Bringing Rostock Max V2 back to life.
I've updated the Duet 2 WIFI firmware to 3.4.5.
I was hoping to get some help reviewing my new config files. config.g
I have a delta smart effector coming for the Z probe and a PT100 at the hot end, 2 extruders with one hot end.Please let me know if I missed any info you'd need.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Apr 09 2023 17:52:31 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M665 R120 L290.8 B120 H380 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E94.02:94.02 ; set steps per mm M566 X72000.00 Y72000.00 Z72000.00 E1200.00:1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X1200000 Y1200000 Z1200000 E3600:3600 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00:1000.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop ; Z-Probe M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4338 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C M308 S1 P"e0temp" Y"pt1000" ; configure sensor 1 as PT1000 on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"HotEnd" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Are you having any issues? I don't see anything glaring at a quick glance.
@Phaedrux thanks for the reply.
My Hotend is showing 2k at room temp.
When I turn on the bed I got an error that it wasn't heating up fast enough.
Under Extruder control I can change the feed amount and rate, but can't click on retract or extrude. -
2k temp means thermistor isnt cinnected correctly, check wiring on both ends and that you use the right connection on the board.
Your bed temp rising too slowly is because in RRF3 bed heaters dont get special treatment and you will beed to PID tune it.
With the broken thermistor, extrusion is disabled. Should be working fine if you sort that out. Just a note cold extrude is broken in the current 3.5beta2 but should be fixed in the 3.5beta3 supposed to be coming out real soon now.
@TwoTone said in Bringing Rostock Max V2 back to life.:
Your config.g file is set up for a PT1000. Is that what you have, or do you have a PT100 + daughter board?
@dc42 I have a pt100 with daughter board.
In that case you'll need to change your heater config a bit.
M308 S1 P"e0temp" Y"pt1000". ; configure sensor 1 as PT1000 on pin e0temp
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1
@Phaedrux Thanks
