1HCL probing problem with ***video***
@phaedrux we appreciate, thank you.
will wait.
@highfreq said in 1HCL probing problem with ***video***:
In open loop it works it seems but between first and second touch it emits a beeping sound, maybe it would go back like in closed loop but being in open it skips steps and looks like it works?
I was thinking about this problem just now and came to the same conclusion myself, before I read your post. I was about to ask you whether there was an odd noise after the probe triggers when in open loop mode.
I will review the main board code tomorrow afternoon to work out what might be happening.
@dc42 great thanks.
If you need us to make any test just ask, we will be glad to help.
@HighFreq please can yo test whether the following works around the problem:
In your M584 command add a 5th Z motor assigned to a spare driver on the main board. I suggest you set the timing for that driver to T0:0:0:0 in a M569 command for that driver. You don't actually need to connect anything to that driver output.
@dc42 hello good morning.
Now the probing works, it doesn't jump anymore but endstops on the 4 phisical axis do not work anymore, probably because the fake axis configuration is not complete. If i remove the fake axis homing works as expected.
Our machine does z homing on top of the machine with 4 endstop switches.
@dc42 are you still going to get a look at it this afternoon?
@highfreq thanks for confirming that the work around fixed the problem. It gives an indication of what will need to be fixed in firmware so the work around is not needed.
@t3p3tony Just to make sure you understood, the workaround fixed a problem but created another so it is not usable, we are waiting for a firmware fix to be able to use the machine again.
Sometimes my english is not the best -
@highfreq could you switch from using endstops to using the probe to home Z?
@jay_s_uk no, we can't, our z axis is made of 4 screw phisical axis so we need to home all of them individually. At least that is how the machine is designed to work so we would much prefer to use it that way.
@highfreq why? homez using the probe and then use the built in bed levelling to get them positioned correctly.
My voron has 4 z motors but none of them have endstops... -
@jay_s_uk at least at the moment it is not possible, 1HCL has a little bug and sometimes one of the axis drops during power on, so it would not be possible do as you describe.
@highfreq one of mine always drops. i don't see why it wouldn't work unless your bed is so overly constrained that it can't move when one motor is out of sync with the others
@jay_s_uk we would prefer to have the bug solved and we want the machine to be able to home on the end stops because we need it in our layout.
@highfreq sorry, i just thought you wanted to get to a position of using the machine until the bug was fixed. i won't bother next time
@jay_s_uk thank you for your help, we hope it won't get too long until it gets fixed.
please share an updated config.g and the homing files so we can see how the 4 real axis and this 5th z motor interact.
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 02 2022 11:44:56 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"Duet 3" ; set printer name; Wait for expansion boards to star
G4 S1; Fans
M950 F0 C"!out4+out4.tach" Q25000 ; fan 0 con tach. + pwm freq 25kHz
M106 P0 S0 ; fan al minimo; Input ports
M950 J5 C"io5.in"
M950 J6 C"io6.in"
M950 J7 C"io7.in"
M950 J8 C"io8.in"; Output ports
M950 P5 C"io5.out" Q0
M950 P6 C"io6.out" Q0
M950 P7 C"io7.out" Q0
