High temperature in driver 2
I think you are saying that the Z motor doesn't turn, but if you connect it to another driver output then you can make it move. Is that right?
If you have only one Z motor, do you have 2 jumpers in the second Z motor connector?
the second connector of z is bridged, if I connect the motor of the tower z in x the motor turns without problems.
I'm sorry, it sounds as though either the Z driver on your board is faulty or (more likely) it is not receiving its CS signal. Please ask for your Duet to be replaced.
Could you remap the firmware to disable driver 2 and pass it to driver 5?
I presume you mean driver 4. Yes, you can use M584 X0 Y1 Z4 E3 to remap the Z driver to driver 4 (labelled E1). In recent 1.20beta versions of the firmware, you can stop driver 2 producing messages by sending M569 P2 E-1.
good night, when I insert the command to stop the driver I get this message
M569 P2 E-1
Error: M569 no longer accepts XYZE parameters; use M584 instead -
I'm sorry, it should be R not E:
M569 P2 R-1
good morning, after putting the commands that you have indicated this is the message sent me G28
Warning: Error: Short-to-ground on drivers 2
Warning: Warning: high temperature on drivers 2 -
Are you using the latest 1.20 beta firmware? The R-1 option doesn't work on firmware 1.19 and earlier.
yes,using 1.20
Which particular 1.20beta is it? Run M115 to find out.
FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20beta8+1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-11-18
Strange, in that release M569 P2 R-1 should suppress messages from driver 2. I'll test it when I have a suitable faulty board.
Just to be clear: you are using these 2 commands in config.g:
M584 X0 Y1 Z4 E3
M569 P2 E-1Yes?
Good afternoon, I had all the commands on but the driver keeps warming up and as a precaution I'm going to replace it, thank you very much for all the help provided.
