CONSTANT AJAX disconnect errors
Try removing the (1) from the filename before you upload it. If that doesn't work, I suggest you go into the System Editor in DWC, rename or delete the existing DuetWiFiServer.bin, then upload again.
Thanks for replay I did and work let see i connect my laptop to duet wifi any error commigm after update.
M122
Used output buffers: 3 of 32 (17 max)
RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
Board ID: 08DDM-9FAM2-LW4SD-6J9D6-3SN6L-12ZHY
Static ram used: 21176
Dynamic ram used: 96072
Recycled dynamic ram: 1536
Stack ram used: 1304 current, 9096 maximum
Never used ram: 3192
Last reset 01:48:41 ago, cause: software
Last software reset reason: User, spinning module GCodes, available RAM 7408 bytes (slot 4)
Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 8
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 32.4, current 32.7, max 33.4
Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
Driver 0: stalled standstill
Driver 1: stalled standstill
Driver 2: stalled standstill
Driver 3: stalled standstill
Driver 4: standstill
Date/time: 2017-11-07 14:10:11
Slowest main loop (seconds): 0.077148; fastest: 0.000000
MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 15, completed moves: 15
Bed compensation in use: none
Bed heater = 0, chamber heater = -1
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
Network state is running
WiFi firmware version 1.20beta6
WiFi MAC address 2c:3a:e8:0a:f1:18
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 33368
WiFi IP address 192.168.0.144
WiFi signal strength -42dBm
Reconnections 0
HTTP sessions: 2 of 8
Socket states: 2 0 0 0 0 0 0 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) -
M122
Error status: 8
Segments left: 0
Reconnections 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)2:21:28 PM
Disconnected. AJAX error
2:23:29 PM
Error status: 8
Segments left: 0
WiFi IP address 192.168.0.114
Reconnections 0
Were you able to reconnect by pressing the Connect button in DWC, or not?
I try both way refresh F5 and connect button
Run time 20min to 30min max and get Ajax error -
Patel, a few more questions:
1. Have you worked through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
2. In the AJAX error message box, is the Error Reason always given as "timeout"?
3. After a disconnection occurs, are you able to ping the Duet?
KeeganB, I recall that you are getting disconnections more frequently when your printer is printing than at other times. Please can you try simulating some prints (this is a right-click option in DWC1.19.3) and see if connections are lost more frequently during simulations than when the printer is idle.
Patel, if you too have found that the connection is much less reliable when printing, please try this too.
Hey David,
I can test that. I need to email you, Roland, and Tony with some of my findings over the past few days. Ill try to type that up today.
Thanks
Error timeout. And I follow your wiki page also.
After error some time connect right way and some time I need press reset button get backI am tried to do this thing can you accept return.
I've noticed a difference between the M122 reports from KeeganB and patel when the wifi connection has been lost and DWC won't reconnect. KeeganB's report from some time ago had this:
HTTP sessions: 1 of 8
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)Patel's more recent reports have this:
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)Patel's reports are intriguing, because HTTP state 1 should time out after 2 seconds if no data is received.
Patel, were M122 reports obtained by sending M122 from the USB port when DWC has disconnected? Or did you reconnect DWC and send M122 from DWC?
Also, did you have just one device (e.g. PC) connected to the Duet; or did you have a second device (e.g. smartphone, tablet or another PC) connected too, or a second browser tab?
1. I have put a build of DuetWiFiServer with sleep disabled (version 1.20beta7-nosleep) at https://www.dropbox.com/s/59s7vfkrf50fe0v/DuetWiFiServer-1.20beta7-nosleep.bin?dl=0. Please try it. The previous build (1.20beta6) is at https://www.dropbox.com/s/djs0p4beitjs60t/DuetWiFiServer-1.20beta6.bin?dl=0.
2. Patel, what make and model of wifi router are you connecting the Duet to?
David, I will try the beta7 build tonight.
Email sent.
Thanks
DC. It happens on my Ethernet Duet at idle and while printing. Tried different browsers and computers. Also WiFi and Ethernet connections. I saw you were concentrating on the WiFi server, so I wanted to let you know that might be the wrong direction! Love everything else about the board. Keep up the good work.
Oh you might want to put a warning out that Chinese Duets are out.
David
Just tried to install B7-nosleep and sorry to say it failed (FW Loads fine) when trying to diagnose this I sent the usual M552 S0 but got no response back send M552 S1 and get an error saying to stop the wifi before starting it and M552 reposrts WiFi starting (Reloaded the Server fw 3 times with the same results including copying direct to the SD Card and renaming etc).
so decided to try B6 which worked and loaded the Wifi almost instantly.
Hope this helps (Not that I was suffering the Disconnects anyway)
Doug
Any tips on what I should try. I have noticed I will get the Ajax Disconnect error at random times in a print. Sometimes it is when it is probing with the G32 command, and other times it can be actually printing. Mine will completely disconnect from the network and can't ping it or anything. I will have to wait for the print to finish and then turn it off and back on and it connects back immediately. The printer is in the same room as the router.
Loaded on my system. Got a message saying can't rename the file but then it went ahead and updated.
Wont be able to print to later but I can make it run through some large simulation files remotely. -
JavaScript Error
A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Script Error: See Browser Console for Detail
Received the above when i resized the browser window, reconnected when the "connect" button is pressed.
Then when i ran M122 and tried to copy the wifi section it disconnected with same errorM122:Network state is running
WiFi firmware version 1.20beta7-nosle
WiFi MAC address a0:20:a6:10:55:89
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 28552
WiFi IP address 192.168.2.34
WiFi signal strength -45dBm, reconnections 0, sleep mode none
No. One. Mention. The. Clones.
J/k pm where you have seen them
I thought I had some good google fu, but I can't find anything. Mythological creature, maybe?
