Pre-release 3.5 beta 2 now available
We tested this 3.5 beta 2 in our 6XD + several 1LCs machine in SBC mode, and it gives constant SPI reseting.
Going back to 3.4.5 stable version revert the normal behaviour of the printer.
All firmware on the boards in the beta 2 are been updated, just in case it needs to be same version than mainboard.
@DIY-O-Sphere said in Pre-release 3.5 beta 2 now available:
Is there any news on restoring the old error handling in the case of a heater fault ?What aspect of the old error handling is it that you want, that can't be achieved using the event system?
@Marcossf thanks for your report. I've asked @chrishamm to look into this.
For now the 3.5beta builds of expansion boards are compatible with RRF 3.4 on the main board, and vice versa. This will change in a future beta release.
This topic is really getting annoying.
I expect the firmware to shut down the system as announced here."Currently, RRF does not attempt to turn off power to the whole machine in the case of machines with firmware controlled power supplies if the user does not respond to the heater fault. We plan to reinstate this or a similar function in release 3.5"
@DIY-O-Sphere This sounds easy enough to handle yourself with the use of daemon.g?
@DIY-O-Sphere What do you want to say with that?
I'd simply write a piece of code for daemon that checks if a heater has been in fault state for some time and if it does, turn off the power supply.
Even if I don't really see why you'd want to do that, you clearly appear have a use case for it and it it's easy enough to add? -
@Marcossf Please can you share your config and/or the M122 output after a SPI reset.
Hi @chrishamm
Our config file is not going to clarify anything for you as it makes calls to several other files that it loads from where there are hundreds of variables.
We would have to figure out a way to get an M122 out because when it connects and disconnects it does it often, with no time to see what is going on. I think we have a console log where we can see it, but it never connects stable, not even once. I'll look for it.
With version 3.4.5 it works perfectly.
Sorry I can't give you more clues. -
@Marcossf You should be able to connect via USB to get the M122 output.
@Marcossf you can also share a zip of the /sys directory and and other macro directories. If that's sensitive information then we can arrange to get it another way
This post is deleted! -
