Filament monitoring while printing via USB
@benecito looks like there are a few things that aren't reported in the OM for filament sensors, especially when over CAN-FD. https://github.com/Duet3D/RepRapFirmware/issues?q=is%3Aissue+is%3Aopen+filament
@jay_s_uk @chrishamm To be honest I don't care so much if it's reported in the OM or not. The proposed "workaround" at https://github.com/Duet3D/RepRapFirmware/issues/862 does not work if the status is always "ok". Rearranging the extruders and the filament monitors to the mainboard could be done, but is not the preferred option.
Is there another parameter than sensors.filamentMonitors[0].status that might help to achieve the idea of using deamon.g
@benecito no, thats the point of my response, sensors.filamentMonitors[0].status is from the object model...
there isn't another way to query something -
@jay_s_uk all right - so the conclusion is, that we can't use any filament monitor as of now?
@jay_s_uk But that's my point - even when connected to the mainboard sensors.filamentMonitors[0].status will stay at "ok" when I run out of filament
@benecito that may be a bug then. what firmware version are you running?
@jay_s_uk 3.5.0 beta 3
Hi, are there any updates on how to enable filament monitoring while printing via usb? Is there a new enable mode which needs to be used?
Thanks, Timo -
@timoschuett you use S2 in M591 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m591-configure-filament-sensing
only supported in 3.5RC1 and newer -
@timoschuett see the M591 documentation:
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m591-configure-filament-sensingThe S2 parameter.
@timoschuett please be aware it does not really work yet.
@benecito have you reported any problems with it that you're having?
@jay_s_uk we're in contact and diagnosing the issue yes
Thank you guys! I must been blind while reading the wiki earlier, have not found anything about it. Now i`ve found it
@benecito what exactly "does not really work yet" ? -
@timoschuett we have one user (only one AFAIK) who has an intermittent issue with a filament monitor connected to a Duet 3 Mini. Apart from that, I believe all the outstanding issues have been addressed in the 3.5.0-rc.1+ firmware builds, which are available at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0.
@dc42 Perfekt, sounds promising. I will give it a try on monday
