I'm confused about stepper motor voltage
@jens55 thanks for providing that summary.
The 48V-capable MB6HC 1.02 and EXP3HC 1.02 have on-board 12V regulators which can be used to power 12V fans.
@gnydick you can use the calculator at https://www.reprapfirmware.org/emf.html to see how increasing the driver voltage allows torque to be maintained at higher speeds.
@dc42 I wish I had the 1.02. I just (couple months ago) finished building out my machine with the 1.01.
Very cool about the emf tool
@dc42 I plugged my info into the form and changing the voltage didn't change anything but low slip angle. I don't know how to interpret that number. I can see changing the torque also brings the number back down after increasing the voltage, but other than that, how am I supposed to use this?
@gnydick, the first 3 parameters are a function of the motor itself and not related to voltage. Only the slip angle parameters (and I don't know what the low/high slip angle difference is) are supposed change. If you change the supply voltage you can see how the motor maximum speed increases with supply voltage.
As I don't know what the slip angles represent, I can only guess that it is the point when the motor torque starts to dip noticeably. -
I will add few cents to this discussion:
I supply 37V to my v1.0 6HC Duet:
https://forum.duet3d.com/topic/26758/32-4v-input-instead-of-32v/2?_=1659258404908If you want to know more about steppers, check this video out:
https://www.youtube.com/watch?v=lftsMrksdTA&list=PLWQs4VcXB7unGrcCVibcisuvt0Hamxb4d&index=21 -
undefined droftarts referenced this topic
@Mandragora that's cool. I guess I can get a decent bump in performance.
I'm assuming the higher voltage will not be good for my fans that run one VIN?
Also, what about tool boards, heater cartridges, etc.?
@gnydick said in I'm confused about stepper motor voltage:
............. Also, what about tool boards, heater cartridges, etc.?
For sure you'd need to either use a second PSU or a buck converter. Doing some rough maths, a 40 watt, 24V heater has a resistance of about 14 Ohms and draws about 1.7 Amps of current. If you supply it with 37 volts, that same 14 Ohms will draw about 2.6 Amps of current. So your 24V, 40 watt heater becomes about 95 Watts at 37 volts.
@deckingman, so is it possible to run 1 PSU for the motors and 1 for everything else?
@gnydick I don't see why not but someone more knowledgeable than me might say otherwise. I'm fairly sure that the Duet boards switch the 0v side of things like fans and heaters. So you'd connect one side of your 24V heater to the 24V PSU and the other side to the Duet heater -ve terminal while supplying the main board with the higher voltage PSU.
@deckingman said in I'm confused about stepper motor voltage:
Yes that's correct.
@dc42 I don't have the confidence to wire things without foolproof instructions/diagrams.
For example, when I hear something like the fact that there's a common ground and I can use any of the negative terminals, makes my eyes water. I have 2-3 years of EE from high-school 30 years ago.
And I'm using tool distro board + 4 toolboards. Only heater directly connected is the bed.
@gnydick, Danger Will Robinson, Danger, Danger
Most of the outputs are SWITCHED on the ground side. They are NOT common !!! -
@gnydick In your OP you mention people using 48V to get "crazy speed and torque". If you are uncomfortable about making the necessary changes, then I guess the question you have to ask yourself is how badly you want that "crazy speed and torque". You can't print at "crazy speeds" due to restrictions imposed by the volumetric melt rate of the hot end. If your machine is for cutting metal, then you are restricted by how fast the cutter can remove material. So the only time you can use "crazy speeds" is for travel moves. How badly do you want to use higher travel speeds than those that you can get now? Torque is another matter. It is needed to accelerate the moving mass. So if you have a particularly heavy print head or cutting spindle, and you want to accelerate the gantry on which it sits faster than you are currently able, then you need more torque. But again, can you reasonably make use of that extra acceleration? If so, and given that you are uncomfortable with making the necessary wiring changes involved with using higher voltages, then there are other ways such as simply using bigger motors, or use remote drive shafts and asymmetric pulleys to get a gearing effect, or use two or more motors.
But you really need to do your own cost/benefit analysis (and for cost, I mean time as well as cash). Start with the benefits and look closely at how yould benefit from "crazy speeds and torque". Can you reasonably make use of them? How much would the printing or machining time be reduced? If yours is a commercial enterprise and the machine is running 24/7 then saving a few minutes out of every hour might be worth the cost. But if the machine sits idle for large parts of the time, then probably not.
@deckingman that's all correct. My print head is heavy because it's the E3D tool changer setup on a RailCore II. I don't want crazy speed, just a bit more torque. I was merely referring to what happens at higher voltage to see if I could benefit.
I'm not uncomfortable making changes if I know what they are. The lingo is just too casually bandied about sometimes to be sure what people mean. Give me a diagram or explicit instructions, and I can do it.
It's when it comes to terms that aren't identical to what's in the duet docs that I'm not sure. Like, what's Ve? I remember VIN, VOUT, positive, ground, etc.
I just like to be careful. I have a literal pile of duet boards that are fried in one way or another because I carried on when I wasn't sure.
Like, what's Ve?
I think you are referring to where @deckingman said "... and the other side to the Duet heater -ve terminal ..."
"-ve" is negative. He means the negative terminal.Ian
@droftarts OMG, like i18n, but even slightly nerdier. Well done.
@gnydick Yes, sorry. -ve is just shorthand for negative, and +ve is shorthand for positive. Unfortunately such shorthand terms are often used on circuit boards because there simply isn't room to fit the full length term in a legible font size. -ve could also be labelled "gnd" (short for "ground") and you might see vcc which generally means supply voltage (not sure what the "cc" part stands for), or 12v which means 12 volts. But being a nearly 70 year old, retired mechanical engineer, with little in the way of formal qualifications, I'm probably not the best person to advise you on electronics terminology. What I know is just what I've picked up over the years.
@deckingman it's all perfectly reasonable. I'm the same, all self taught. I know the challenges.
