Solved Vibrations when printing arcs after FW update
I wanted to test input sahping and had to update my firmware for this to 3.4.5. Before that I had a version running below 3.3. I'm not sure anymore, something with 2.x.
Since the upgrade, I now have a problem printing circles and arcs. Whether the radius is very large or very small, the printer starts to hum extremely, as if it stops for a millisecond between each segment. The print result looks accordingly. Input shaping is not activated.
Is it possible that this is due to the new firmware? Is there perhaps some function that recognizes curves and can lead to such problems? -
Can you share your config.g and a photo/video example of what you're talking about?
I have found the problem. It was not the firmware, but my settings. As a test, I had set the j**k for the frequency measurement to 0. Now everything works again
@Jorge thanks for updating us.
