No fans!
@tecno
What were you trying to do when you got that error?The Fan code is exactly the same as mine (except I've only got two)
Tried just use the slider for the ony fan that is there
@tecno The error message seems clear enough to me : You need to define a fan id by adding Pxxx for each M106
See https://docs.duet3d.com/User_manual/Reference/Gcodes/M106 -
@Falcounet
What have I missed, because it looks like that's exactly what he's done? -
There is a P0 for the fan need to be gcode controlled or am I missing something
M950 F0 C"out5" Q500 ; Parts cooling,create fan 0 on pin out5 and set its frequency M106 P0 S0 H-1 ; set fan 0 value = Gcode controlled. Thermostatic control is turned off
The two other fans have P designations too but to be run continiously.
@Nightowl You are right, I was mixing the M950 and M106 lines
@tecno
What version of RRF are you running? -
@Exerqtor
Board: Duet 3 Mini 5+ (Mini5plus)
Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0 (2022-03-15)
Duet WiFi Server Version: 1.26Downloaded today
@tecno Post your complete config.g file so we can see the full configuration you are using.
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Jan 07 2023 12:09:54 GMT+0100 (centraleuropeisk normaltid) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Voron01" ; set printer name M669 K1 ; select CoreXY mode M918 P1 E4 F2000000 ; configure direct-connect display ; Network M551 P"bengt" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards using default driver timings M569 P1 S1 ; physical drive 1 goes forwards using default driver timings M569 P2 S1 ; physical drive 2 goes forwards using default driver timings M569 P3 S1 ; physical drive 3 goes forwards using default driver timings M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E690.00 ; set steps per mm M572 D0 S0.10 ; PA M566 X100.00 Y100.00 Z100.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X5000.00 Y5000.00 Z2600.00 E7200.00 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z1500.00 E800.00 ; set accelerations (mm/s^2) M906 X1250 Y1250 Z400 E800 I25 ; set motor currents (mA) and motor idle factor in per cent M207 S1.5 F7200 Z0.2 M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X120 Y120 Z120 S0 ; set axis maxima ; Endstops M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io3.in ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:120 Y15:120 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R1.145 K0.757:0.000 D3.50 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M140 H1 ; map toolhead to heater 1 M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"out5" Q500 ; Parts cooling,create fan 0 on pin out5 and set its frequency M106 P0 S0 H-1 ; set fan 0 value = Gcode controlled. Thermostatic control is turned off M950 F1 C"out0" Q500 ; Toolhead cooling, create fan 1 on pin out0 and set its frequency M106 P1 S1 H-1 ; set fan 1 value = always ON. M950 F2 C"out6" Q500 ; Drivers/CPU cooling, create fan 2 on pin out6 and set its frequency M106 P2 S1 H-1 ; set fan 2 value =always ON. ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
@tecno What version of DWC are you using? Can you run M98 P"config.g" and post any output. It looks like you may not have a tool selected, so you may need to add T0 at the end of your config.g.
@gloomyandy
2023-01-07 19:32:13 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23 -
What is going on, now next wierd thing, Output 2 toolhead and bed has same Heater name and temp
@tecno
This seems irrelevant to your issue, but the error I get (on my disconnected-from-everything test board) when I run M98 P"config.g" is this:07/01/2023, 18:42:49 M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: in file macro line 53 column 13: M106: expected number after 'H' Tool 0: offsets X0.000 Y0.000 Z0.000
Which is the last line on this block from the config.g file:
; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on
...showing an error with H - but this is how the RRF Config tool produced the file.
How weird!
Looks OK and familiar
