M671 like function for Delta printer
@tecno
Apologies.
Should have had the filename in both echo commands.echo >"0:/sys/savedData.txt" G30 S-1 ; do probe at current point echo >>"0:/sys/savedData.txt" "Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
No reason to apoligise, I am thankful for all help I can get.
Now I get these values in txtfile, they also show up in console but nothing can be done there.
How to save the file so it can be exported as CSV directly from console. -
@tecno
I'm not sure I understand what you are looking for.
The use of the echo command is detailed here
https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-commandIf you want each probe point on a single line then use three > symbols
echo >"0:\sys\testFile.csv" "Test1,Test2,Test3,Test4,Test5," while iterations < 5 G30 S-1 echo >>>"0:\sys\testFile.csv" move.axes[2].machinePosition ^ ","
The resulting file will be something like
Test1,Test2,Test3,Test4,Test5, 1.388,1.595,1.595,2.015,2.213,
Error: in file macro line 8 column 8: meta command: expected string expression
@tecno said in M671 like function for Delta printer:
None of the macro extracts you've posted in teh thread recently even have an eighth line. What does line 8 of the macro file say?
echo >>>"0:\sys\testFile.csv" ^ move.axes[2].machinePosition ^ ","
@tecno https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command says >>> is only supported in firmware 3.5beta2 and later, what are you running?
@achrn
3.4.5 and nobody has said this before.It runs now but still I need to get correct syntax for the csv file for all results on same line.
echo >>"0:\sys\testFile.csv" {move.axes[2].machinePosition} ,","
point1,point2,point3,point4 0.858 , 0.824 , 1.322 , 0.821 ,
@achrn
3.4.5 and nobody has said this before.Well, it's been in the docs a while, I think.
I don't think you can, working it in a loop like that. you could dump the loop and do five separate probes storing in single variables then write to file with a single line, I think. e.g.
G30 S-1 ; probe set var.z1 = move.axes[2].machinePosition ; memorise probe position G30 S-1 set var.z2 = move.axes[2].machinePosition G30 S-1 set var.z3 = move.axes[2].machinePosition G30 S-1 set var.z4 = move.axes[2].machinePosition G30 S-1 set var.z5 = move.axes[2].machinePosition echo >>"0:\sys\testFile.csv" "whatever", var.z1, var.z2, var.z3, var.z4, var.z5
OK, will play with your suggestion and see the results.
M98 P"0:/macros/test var.g" Stopped at height 0.708 mm Error: in file macro line 7 column 13: meta command: unknown variable 'z1'
G28 M562 ; clear any bed transform from mesh leveling G90 ; absolute positioning G1 Z50 F4000 G1 X0 Y0 ; 1 point G30 S-1 set var.z1 = move.axes[2].machinePosition G1 Z50 F4000 G1 X-154 Y-164 F4000 ; 2 point G30 S-1 set var.z2 = move.axes[2].machinePosition G1 Z50 F4000 G1 X-63 Y214 F4000 ; 3 point G30 S-1 set var.z3 = move.axes[2].machinePosition G1 Z50 F4000 G1 X217 Y-52 F4000 ; 4 point G30 S-1 set var.z4 = move.axes[2].machinePosition G1 Z50 F4000 echo >>"0:\sys\testFile.csv" "whatever", var.z1, var.z2, var.z3, var.z4 G28
Well yes, you need to initialise the variables.
var z1 = 0 var z2 = 0 var z3 = 0 var z4 = 0 var z5 = 0
before you first refer to any of them.
@achrn said in M671 like function for Delta printer:
Works like a charm now!
Is there a way to replace "whatever" with date + time?
echo >>"Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
Should be:
echo >>"0:/sys/savedData.txt" "Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
i.e. you need to specify the filename again.
Instead of using move.axes[2].machinePosition I suggest you use sensors.probes[0].lastStopHeight as I suggested earlier.
This is what works now, only missing part is date/time stamp.
; test var.g macro datetime 0.758 1.074 1.122 0.821 datetime 0.708 1.074 1.022 0.771
G28 var z1 = 0 var z2 = 0 var z3 = 0 var z4 = 0 M562 ; clear any bed transform from mesh leveling G90 ; absolute positioning G1 Z50 F4000 G1 X0 Y0 ; 1 point G30 S-1 set var.z1 = sensors.probes[0].lastStopHeight G1 Z50 F4000 G1 X-154 Y-164 F4000 ; 2 point G30 S-1 set var.z2 = sensors.probes[0].lastStopHeight G1 Z50 F4000 G1 X-63 Y214 F4000 ; 3 point G30 S-1 set var.z3 = sensors.probes[0].lastStopHeight G1 Z50 F4000 G1 X217 Y-52 F4000 ; 4 point G30 S-1 set var.z4 = sensors.probes[0].lastStopHeight G1 Z50 F4000 echo >>"testFile.csv" "datetime", var.z1, var.z2, var.z3, var.z4 G28
echo >>"testFile.csv" state.time, var.z1, var.z2, var.z3, var.z4
Is there a way to format output to 0,000 and not 0.000 as this is a language problem?
@tecno if the format is CSV then you must use '.' as the decimal separator character, because ',' is used to separate one field from the next. The program you use to import the .csv file should recognise '.' as the decimal separator.
@dc42 said in M671 like function for Delta printer:
I use LibreOffice Calc in Swedish and the import is now in TEXT mode with '.' and needs to be in NUM mode with ',' to work OK
As you can see only fields with NUM values can be used for calc and that is with comma. Field separator should be something else to be imported correctly.
@tecno I suggest you import in CSV mode instead and change the macro to insert commas between the fields.
