Extruder motor not working.
@jfavre said in Extruder motor not working.:
Heater 1 fault: temperature rising too slowly: expected 2.36°C/sec measured -0.00°C/sec
When you try to heat does the LED near the heater terminal actually turn on? Can you see any rise in temp on the graph before it faults? Have you double checked the wiring for the heater cartridge? Check the resistance of the heater with a multimeter?
I did test motor by plugging it into the x axis channel "driver 0"
And does it work there?
@Phaedrux my apologies, yes the extruder motor did work in the x axis. I will check the led. There was no change in temperature.
Ok if the motor is confirmed working, then at least cold extrusion should allow it to extruder as long as the tool is actually selected.
So please send
T0
andM302 P1
and then see if you can sendG1 E1 F100
to make the extruder motor move slightly.The heater issue appears to be separate.
@Phaedrux said in Extruder motor not working.:
G1 E1 F100
Tried as suggested and received the following error. I have checked phasing by shorting the coils at the connector that attaches to the board and seem fine.
1/1/2023, 1:03:46 PM Warning: Driver 0.3 warning: phase A may be disconnected, phase B may be disconnected
M302
Just got the extruder motor to work with G1 E1 F100 andG1 E-1 F100. Still no luck with Extrusion Control jogging buttons.
So are you still getting phase errors, or is that resolved?
Send
T0
in the gcode console and check the buttons again. -
Is the heater up to temperature? By default cold extrusion is disabled and the extrusion buttons in DWC are deactivated.
@dc42 found connection issues with ribbon cable and pcb, new one on order. Then we move forward.
@Phaedrux the phase issue is resolved. Found other connection issues. New pcb on order.
After replacing PCB managed to get everything up and running. Just need to find settings for Slice Engineering 300c thermistor, the temp reading slightly higher than actual measured with an TC thermometer. It was type 5 in marlin.
According to this document, you need to use the following in your M308
T100000 B4680 C6.455513e-8
@OwenD awesome! Thanks, l will try tomorrow.
undefined jfavre marked this topic as a question
undefined jfavre has marked this topic as solved