M950 P8 C"io8.out" Q0; Drives
M569 P1.0 D0 S0 ; asse Z - accensione in Open Loop per evitare caduta durante il tuning
M569 P2.0 D0 S0
M569 P3.0 D0 S0
M569 P4.0 D0 S0
M569 P5 D0 S0 T0:0:0:0; asse Z fantasma sulla mainboard per errore G30
M569 P1 S0 T2:2:0:0 ; asse Y
M569 P0 S0 ; asse X
M569 P10.1 S1 ; extruder motor
;M917 Z0 ;riduzione di corrente a motore fermo per asse
M584 X0 Y1 Z1.0:2.0:3.0:4.0:5 E10.1 ;mappa driver per ogni asse
M350 Z16 I1 ; configure microstepping with interpolation
M92 X200 Y200 Z320 E224.6 ; set steps per mm
M566 X10000 Y10000 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X60000 Y60000 Z5000 E9000 ; set maximum speeds (mm/min)
M201 X1000 Y1000 Z200 E250.00 ; set accelerations (mm/s^2)
M906 Z6000 E2500 ; set motor currents (mA)
M84 S0 ; Disable motor idle current reduction; Brakes
M569.7 P1.0 C"out1"
M569.7 P2.0 C"out1"
M569.7 P3.0 C"out1"
M569.7 P4.0 C"out1"; accensione assi
M17 Z E
G4 S2 ; attesa per essere sicuri che la Z sia eccitata; Z Encoders
M569.1 P1.0 T2 C5 R100 I8000 D0.1 E1.0:3.0; PID asse Z
M569.1 P2.0 T2 C5 R100 I8000 D0.1 E1.0:3.0
M569.1 P3.0 T2 C5 R100 I8000 D0.1 E1.0:3.0
M569.1 P4.0 T2 C5 R100 I8000 D0.1 E1.0:3.0; Drives
M569 P1.0 D4 S0 ; asse Z - accensione in Closed Loop
M569 P2.0 D4 S0
M569 P3.0 D4 S0
M569 P4.0 D4 S0; Tuning
;polarity and zeroing asse Z
M569.6 P1.0 V1
M569.6 P2.0 V1
M569.6 P3.0 V1
M569.6 P4.0 V1; Axis Limits
M208 X0:1000 Y0:1000 Z0:1500; Endstops
M574 Z1 S1 P"1.io0.in+2.io0.in+3.io0.in+4.io0.in"; Bed plate Heaters
M308 S0 A"Dietro DX" P"temp0" Y"pt1000" ; configure sensor as thermistor on pin
M308 S1 A"Dietro SX" P"temp1" Y"pt1000"
M308 S2 A"Avanti SX" P"temp2" Y"pt1000"
M308 S3 A"Avanti DX" P"temp3" Y"pt1000"
M950 H1 C"out0" T0 ; create bed heater output and map it to sensor
M950 H2 C"out1" T1
M950 H3 C"out2" T2
M950 H4 C"out8" T3
M307 H1 R0.040 K0.060:0.000 D23.41 E1.35 S1.00 B0 ; PID
M307 H2 R0.040 K0.060:0.000 D23.41 E1.35 S1.00 B0
M307 H3 R0.040 K0.060:0.000 D23.41 E1.35 S1.00 B0
M307 H4 R0.040 K0.060:0.000 D23.41 E1.35 S1.00 B0
M140 P1 H1 ; map heated bed to heater
M140 P2 H2
M140 P3 H3
M140 P4 H4
M143 H1 S120 ; set temperature limit for heater
M143 H2 S120
M143 H3 S120
M143 H4 S120; Extruder Heaters
M308 S10 A"Top" P"spi.cs2" Y"rtd-max31865" ; configure sensor as thermistor on pin
M308 S11 A"Bottom" P"spi.cs4" Y"rtd-max31865"
M308 S12 A"Nozzle" P"spi.cs1" Y"rtd-max31865"
M950 H10 C"out5" T10 ; create nozzle heater output and map it to sensor
M950 H11 C"out7" T11
M950 H12 C"out6" T12
M307 H10 R1.070 K0.120:0.000 D25.16 E1.35 S1.00 B0 ;PID riscaldatore pulsar top
M307 H12 R0.833 K0.103:0.000 D28.21 E1.35 S1.00 B0 ;PID riscaldatore pulsar nozzle
M307 H11 R0.867 K0.115:0.000 D17.33 E1.35 S1.00 B0 ;PID riscaldatore pulsar bottom
M143 H10 S300 ; set temperature limit for heater
M143 H11 S300
M143 H12 S300; Tools
M563 P0 D0 H10:11:12 F0 S"Pulsar" ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Z-Probe
M558 Z P5 K0 C"io1.in" H10 F500:20 T2000 ; definizione probe Z
G31 K0 X-3 Y54.5 Z5 ; offset rispetto alla testa
M557 X0:200 Y0:200 S100 ; define mesh gridI added this line:
and added motor 5 to this line:
homez
; homez.g
G91 ; movimenti relativi
G1 H1 Z1520 F900 ; muove la Z verso l'alto fino a che il finecorsa viene toccato
G1 H2 Z-5 F2000 ; scende di 5mm disimpegnando il finecorsa
G92 Z1500 ; imposta la Z nel punto di trigger a Z1500
G90 ; movimenti assolutiM291 P"Asse Z azzerato" R"INFO" S0 T2
@highfreq thanks for confirming the workaround. That tells me what is going wrong. Now I need to work out why it goes wrong on your system but not on my bench setup.
