Probing Errors with Prusa mk2.5s and PINDA sensor
@Trafim In DWC, what number does the Z-Probe report when the probe is far from the bed? If it is 1000, this means the firmware thinks the probe is already triggered. It should read 0. If you can put something under the probe, close to it, and then it reads 0, it means the probe has been wired 'inverted'. This would be a bit strange, as the signal should not need inverting. You can invert the pin logic in the M558 command by adding a
at the beginning of the pin name, egM558 P8 C"!io2.in" H1 F1000 T6000 A3
However, if the Z-Probe reading never changes, most likely there is a wiring error, and probably the signal wire is not making contact. Check all wiring connections; it may not be receiving power. Check it is plugged into the correct IO header. If the thermistor is reporting a sensible temperature, then at least the thermistor wire and GND are connected. If there is a light on the probe to show it is getting power (I can't remember if there is), and/or is triggered, this may help diagnose what the problem is. If you can post a picture of how it is wired, that may also help.
Regarding M18, as far as I'm aware, it has always needed an extruder drive number for E. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes/M18
@droftarts Yes, the probe does have a light on it, showing it is getting power, and it turns off when the probe is triggered. Everything is wired as such, and there is continuity in the wires:
When triggered the probe shows 1000, when not 0. I don't know where to look to find the thermistor readings of the Pinda sensor. Putting something metal under the sensor shoes it triggering correctly both on the sensor itself and in DWC. And after looking closely, it does seem that the probe is triggered before the probing move and the probe never triggers on the next probing move. But why? the bed nor X axis seem to be that badly out of alignment. After lowering it down to were the probe triggers, moving it to the other side does seems to stop it from triggering, but this issue seems to be very small. Isn't this compensation in place to fix just this?
With M18, its just a bit bizarre that that wasn't in the software from the RR config tool... / CNC Kitchen's tutorial. Would setting it to zero be the right thing to put there? What is an extruder drive number?
Sorry for the delay, Thank you!
@Trafim your dive height is set to 1mm (in the M558) in the config.g but your trigger height is more than that (1.1mm, in the G31). Since dive height is the height from which probing starts, I think it needs to be higher than trigger height. I'd try setting the H1 parameter in the M558 to be H3, then probably in due course refine it down to H1.5.
The rest of this is just my observations about a similarish configuration, not (I think) related to your problem.
I have a Pinda V2. Mine is a mini5+ and a toolboard, but apart from different pin names I think the config should be fairly similar.
My config.g (extract):
M308 S3 P"121.temp1" A"pinda" Y"thermistor" T100000 B3950 ; pinda thermistor M558 P8 C"^121.io2.in" H2 A5 S0.005 F300:60 T6000 ; set Z probe type to unfiltered switch, dive height (2mm), max repetitions, tolerance, speeds G31 P500 X23 Y5 Z0.87 T-0.000987:0.000245 S30 H3 ; set Z probe trigger value, offsets, trigger height and temperature compensation M557 X25:240 Y6:204 P6:5 ; define mesh grid M376 H8 ; compensate first 8mm only
Compared to yours, I've specified up to 5 probes and much slower probe speeds (I use 300:60, you are using 1000 in the config.g but you drop it to 100 for some probes in bed.g. I found probing fast to be not nearly as accurate.
My G31 has very different temperature compensation. I use polynomial compensation, with a much lower coefficient. You can find a (long) discussion of that (with graphs) at https://forum.duet3d.com/post/309759
I have a different number of probe points x and y so each cell of the grid is closer to square.
In bed.g I have:
; bed.g ; called to perform automatic bed compensation via G32 ; M561 ; clear any bed transform ; probe across centreline of bed and level Z motors G30 P0 X25 Y105 Z-99999 G30 P1 X240 Y105 Z-99999 S2 G4 P250 ; pause G30 P0 X240 Y105 Z-99999 ; repreat process coming back again G30 P1 X25 Y105 Z-99999 S2 G29 ; probe the bed and enable compensation G1 Z5 F720 G1 X0 Y0 F6000
I'm not sure why you have other M558s in there rather than just setting a single config in confg.g (I want similar accuracy when setting the leadscrews as when doing mesh probing, so it's just a single set of speeds, tolerance etc.). I also don't bother homing again in this file.
I also do two passes, i.e. probe at left leadscrew the right leadscrew and compensate, then at right leadscrew and left left leadscrew again.
I don't know why you're using M18 at all - it lets the steppers float, but why? I don't use M18.
As to where to look to find the Pinda thermistor, you've defined it as being on pin 'temp2' and called it sensor 2 (S2 in the M308 line) and your wiring diagram looks compatible with that, so it should be showing in the DWC temperatures panel (under 'Extra'). You've named it 'Pinda V2'.
