48V Duet3(4?) to complement future Duet Motors?
If it isn’t in the plan, just wanted to plant the seed - it’d be great to have a 48V mainboard to compliment the upcoming duet motors! Running off of a single power supply would be nice, although I can see the point if not having compatible hot end heaters and whatnot.
@TLAS it already exists: Duet 3 MB6HC version 1.02.
When making the Duet 48V capable, what was the anticipated use case? Was it just for CNC purposes?
I can see how 48V would be nice for motors but what do you do for hot end heater cartridges. in 3D printers? I have only seen those in 12V and 24V. Do people end up generating 24V externally just for the heaters?
Are there plans for a 48V 1LC tool board? -
@jens55 for people who want to run motors at higher speeds, they benefit from the higher voltage. I believe there are already 48V heating cartridges available from a few suppliers and we support using 12V fans from the onboard 12V power supply.
At this point we don't expect a large demand for tool boards in their current formfactor to need to run at 48V.
Larger machines (the normal use case for 48V) often need multiple power supplies anyway so i expect some configurations for both 24V and 48V in that case
@T3P3Tony When this new Duet motors will be available?
Thanks! -
@juliann we are aiming for Q2 for the first of the range.
@T3P3Tony Thanks, that's great, where can I get more information about them? is a brochure available?
@juliann I will announce more on the forum when its available.
@jens55 said in 48V Duet3(4?) to complement future Duet Motors?:
In config.g you can reduce the power for a 24V heater cartridge to 0.5. That's what was done in early FDM days, when the 24V controller boards where new and 12V cartridges were the only available ones.
@o_lampe but thats definitely NOT recommended as you're still feeding 48v to the cartridge!!!!
@jay_s_uk The heater is just a resistor with a max. power value.
It doesn't care about voltage so much when the duty cycle is limited to 50%.
Maybe PID tuning is difficult? -
@jens55 it's possible to buy 48V cartridges to fit hot ends that use cartridges.
@dc42 I would still suggest to get more current on the 12V rail in a future revision, BTT boards like the Octopus allow 4 / 8 A on 12V.
@oliof we'd like to do that but it's expensive to generate 12V from 48V and also difficult to meet FCC and CE EMC regulations. I don't think any other boards support 48V input without requiring a separate 24V input to power the lower voltage components.
@dc42 thats correct. all the other boards require a 24v input to generate the lower voltages with 48v only used to drive the motors
@oliof I agree about ohm's law telling us to use only 25% duty cycle. My mistake!
I've use a 12V bed heater at 24V without problems using this method, but overpowering a cartridge might be a different story.
Just wanted to point out, that a resistor doesn't have a voltage limit per se. -
@jay_s_uk
What about using a big 24V PSU and feed the motors from a DC-DC boost converter?
I'm using a few different boost converters for several tasks and they never failed me so far. ( 100W - 600W are cheaper than a second PSU) -
@o_lampe that may work assuming the boost converter and PSU can handle it.
For my voron 2.4 i went with a separate 48v PSU. The LRS-200-48 aren't very expensive https://www.printyplease.uk/LRS20048?search=48v
