fans out7 out8 out9
Hi, I have been having some problems the out7 out8 out9 pins getting to turn on. I am using a 24V power supply. Can someone help me determin if those ports are fried? Thanks
What board are you using? What firmware? What gcode are you sending? What do you have connected? How is it connected?
@Phaedrux Its a duet3 board the firmware is RepRapFirmware for Duet 3 MB6HC version 3.4.1
I try something like this:
M950 F0 C"out8" Q500
M106 S127
M106 P0 S200 H-1I tried the slider tool too and no dice
Post your full config.g please.
@rister502dad please do reply here.
@T3P3Tony Sure I am a bit confused sorry with this format, here is my config.g
; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.15 on Mon Dec 12 2022 12:58:34 GMT-0800 (Pacific Standard Time); General preferences
G21
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X160.00 Y160.00 Z400.00 E123.00:123.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z1800 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout;C drive specific instructions
M584 C5 ; Axis mapper
M208 C0:240 ; Axis limits
M92 C200
M350 C16 I1
M566 C2 ; Set maximum instantaneous speed changes (mm/min)
M203 C10000 ; Set maximum speeds (mm/min)
M201 C500 ; Set accelerations (mm/s^2)
M906 C500 ; Set motor currents (mA) and motor idle factor in percent
;M574 C1 S3 ; Stall detect coupler at low end of its range
;Stall Detection
M915 C S5 F0 H200 R0; Axis Limits
M208 X330 Y270 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
M574 Y1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io1.in
M574 Z1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !io2.in; Z-Probe
M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
M557 X25:300 Y25:250 S50 ; define mesh gridG4 S1 ;wait for expansion boards to start
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out0" T0
; create bed heater output on out0 and map it to sensor 0
M307 H0 R0.502 K0.271:0.000 D7.19 E1.35 S1.00 B0
;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
;M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin 121.temp0
;M950 H1 C"out2" T1
;M950 H1 C"out1" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
M307 H1 R2.028 K1.010:0.000 D7.72 E1.35 S1.00 B0 V27.2
;M307 H1 R0.531 K2.006:0.000 D3.90 E1.35 S1.00 B0 V12.1 old version
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"out8" Q500 ; create fan 0 on out7 and set its frequency
M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
;M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
;M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0 S"T0" ; define tool 0
G10 P0 X-9 Y39 Z-7.5 ; set tool 0 axis offsets
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C;deselect tools
T-1; Custom settings are not defined
@rister502dad Fan 0 on out8 is set as a thermostatic fan so it will only turn on when the hotend is above 45C, however you have an S0 in there which is either invalid or will prevent it turning on at all.
; Fans M950 F0 C"out8" Q500 ; create fan 0 on out7 and set its frequency M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m106-fan-on
