Multizone heater bed
Is there an easy-ish way to run a heater bed with multiple heating elements and then just turn on whatever part of the bed is needed?
Like what the Prusa XL does?
Would be neat for big printers. -
I mean this was made by you (Duet3D).
Any documentation to go with it?
How were the 3HC board connected to the beds? I mean each 3HC only has 3 high amps outputs but that bad has 9 segments? -
@Anon1337 I believe the bed heaters were all AC mains voltage, so controlled by SSRs.
@dc42 So AC SSRs connected to the 3HC PWM outputs? How were the segments controlled? Was it automatic or do you have to manually choose what segments to heat?
