Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Can I run separate input shapers for different tool heads? For example M593 P"zvddd" F47 for T0 and M593 P"mzv" F42 for T1, if I put them under each specific tool in the config file?
You could probably load the shaper profile in the tool change files.
Or in daemon.g with some conditional code.
daemon.g
@Velvia as @Phaedrux suggested, use the tool change files. You can put the M593 command in the tpost#.g file.