@achrn That seems to have fixed most of everything! I implemented what you told me and everything seems to be working, I just had to change the Z offset for my printer to get a good first layer. The extra M558s were part of the original tutorial, and I'm planning on phasing them out after reading up on them a little bit. Although, I do have another peculiar issue. The temperature readings for the PINDA V2 are negative... -26°C when turning on, and when printing they warmed up to around -17°C. Is this an incorrect config, or is the PINDA just done? The M18 was also part of the Firmware provided in the tutorial... I'll look into that as well.
Thank you for the info!
@Trafim your config looks OK to me (
M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950
) and matches what I have (M308 S3 P"121.temp1" A"pinda" Y"thermistor" T100000 B3950
) but for the pin it's connected to and the number and name assigned. That's what I found online also (from a few sources, but I don't remember details). So I don't think it's a config issue.Temperature reading too low implies resistance is too high, so are the connections good? Is the cable good? What resistance do you measure across the pinda white and blue wires at the mini5 end? The thermistor ought to be reading 100k ohm at 25C, and a reading -26C suggests a resistance about 1.3M ohm. You could try connecting the pinda2 to temp1 (i.e. disconnect the bed thermistor) to see if that narrows down the problem (and indeed try connecting the bed thermistor to temp2 and see what that does).
Incidentally, with respect to the bed thermistor, my reading of the Prusa firmware source is that the bed thermistor is type 1 from 1_75mm_MK25S-RAMBo13a-E3Dv6full.h where #define TEMP_SENSOR_BED 1 and "1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)". That thermistor is typically cited as B=4036, but back-calculation of the values in the source lookup table give best match if B=4078, I think.
However, the Prusa firmware seems to also add a 'fudge factor' or correction of 0 below 40C, 5C at 50C, 10C at 100C.
I trapped a couple of thermocouples under the magnetic plate and played around with B values until I got best correlation between what the bed was set to and what the thermocouples reported. That happened with a bed thermocouple B value of 4298. My bed thermistor is on temp0 so I have
M308 S0 P"temp0" A"bed" Y"thermistor" T100000 B4298
for the bed thermistor. -
@Trafim I've had another thought - your reported temperatures are about what you'd get at normalish room temperatures if you'd configured it with
T10000
instead ofT100000
. Are you sure you have enough zeros? -
@Trafim Hello, I have uploaded all the files provided by CNCKitchen, I have them hosted on a Duet 3 prusa 2.5s they really do not work correctly, the z gives me error G28 from there I have not advanced since I lack a lot of knowledge and time since it is a hobby, would someone have the .G files, working on a prusa like the one I have? Thank you
@Trafim said in Probing Errors with Prusa mk2.5s and PINDA sensor:
Estoy reconstruyendo una Prusa mk2.5s para usar una duet 3 mini 5+. Estoy usando la mayor parte del código de la guía de CNCkitchen pero cambié algunas de las configuraciones de la sonda de acuerdo con este foro .
Esto me dejó con este archivo de configuración:It is possible that you upload your correct files so that I can use them, I had a problem with the CNCKitchen files, and I could not solve them, lack of knowledge I have a Prusa MK2.5s like you with a Duet 3 board. It is just a hobby Thank you
G28 Z Error: Homing file homez.g not found
@raftaman said in Probing Errors with Prusa mk2.5s and PINDA sensor:
Do you have a homez.g file in your sys folder on the SD card?
@Phaedrux; 0:/sys/homez.g
; Home the Z axis;M98 P"current-sense-homing.g" ; Ensure the current and sensitivity is set for homing routines.
; !!! If using Pinda, comment-out the following two lines
;M280 P0 S160 ; BLTouch, alarm release.
;G4 P100 ; BLTouch, delay for the release command.G91 ; Set relative positioning.
G1 H0 Z3 F6000 ; Lift Z axis 3mm.
G90 ; Set absolute positioning.G1 X105 Y105 F6000 ; Go to the center of the bed for probe point.
M558 F1000 A1 ; Set probing speed to fast for the first pass.
G30 ; Perform Z probing.
G1 H0 Z5 F400 ; Lift Z axis to the 5mm position.M558 F50 A5 S-1 ; Set probing speed to slow for second pass, take 5 probes and yield the average.
G1 H0 Z5 F400 ; Lift Z axis to the 5mm position.M558 F200 A1 ; Set normal z-probe speed.
When exactly are you getting that error?
@Phaedrux when I do a startup test on the Prusa mk2.5s
What is the startup test exactly?
@Phaedrux When I click on: Home All, I get that error. Home X, super, Home Y., Super, Home Z. Mistake
It's not saying homez.g not found, it's saying a move was attempted on an axis before it was homed. In your homez.g you have this G1 H0 move trying to lift the Z axis before it has been homed. This should be G1 H2 to allow the move to proceed even though it is not homed.
@PhaedruxWhat step should I take, what code should I include?
@Phaedrux said in Probing Errors with Prusa mk2.5s and PINDA sensor:
@PhaedruxI'M GOING TO TRY THIS WEEKEND WITH THE CODE YOU WRITE FOR ME. Thank
