SAMMYC21 ERCF
@Th0mpy you could try the Duet3Expansion 3.5 source together with the 3.5 source for CANlib and CoreN2G. It has about 200 bytes more RAM available.
You could also reduce the sizes of the debug UART transmit and receive buffers in file Hardware/SAME5x_C21/SAMC21/Devices.cpp. They are currently both set to 512 bytes, which is much larger than necessary.
PS - I've just reduced those buffer sizes in the 3.5-dev source code.
This is great!
From a hardware perspective I just have the two steppers, ir switch, servo, and endstop. There is another unused output but not tied to anything yet.
I will give that a try this evening.
I appreciate the pointers!
@dc42 That seemed to fix it. Just updating alone to 3.5 was enough to handle the filament sensor, but when I enabled the end-stop it crashed again. I had to reduce a little further so I also reduced buffer sizes for UART.
Everything works together now. Thank you for your help! I have a bunch of manual macros working now so I just need to automate it all.
If you decide to undertake the ERCF, hit me up. I have a few boards that I made. You can't buy just one. I also made some adjustments (manually) to the board to solve the servo issue experienced by some.
I'll post about it later in another thread once I get it a little more automated.
@Th0mpy are you using the ERCF sensor under the extruder?
@jay_s_uk Not at the moment. I am only using the 1/2 bondtech gear in the ERCF itself for confirmation of bowden distance to load the extruder.
I am thinking of adding a sensor in the extruder to simplify, but there is no eloquent way to add a reliable filament sensor (i.e. magnetic filament monitor) to the stealthburner yet. They do have a simple switch sensor but I really don't like the washer approach.
That said, I am playing with the laser filament monitor, which would fit into the stealthburner nicely. It does not, however, work as well with the PET filament. I did contact the manufacturer to get their specs and programming guide for the sensor, but I haven't had time to play with it yet.
@Th0mpy it may be worth looking into https://reprap.org/forum/read.php?424,889788
@oliof Good ole Forest Mimms, I had a few of his books from Radio Shack when I grew up.
I will have to check this out, I was considering something like that but was leaning towards something already manufactured. This is cool!
@oliof
That is cool.
Have you integrated it on RRF?
If so, can you detail it (in a new post)? -
@OwenD Of course! I plan to share what I have this weekend(ish). I'll post a new thread on the subject.
@OwenD I have not built that myself, nor integrated into RRF. I am just reading that section of the venerable reprapforum and sometimes interesting stuff comes up.
@OwenD Did you make a new Post? I am soldering my own canned ercf board now. Can you share the firmware card you used?
@VoodooBane
I think you need to ask @Th0mpy
I'm just an onlooker -
Hey thompy, Do you have any of the boards still? I would like one from you if you do
@Gixxerfast I sourced a bunch of the SMD components myself. However, it looks to be that some components are missing from your Excel document. I didn't think to look for whatever reason before buying components.
The components you did not include in the Excel sheet and what I am missing.
D1, D2
C3, C4, C6
R8, R11, R12, R13, R14, R15, R16, R17, R18, R19I really hope I am not screwed...
See my screenshot.
@VoodooBane I was actually able to find what the components where in Kicad.
@VoodooBane Hey there, sorry for the delay. I might have a couple left, let me know if you're still interested.
@OwenD Haven't touched it in a hot minute, but as I recall that I had a custom firmware to handle the two steppers. Are you still looking for this?
EDIT: I found the firmware I used, it was the one originally from @Gixxerfast , you'll need to compile it: https://github.com/gixxerfast/Duet3Expansion/tree/cannedboard
I need to look at the settings, so I get emailed when someone responds; sorry about that.
I might be interested. I would like to see if I soldered correctly. (it is my first SMD DIY project)
But I would like another one since it is going on an Idex printer if I want to go super extreme, lol.Do you know if @gixxer is planning to make a more modern firmware? That latest is 3.4 from what I remember on Gixxer's GitHub and the new stable release for duet is 3.46
@VoodooBane I don't know, I haven't seen them online for quite some time. It's pretty simple, however, to update and compile the firmware. To be honest it's been a hot minute since I touched it last.
I was looking around for someone else and either I sold them all or completely lost them in my shop
I am considering a new order of them, if I get enough interest it would push my decision up a notch.
