Duet mini 5+ freezes and shuts off heaters
@droftarts Yes, this is what I said in my previous statement to you. It is all the components on the board.
The chamber is heated by the bed and hotend. The reason why it prints petg and not the high temp nylon is because the chamber temp rises much higher with the higher temp plastics. Especially on very hot days. I realize now that I cannot print my higher temp plastics until I bring cold air in to cool the electronics.
A small update: The issue has nothing to do with heat of the chamber or the Duet 3 mini. After a ton of testing, I have narrowed the issue down around the extruder.
Exhausting all other tests, I decided to run a print cycle with no filament running through the extruder and it finished the print. I am able to print at high temperature with flexible Nylon, but the stiff carbon fiber nylon throws a reset.
I installed a new stepper and Bontech extruder. I will post results later.
10/25/2022, 1:15:28 AM m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus Ethernet (standalone mode) Board ID: 6MFQS-V096U-D65J0-40KMJ-JS03Z-R72JU Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 103684 Dynamic ram: 105204 of which 0 recycled Never used RAM 32752, free system stack 168 words Tasks: NETWORK(ready,25.9%,260) ETHERNET(notifyWait,0.3%,568) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,290) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,81) MAIN(running,72.1%,422) IDLE(ready,0.2%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last software reset at 2022-10-25 00:59, reason: User, GCodes spinning, available RAM 32752, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 101415, completed 101415, timed out 0, errs 0 Step timer max interval 1486 MCU temperature: min 41.6, current 42.2, max 43.3 Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 5298, writes 12, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2022-10-25 01:15:24 Cache data hit count 172505060 Slowest loop: 12.16ms; fastest: 0.13ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 1.0ms, write time 9.1ms, max retries 0 === Move === DMs created 83, segments created 3, maxWait 42811ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.6 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === CAN === Messages queued 909, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 506/0/0 Tx timeouts 0,0,505,0,0,402 last cancelled message type 30 dest 127 === Network === Slowest loop: 9.29ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 2 2 2 2 2 0 0 0
@nikscha
24 Oct 2022, 14:30
Printer runs perfectly without errors with no filament loaded. Petg, non-composite nylon, everything works. Yes my nozzle is grounded to the frame and Earth ground.I now have a Nema 17 x 48mm stepper on a Bontech extruder, pulling from 2.5Kg spool and pushing through 500mm of bowden tube.
Maybe there is too much friction with carbonfiber nylon?
Currently printing test cube with M92 E1.
@Michael-Hathaway said in Duet mini 5+ freezes and shuts off heaters:
If it works OK without filament, it does sound as though it is ESD. Have you checked with a multimeter that there is continuity between the hot end metalwork and Duet ground? Also check that the extruder motor body is connected to the same ground, in case it is the extruder motor building up ESD and flashing over to the phase connections.
Hello and thank you. Where on the Duet mini would be the appropriate place to place an earth ground?
@dc42 Is it safe use the 24v power supply ground on the board?
"At the power supply, you can also connect the DC - terminal to the earth terminal, that way any shorts on the low voltage side to the high voltage side will be shunted to ground as well. If you do this you need to be a bit more careful about ground loops when connecting via USB."
I made some progress.
Everything grounded, and verified. Still failed to print.
And then I purposely added load to the extruder and reproduced the failure. I didn't know that excessive pull force on the extruder, pulling from a large 2Kg spool would trigger a reset.
Increased current to 1200 fail, 1400 fail, 1600 and it almost finished the print. However, 1600 is beyond the capability of the mini 5, so I will have to find another solution to reduce pull resistance from the spool. Other materials work well, but not carbon fiber.
I will test some more and report back.
Larger internal diameter PTFE tube?
The surface texture of the carbon fiber materials is very rough. Lots of friction.
@Phaedrux Exactly.
So because this is Nylon CF I print from a sealed filament box, a big one that can handle up to 8Kg spools, my filament has to pass through bowden tubing before it reaches the print enclosure. I have obtained 6mm OD/ 4mm ID ptfe tubing with PC6 fittings.Also, normally my spools roll on rollers, which is fine because my rollers are 75mm in diameter. Larger rollers are a lower roller-to-spool ratio and less friction. But with this material, the system had too much resistance. So I built a center shaft mount in the enclosure for the larger spools, while still being able to use the convenience of the rollers for my other spools.
I am finally able to finish a print without failure. I lowered my motor current down to 1200ma. I know it sounds rediculous, but I am considering mounting one of my 60mm steppers to the bondtech extruder so that I can have increased torque with lower current draw from the drivers. I am not sure if this will work due to the 60mm stepper being 4 volts and higher impedance. However, I am not looking for speed out of the extruder stepper, just torque.
