PID does not work
@dc42 I did the tuning with the print cooling fan on, but it said something like "it appears the print cooling fan is not cooling down the hotend"
@Haggan90 best tune as a tool i.e.
M303 T0 S240
@jay_s_uk I did so
@Haggan90 which firmware version are you using?
@Haggan90 3.4.2
What kind of heater is it? Photos?
@Phaedrux It's just a Volcano heater, I never had this problem before RR3.
This post is deleted! -
@Haggan90 two suggestions:
- Upgrade to firmware 3.4.6
- If that doesn't help, reduce the R parameter in the M307 command. Try a 25% reduction first. If you reduce it too much then the temperature will overshoot the set value.
@dc42 Ok thank you, I will try that!
