Duet not starting properly if SBC is not on
@kuon said in Duet not starting properly if SBC is not on:
If I start the PI, wait for it to boot, THEN start the duet, it works, but that's cumbersome because I would need a timed relay or something to sequence the power up.
Would it be possible to add a G4 S60 command at the beginning of config.g to wait a minute?
Or maybe toggle an IO pin on the PI after boot, which allows Duet to boot? (hold down Duet reset button or the like) -
@kuon the status LED being dim points to there being no firmware on the board.
Yes, everything is running 3.4.4
M122 reportAFAIK, you must run M122 for each board separately. You've only posted the mainboard status...
"Would it be possible to add a G4 S60 command at the beginning of config.g to wait a minute?"
@o_lampe The problem is that you can't read the config.g file if there is no SBC to provide it.... -
@o_lampe Yes, and they are all running 3.4.4. But when I tried to fix the issue, the toolboard where disconnected so I didn't think of including the M122 output.
I think the issue occurs even before the duet can start loading the config.g or anything. It just stays here.
I also tried pressing the reset button, but it doesn't do anything. Power cycling the duet fixes the issue and the duet connects to the SBC. But this doesn't help, as I would need to power up the duet after the SBC had booted, and this would require an additional timed relay.
@dc42 what is the duet looking for when booting to try to communicate with the SBC? Should a pin on the ribbon be pulled up and it arrives too late in my case?
I think I found the issue, my 5V power supply for my PI takes about 500ms to run to a steady 5V, but the Duet regulator is faster, (I clearly see a sequence in the LEDs) and what I think is happening is that the duet sees that the 5V pin for the PI is not at 5V and then ignores it (@dc42 might be able to confirm this).
I have removed the INT 5V EN jumper, and I am now providing the duet 5V from the power supply I use for the PI through the EXT 5V KK connector and the issue is gone.
@kuon The problem wit RasPi powersupplies is: they produce a little more than 5V. Just check out your'e not toasting the other 5V components with it.
@o_lampe It is a power supply I made myself to convert from 24V, and it has a regulated 5V output which I measured between 4.95 and 5.06V with my scope, so I guess it should be fine.
@o_lampe the Duet is quite happy with a little more than 5V such as the 5.2V typically provided by RPi PSUs. The absolute maximum is 6.5V or 7V AFAIR.
@dc42 Is the behaviour I am observing normal? I mean the duet ignoring the SBC if SBC's 5V comes a bit late after duet powering up.
