CONSTANT AJAX disconnect errors
I'm not sure if it adds anything to this discussion, but I have an ethernet Duet. I have used different routers and switches and always had disconnects. Its the only thing about this wonderful board that is annoying. I use curl to upload from S3D and it works 100% of the time even when the web interface won't connect.
I keep hoping new firmwares will make it better, but not yet. It seems better on some firmwares, but its hard to tell if thats just me. It seems to help to disconnect the ethernet and reconnect.
Do the disconnections happen only during printing, or at any time? If they happen only during printing, then next time you get a disconnection during a print, after the print finishes please run M122 and report the MaxReps value in the report. Note, MaxReps is cleared each time you run M122 so only the value you get the first time you run M122 after a print counts.
Last night i finally had time to setup the separate router and connect the Duet to it. Very basic setup. network with WPA2 encryption, dhcp IP, no internet access, and no other devices connected to it. Its a rather annoying way to test because I have to switch back and forth networks from my computer, but I may pull an old junk laptop out to do some extended testing.
I'm now getting AJAX errors while the unit just sits there, idle. I can power cycle the printer and it comes back online, but it goes offline again after I connect.
I tried resetting the router, which is literally 6 feet away from the printer. No difference.
So, when you get the AJAX disconnect, you can not click "Connect" in DWC or reload the page to get back connected?
Can you reconnect without a power cycle by sending M552 S0 (or S-1), followed by M552 S1 via USB?
M122
Used output buffers: 3 of 32 (6 max)
RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
Board ID: 08DDM-9FAM2-LW4SD-6J9D6-3SN6L-12ZHY
Static ram used: 21176
Dynamic ram used: 95976
Recycled dynamic ram: 1632
Stack ram used: 1304 current, 4880 maximum
Never used ram: 7408
Last reset 00:12:06 ago, cause: power up
Last software reset reason: User, spinning module GCodes, available RAM 3192 bytes (slot 2)
Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 26.1, current 34.9, max 36.7
Supply voltage: min 11.4, current 12.1, max 12.5, under voltage events: 0, over voltage events: 0
Driver 0: standstill
Driver 1: standstill
Driver 2: standstill
Driver 3: standstill
Driver 4: standstill
Date/time: 2017-11-06 13:50:27
Slowest main loop (seconds): 0.005554; fastest: 0.000034
MaxReps: 8, StepErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 4122ms, Underruns: 0, 0
Scheduled moves: 4, completed moves: 4
Bed compensation in use: none
Bed heater = 0, chamber heater = -1
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
Network state is running
WiFi firmware version 1.19
WiFi MAC address 2c:3a:e8:0a:f1:18
WiFi Vcc 3.08, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 39528
WiFi IP address 192.168.0.22
WiFi signal strength -77dBm
Reconnections 0
HTTP sessions: 1 of 8
Socket states: 2 0 0 0 0 0 0 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0AJAX ERROR did not connect printer to the web page
I've put a temporary build (1.20beta6) of DuetWiFiServer.bin at https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1. This version uses the latest SDK from Expressiv and includes a fix for the WPA2 KRACK vulnerability. It may or may not help with reliability of the WiFi connection. I've heard that the KRACK vulnerability fix may be incompatible with some routers.
I am doing further work on DuetWiFiServer to make additional diagnostics available.
David, does that build include the correction of the sleep mode?
Did the "disable sleep" make it in ?
No, I didn't want to try more than one thing at a time.
1:52:39 PM
Can't rename file or directory 0:/sys/DuetWiFiServer(1).bin to /sys/DuetWiFiServer.binFile gg_PLA_OPTIMAL.gcode selected for printing
FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01
1:52:39 PM
M32 gg_PLA_OPTIMAL.gcode
1:51:31 PM
M997 S1
WiFi Server Version: 1.20beta6 done i getting error for rename -
Try removing the (1) from the filename before you upload it. If that doesn't work, I suggest you go into the System Editor in DWC, rename or delete the existing DuetWiFiServer.bin, then upload again.
Thanks for replay I did and work let see i connect my laptop to duet wifi any error commigm after update.
M122
Used output buffers: 3 of 32 (17 max)
Dynamic ram used: 96072
Recycled dynamic ram: 1536
Stack ram used: 1304 current, 9096 maximum
Never used ram: 3192
Last reset 01:48:41 ago, cause: software
Last software reset reason: User, spinning module GCodes, available RAM 7408 bytes (slot 4)
Error status: 8
MCU temperature: min 32.4, current 32.7, max 33.4
Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
Driver 0: stalled standstill
Driver 1: stalled standstill
Driver 2: stalled standstill
Driver 3: stalled standstill
Date/time: 2017-11-07 14:10:11
Slowest main loop (seconds): 0.077148; fastest: 0.000000
MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 15, completed moves: 15
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.0
Segments left: 0
WiFi firmware version 1.20beta6
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 33368
WiFi IP address 192.168.0.144
WiFi signal strength -42dBm
Reconnections 0
HTTP sessions: 2 of 8
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) -
M122
Error status: 8
Segments left: 0
Reconnections 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)2:21:28 PM
Disconnected. AJAX error
2:23:29 PM
Error status: 8
Segments left: 0
WiFi IP address 192.168.0.114
Reconnections 0
Were you able to reconnect by pressing the Connect button in DWC, or not?
I try both way refresh F5 and connect button
Run time 20min to 30min max and get Ajax error -
Patel, a few more questions:
1. Have you worked through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
2. In the AJAX error message box, is the Error Reason always given as "timeout"?
3. After a disconnection occurs, are you able to ping the Duet?
KeeganB, I recall that you are getting disconnections more frequently when your printer is printing than at other times. Please can you try simulating some prints (this is a right-click option in DWC1.19.3) and see if connections are lost more frequently during simulations than when the printer is idle.
Patel, if you too have found that the connection is much less reliable when printing, please try this too.
Hey David,
I can test that. I need to email you, Roland, and Tony with some of my findings over the past few days. Ill try to type that up today.
Thanks
Error timeout. And I follow your wiki page also.
After error some time connect right way and some time I need press reset button get backI am tried to do this thing can you accept return.
I've noticed a difference between the M122 reports from KeeganB and patel when the wifi connection has been lost and DWC won't reconnect. KeeganB's report from some time ago had this:
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)Patel's more recent reports have this:
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)Patel's reports are intriguing, because HTTP state 1 should time out after 2 seconds if no data is received.
Patel, were M122 reports obtained by sending M122 from the USB port when DWC has disconnected? Or did you reconnect DWC and send M122 from DWC?
Also, did you have just one device (e.g. PC) connected to the Duet; or did you have a second device (e.g. smartphone, tablet or another PC) connected too, or a second browser tab?
