3.5.0b1+ Wifi error - SPI timeout
@OwenD
So nearing the end of my next print and I lost DWC connection.
Inspection of the machine shows the print still running but the same error messages flashing on the screen.
This time I was able to connect via USB and get an M122 report with it still running.
I should note that this machine has been in the same spot for > 2 years and this error has only just started since 3.5.0
The poor signal has always been there, but the behaviour is new.
I was able to send
M552 S-1 M552 S1
from YAT to restart itError: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout M122<CR> === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2023-01-10 20:40:02) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 1 of 26 (26 max) === RTOS === Static ram: 22188 Dynamic ram: 80056 of which 132 recycled Never used RAM 6368, free system stack 88 words Tasks: NETWORK(notifyWait,36.7%,216) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.6%,305) Move(notifyWait,31.7%,281) MAIN(running,25.4%,460) IDLE(ready,5.6%,30), total 100.0% Owned mutexes: WiFi(NETWORK) USB(MAIN) === Platform === Last reset 10:13:44 ago, cause: power up Last software reset at 2023-01-12 15:51, reason: User, GCodes spinning, available RAM 6048, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x0c Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 26.8, current 28.2, max 29.8 Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/20, heap memory allocated/used/recyclable 2048/1580/1192, gc cycles 360 Events: 1 queued, 1 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: ok, SG min 0 Driver 4: ok, SG min 279 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-01-13 07:38:31 Cache data hit count 4294967295 Slowest loop: 146.73ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 10.9ms, write time 74.4ms, max retries 0 === Move === DMs created 83, segments created 51, maxWait 7093ms, bed compensation in use: mesh, comp offset 0.000 next step interrupt due in 15 ticks, disabled === DDARing 0 === Scheduled moves 1265796, completed 1265793, hiccups 0, stepErrors 0, LaErrors 0, Underruns [516, 1, 363], CDDA state 3 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.5 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X28.99 Y125.475 E0.06689" in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is doing "G4 S2 " in state(s) 0 0, running macro Autopause is idle in state(s) 0 Q0 segments left 1 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 121.70ms; fastest: 0.07ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 0 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 5, noresp 7705 Error: failed to retrieve WiFi status message: SPI timeout Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 ok Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout
@OwenD said in 3.5.0b1+ Wifi error - SPI timeout:
Slightly off topic, but what does this line mean?
i.e. What are under-runs and does this value signify an issue of some sort I should be looking into? -
@OwenD are you running the original 3.5beta1 binary or the version with the G32 fix linked to at https://forum.duet3d.com/post/303514 ?
Good question.
It looks like I still have one I compiled from source a few days ago.
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta1+ (2023-01-10)
I haven't made any changes, so I presume it will have the fixes you mention.
I can upload the last release if it will make it easier to track. -
@OwenD that depends on when you pulled the source files from github.
@dc42 said in 3.5.0b1+ Wifi error - SPI timeout:
It would have been the same day, but I'll revert and run another print just to be sure.
@OwenD
I've run several prints with no re-occurrence of this issue, so I'll mark this as solved.
If it crops up again, I'll re-visit. -
Came home from work today to find this had re-occurred.
The printer has been idle for several days apart from some macro debugging last night.
When it occurs the PanelDue is flooded with error messages at a very high rate.
Connected by USB and got an M122 report.ror: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2022-12-31 17:10:26) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 1 of 26 (26 max) === RTOS === Static ram: 22148 Dynamic ram: 79236 of which 216 recycled Never used RAM 4712, free system stack 192 words Tasks: NETWORK(notifyWait,37.1%,233) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.6%,330) Move(notifyWait,0.1%,362) MAIN(running,60.8%,331) IDLE(ready,1.6%,30), total 100.0% Owned mutexes: WiFi(NETWORK) USB(MAIN) === Platform === Last reset 23:57:15 ago, cause: software Last software reset at 2023-01-19 19:22, reason: User, GCodes spinning, available RAM 8228, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 27.3, current 29.4, max 34.3 Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no Heap OK, handles allocated/used 297/195, heap memory allocated/used/recyclable 4096/3648/484, gc cycles 89 Events: 0 queued, 0 completed Driver 0: ok, SG min n/a Driver 1: ok, SG min n/a Driver 2: ok, SG min n/a Driver 3: ok, SG min n/a Driver 4: ok, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-01-20 19:19:46 Cache data hit count 4294967295 Slowest loop: 97.05ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 4.8ms, write time 131.9ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 523.09ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 0 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 5, noresp 775826 Error: failed to retrieve WiFi status message: SPI timeout Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 ok Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout Error: failed to retrieve WiFi status message: SPI timeout
@OwenD before you reset could you try activating wifi debugging over USB?
