Filament monitoring while printing via USB
@jay_s_uk But that's my point - even when connected to the mainboard sensors.filamentMonitors[0].status will stay at "ok" when I run out of filament
@benecito that may be a bug then. what firmware version are you running?
@jay_s_uk 3.5.0 beta 3
Hi, are there any updates on how to enable filament monitoring while printing via usb? Is there a new enable mode which needs to be used?
Thanks, Timo -
@timoschuett you use S2 in M591 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m591-configure-filament-sensing
only supported in 3.5RC1 and newer -
@timoschuett see the M591 documentation:
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m591-configure-filament-sensingThe S2 parameter.
@timoschuett please be aware it does not really work yet.
@benecito have you reported any problems with it that you're having?
@jay_s_uk we're in contact and diagnosing the issue yes
Thank you guys! I must been blind while reading the wiki earlier, have not found anything about it. Now i`ve found it
@benecito what exactly "does not really work yet" ? -
@timoschuett we have one user (only one AFAIK) who has an intermittent issue with a filament monitor connected to a Duet 3 Mini. Apart from that, I believe all the outstanding issues have been addressed in the 3.5.0-rc.1+ firmware builds, which are available at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0.
@dc42 Perfekt, sounds promising. I will give it a try on monday
