Hello
Can somebody help me with driver and software for st3di pro280.
I got this printer but without software and driver. -
Does it have a Duet board in it?
@ddtunder The ST3DI website seems to have disappeared (last active in 2019), but you can see it in the Wayback Machine: http://web.archive.org/web/20190726203455/http://www.st3di.com/
There's some ST3DI produced videos on this youtube channel https://www.youtube.com/@st3di3dprintersandconsumab53/videos though all the videos are from 7 years ago.From what I can see, it does not run a Duet board. I'd expect it to be connected to Ethernet and use the web interface if it did, but it looks like everything runs from a built-in screen. Looking at the pictures in the thread below, it looks like a custom RAMPS board, probably using a ATMEGA 1240 or 2560, running a customised version of Marlin. So not something we support on this forum.
There's a long thread in the forum here https://forum.duet3d.com/topic/20707/st3di-modelsmart-280-duet-maestro-repair-upgrade/ about user @Blacksheep99 converting one to use a Duet Maestro. A Duet 3 Mini 5+ would be a better board to use now. There's also a link at the end of that thread to some of the original ST3DI files.
I'm moving this thread to 'General', not really relevant in 'CNC'.
undefined droftarts moved this topic from CNC
Here is the original slicing software https://drive.google.com/file/d/1f1yuOidiOxlcGvqfJhKm9rftpKGLOB2k/view?usp=drive_link
It's old and clunky. You can use a slicer like Cura or Prusasclier with the printer with a little bit of work. If you want to update the printer then as @droftarts says look at one of the current duet boards.
If I can help let me know, I'll try asisst.
@Blacksheep99
thanks man, it's work perfect, my son try program and all is