M111 P14 S1
@jay_s_uk
Will do.
Not sure how long it will take before it will occur again. -
@OwenD also it would be helpful to get a summary of how (in)frequently this occurs and confirmation of the firmware and wifi firmware versions running.
@OwenD version 2.1beta2 of DuetWiFiSocketServer has been replaced by 2.1beta3 available at https://github.com/Duet3D/WiFiSocketServerRTOS/releases/tag/2.1beta3.
I'm afraid I haven't been able to reproduce this and I can't determine one factor that has "fixed" it.
I do have a few observations.
I used to get the occasional message on PanelDue that said that the WiFi had been successfully reconnected.
This is a modal message, so it could have happened at any time and I wouldn't see it until I went to the shed.
My wifi signal in the shed has always been around -51db, not horrible, but not great either.
After this issue arose, I went and got a wifi range extender.
This boosted the signal to around -41 to -44db
Note: That I hadn't had a re-occurrence BEFORE I put the extender on.
I don't know what signal I showed with 2.1beta2 as it didn't report it.I just installed 2.1beta3
My first M122 showed a signal of -36db with the extender!= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 39380 WiFi IP address 192.168.1.163 WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
I then went back in versions and did reports on each, both with and without the extender.
No extender
= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 2097152, free heap 39440 WiFi IP address 192.168.1.163 WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
No extender
= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 4194304, free heap 23776 WiFi IP address 192.168.1.163 WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
No extender
= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 2097152, free heap 40992 WiFi IP address 192.168.1.163 WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
With extender
= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 2097152, free heap 38844 WiFi IP address 192.168.1.163 WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
I'm not sure how the firmware version can increase the signal so dramatically?
I'm inclined to mark this as solved again simply because I can't repeat it reliably, so if nobody else is complaining it's not worth chasing.
@OwenD thanks for reporting this. Versions 1.x and 2.x of the WiFi firmware use different versions of the Expressif SDK. I guess either one of those SDK versions is mis-reporting RSSI, or they have changed the interface and we didn't pick that up. I will check the version 2.x code.
So for some reason this has reared it's head again a couple of times lately.
My system has a 5v power supply which powers the duet and switches a 24 volt power supply via the ATX pin as required.
Before resetting I ran M111 P14 S1, then M122
YAT seems to have dumped that report due to the volume of lines added, so I've only got the report immediately after restarting.For some reason the MCU voltage shows a very low value until I run M80 and kick the 24v power supply into action. Not sure if that's related.
