleration(mm/s�) ; Everything else else if global.line_type = "External perimeter" if move.printingAcceleration != global.low_accel M204 P{global.low_accel} ; Set printing acceleration(mm/s�) ;if move.shaping.type != global.input_shaper ;M593 P{global.input_shaper} ; Configure input shaping elif global.line_type = "Perimeter" if move.printingAcceleration != 2000 M204 P2000 ; Set printing acceleration(mm/s�) ;if move.shaping.type != global.input_shaper ;M593 P{global.input_shaper} ; Configure input shaping elif global.line_type = "Solid infill" if move.printingAcceleration != 2000 M204 P2000 ; Set printing acceleration(mm/s�) ;if move.shaping.type != "none" ;M593 P"none" ; Configure input shaping elif global.line_type = "Top solid infill" if move.printingAcceleration != global.low_accel M204 P{global.low_accel} ; Set printing acceleration(mm/s�) ; When none of the above line extrusion types else if move.printingAcceleration != global.def_print_accel M204 P{global.def_print_accel} ; Set printing acceleration(mm/s�) ;if move.shaping.type != "none" ;M593 P"none" ; Disable input shaping ; ----------------- ; Daemon loop delay G4 S1 ; Delay running again or next command for at least 1 second
And
sb_leds-state.g
:; /sys/lib/led/sb_leds-state.g v2.0 ; Created by sb_leds.g to store the current/active LED colors ; Called by daemon.g to check if global.sb_leds status has changed since last run var sb_leds = "boot" if var.sb_leds = global.sb_leds ; Same status, do nothing else ; New status, change colors M98 P"/sys/lib/led/sb_leds.g"
And while the printer is idle
global.sb_leds
don't change value.So as far as i can see it shouldn't be any
=0.1
or=0.6
anywhere. -
First M122 report after a crash on that build (also in a idle state when crashing) :
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 11 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 122152 of which 0 recycled Never used RAM 13564, free system stack 186 words Tasks: NETWORK(1,ready,1687.6%,203) HEAT(3,nWait,2.1%,330) Move(4,nWait,0.2%,351) CanReceiv(6,nWait,4.3%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.6%,350) TMC(4,nWait,60.6%,108) MAIN(1,running,1092.0%,670) IDLE(0,ready,21.0%,29) AIN(4,delaying,73.1%,264), total 2941.7% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 04:49:41 ago, cause: software Last software reset at 2023-12-08 01:28, reason: AssertionFailed, Platform spinning, available RAM 12356, slot 2 Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001af 2002c100 20031d10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 20031d1c 00000800 20035a10 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 17381709, completed 17381709, timed out 0, errs 0 MCU temperature: min 34.2, current 34.8, max 38.2 Supply voltage: min 22.7, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/492/96, gc cycles 783 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-08 06:17:56 Cache data hit count 4294967295 Slowest loop: 12.85ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.2ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 156442, received 356364, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6042, peak Tx sync delay 275, free buffers 26 (min 25), ts 86907/86906/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 24.24ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42964 WiFi IP address 192.168.10.x Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor do you get crashes if you disable daemon.g?
@droftarts said in Reboots/crashes - RRF 3.5.0-rc1:
As in setting the global to false disable, or have a empty daemon.g?
I can try both, i just set the global to false (i'm pretty sure we tested this earlier, but it's been such a long time since this all started I have a hard time keeping up).
@Exerqtor better to have a daemon.g file with just a very long G4 command in it.
In general you mean? Or could elaborate on that a little bit?
I have alot of crap in daemon.g currently, it's mostly disabled since i ditched what i was trying to do with it. Just haven't gotten around to cleaning it up yet.
Guess i could do that now
@Exerqtor what I meant was that a daemon.g file with just a long G4 delay in it would result in less S card access than no daemon.g at all. The maximum value for a G4 delay command is about 2 million seconds.
Conversely, if you try reducing the G4 S1 delay in your current daemon.g file (e.g. try G4 P10) then this will result in more SD card reads. It would be interesting to see if that results in more frequent resets. Please try that.
Another thing you could do at the same time is to pad out the end of daemon.g with a few long comment lines something like this:
;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
This might indicate whether the data that overwrites the return address comes from the residue of the sector of daemon.g that is currently past the end of the file. The sector size is 512 bytes so the number of comment characters in total shod be at least that.
Gotcha!I just did the much needed cleanup in my daemon.g, but I've now added what you said mentioned.
This is how it looks as of now:
; /sys/daemon.g v2.5 ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again. ;---/ ; -/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!! ;--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/--/-- ;-/ ; Loop, to be able to turn on/off daemon.g while global.RunDaemon ; Stuff goes below this line ; --------------------------------------------------------------------------- ; Resume after filament change if exists(global.FilamentCHG) if global.FilamentCHG = true && state.status="paused" M24 ; Resume the pause automatically now that the manual filament change is done set global.FilamentCHG = false ; -------------------- ; Refresh chamber lights status if exists(global.chamber_leds) set global.chamber_leds = state.gpOut[0].pwm * 100 ; -------------------- ;Check sb_leds status var SB_LEDS = true ; Turn on(true) / off(false) the Stealthburner led "system" if var.SB_LEDS if fileexists("/sys/lib/led/sb_leds-state.g") M98 P"/sys/lib/led/sb_leds-state.g" ; Check if global.sb_leds has changed since last run/loop ; --------------------------------------------------------------------------- ; Daemon loop delay G4 P10 ; Delay running again or next command for at least 1 second (was S1) ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