I thought I had this under control. The new ptfe larger tube made the pull resistance drop to nearly nothing. Still getting failures mid print. I even attempted to print with all of the enclosure doors open. Enclosure temperature 30C.
But it still succeeds with no filament loaded?
@Phaedrux I am not sure, let me try it again.
@Phaedrux Print finished, no errors. So... Too much resistance from the extruder to the hotend.
I ordered some Capricorn tubing, I don't have any in stock. And I had a good laugh while I was bolting on a 60mm super whomper to my extruder. I guess I should order input gear shafts. I am going to replace a few other things while I have the printer apart.
I took the whole hot end apart and there is no resistance for the filament. I replaced the extruder stepper with another new one, just in case. There has to be something wrong in my settings?
; Config.g ; Configuration file for Duet 3 Mini 5+ (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 23 2021 16:36:21 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Pulse E-423S" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; X-axis drive 0.0 goes backwards M569 P0.1 S1 ; Y-axis drive 0.1 goes forwards M569 P0.2 S1 ; Z-axis drive 0.2 goes backwards M569 P0.3 S0 ; Extruder drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm ; M566 X600.00 Y600.00 Z30.00 E270.00 ; set maximum instantaneous speed changes *(mm/min)(10x60=600) 'jerk speed' Old M566 X840.00 Y840.00 Z30.00 E270.00 ; set maximum instantaneous speed changes *(mm/min)(12x60=720) 'jerk speed' M203 X12000.00 Y12000.00 Z12000.00 E7200.00 ; set maximum speeds *(mm/min) ; M201 X1000.00 Y1000.00 Z1000.00 E5000.00 ; set accelerations (mm/s^2) Old ; M201 X1500.00 Y1500.00 Z1000.00 E5000.00 ; set accelerations (mm/s^2) M201 X1500.00 Y1500.00 Z1000.00 E800.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1200 I40 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X250 Y225 Z227 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io5.in M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin io6.in M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in ; Z-Probe M950 S0 C"io3.out" ; create servo pin 0 for BLTouch M558 P9 C"io3.in" H5 F1000 T8000 ; set Z probe type to bltouch and the dive height + speeds F1000 T600 G31 P500 X23 Y10 Z 0.98 ; *** set Z probe trigger value, offset and trigger height (increase to lower nozzle) glass, g10=0.85 M557 X23:240 Y25:205 S20 ; define mesh grid M557 X25:225 Y25:205 S20 S40 ; Heaters ; tuning; M303 H1 S350 ; H1 is heater number, S350 is target temp C. M308 S0 P"temp0" Y"thermistor" T100000 B4066 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 ; M307 H0 R0.25 C860.4 D14.2 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit ; M307 H0 R0.210 K0.413:0.000 D7.79 E1.35 S1.00 B0 M307 H0 R0.204 K0.266:0.000 D9.47 E1.35 S1.00 B0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; M308 S1 P"temp1" Y"thermistor" T100000 B4275 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 E3D low temp sensor ; M308 S1 P"temp1" Y"thermistor" T500000 B3800 ; configure sensor 1 as thermistor on pin temp1 Slice Engineering 450C M308 S1 P"temp1" Y"pt1000" ; configure sensor for pt1000 high temp sensor Slice Engineering or Filastruder M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 ; M307 H1 R2.648 C163.1:161.1 D6.32 S1.00 ; OLD disable bang-bang mode for heater and set PWM limit ; M307 H1 R2.168 K0.365:0.000 D7.57 E1.35 S1.00 B0 V23.9 ; new T0 tuning result M307 H1 R2.230 K0.321:0.000 D6.90 E1.35 S1.00 B0 V24.0 ; 09102022 target 350C M143 H1 S450 ; set temperature limit for heater 1 to 500C ; Fans ; M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency ; M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 C"HotEnd" S1 H1:0 T35 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 C"CaseFan" S1 H1:0 T35 ; set fan 2 name and value. Thermostatic control is turned on ; Tools M563 P0 S"Hotend" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Filament Runout Switch M591 D0 P1 C"io_4.in" S1 ; P0 P1 NO/NC ; Pressure Advance ; D = extruder drive number, S =amount of pressure advance ; M572 D0 S0.5 ; Custom settings ; M280 P0 S160 ; Clear any alarms M402 ; Retract pin just in case M929 P"eventlog.txt" S3 ; start logging to file eventlog.txt ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool G29 S1 ; Load Height Map
Possible back pressure issue. This filament may have a higher density than normal and require less extrusion.
I dropped extrusion down by 80%, retested print and failed.
Removed 0.4mm nozzle and added 0.6mm nozzle. Print successful.