It does the same regardless of this wifi anomaly.Error: failed to retrieve WiFi status message: SPI timeout ResponseTimeout, pending=1 ESP reported status change ResponseTimeout, pending=1 Error: failed to retrieve WiFi status message: SPI timeout ResponseTimeout, pending=1 ESP reported status change ResponseTimeout, pending=1 Error: failed to retrieve WiFi status message: SPI timeout ResponseTimeout, pending=1 ESP reported status change ResponseTimeout, pending=1 Error: failed to retrieve WiFi status message: SPI timeout M111 P14 S1 Debugging enabled for modules: WiFi(14 - 0xffffffff) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Dda(6) unused1(7) unused2(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) Can(17) M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta2+ (2023-02-12 12:52:31) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 1 of 26 (11 max) === RTOS === Static ram: 22216 Dynamic ram: 79456 of which 12 recycled Never used RAM 8284, free system stack 184 words Tasks: NETWORK(ready,10.9%,377) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,361) MAIN(running,87.9%,502) IDLE(ready,1.1%,30), total 100.0% Owned mutexes: WiFi(NETWORK) USB(MAIN) === Platform === Last reset 00:01:21 ago, cause: power up Last software reset at 2023-02-15 03:34, reason: StuckInSpinLoop, Platform spinning, available RAM 7040, slot 0 Software reset code 0x4080 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20003014 Task NETW Freestk 488 ok Stack: 00414fdf 00459cc2 010f0000 e8000000 400985ff 41c475a6 3edb9368 3331bb4c 40000000 b5ddd8b0 388ab355 bb360b61 3e2aaaab 3f800000 3f800000 41d94ba3 4354c416 41200000 3f800000 80000010 00414fa5 b5ddd8b0 388ab355 20010fbc 3e2aaa01 3f800000 20011248 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 29.3, current 33.6, max 33.8 Supply voltage: min 0.3, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/384/116, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min n/a Driver 1: ok, SG min n/a Driver 2: ok, SG min n/a Driver 3: ok, SG min n/a Driver 4: ok, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 1970-01-01 00:00:00 Cache data hit count 3368987419 Slowest loop: 7.82ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 7.76ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 0 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.39, reset reason Power up WiFi flash size 2097152, free heap 45652 WiFi IP address 192.168.1.163 WiFi signal strength -29dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 ok WiFi: <ESC>[0mConns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
Some more info this morning.
Normally I discover this problem either when I walk out to the garage to get a beer and see the PanelDue flashing ans SPI error, or I can't connect to DWC.
This morning I opened my phone (to a previously open tab) and DWC was frozen.
When I tried refreshing, it just said connecting and that the drive wasn't mounted.Suspecting an SD card issue, I checked the PanelDue wasn't displaying any errors.
Sending M20 resulted in a normal listing, so the SD card has to be mounted.
Maybe this is a red herring?
DWC from my laptop just doesn't connect. "Can't find host"M20 Begin file list random-moves-test.g Outer_Trays_0.2mm_PLA.gcode freak_Pin_0.14mm_PA-CF.gcode Inner_Trays_0.2mm_PLA.gcode SKEW_100mm_0.2mm_PLA.gcode cube_0.2mm_PLA.gcode Freak body large skirt_0.2mm_PA-CF.gcode YACS_0.2mm_PLA.gcode calibration_0.2mm_PLA.gcode monitor-pad-right_0.2mm_PLA.gcode calibration piece _0.2mm_PLA.gcode Box1_0.2mm_PLA.gcode EspChunky_0.2mm_PA-CF.gcode pump-filter_0.2mm_PA-CF.gcode End file list
If I send M111 P14 S1, I immediately get a barrage of busy responses in YAT .
M111 P14 S1 Debugging enabled for modules: WiFi(14 - 0xffffffff) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Dda(6) unused1(7) unused2(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) Can(17) ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy ResponseBusy M111 S0 ok
If I try to do a network scan I get this
M587.1 Error: M587.1: failed to start scan: another SPI transfer is pending
Can you try flashing back to 1.27 and seeing if this still happens? If so, I think it may be the module.
@Phaedrux
Can't rule out a hardware issue I guess.
Have reverted back to 1.27 and will monitor.
I did an M122 before and after the change.
This is the network section. Note the not ready number and lack of IP address.=== Network === Slowest loop: 29273.09ms; fastest: 100.43ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 0 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 42217, noresp 1 Failed to get WiFi status Socket states: 6 0 0 0 0 0 0 0
After reverting and restart.
= WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 2 WiFi firmware version 1.27 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 4194304, free heap 24848 WiFi IP address 192.168.1.163 WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Hi, I have also been getting instability issue with the wifi since going to 3.5.0b1.
The duet will drop off from the network midprint or even not connect at all unless i power it down and then back up.
@StreetFurnitureAustralia
Are you getting the same SPI timeout messages noted in this thread?
Can you connect via USB and grab the same reports as above?
My error is quite random and very specific.
It has not reappeared since rolling the wifi back to 1.27 but it only happened occasionally so I'm not ready to say it's definitely firmware yet.
