    Tool change issues after firmware update 1.19.2
    6.7k
      Thanks for the reminder.
      Please try firmware 1.20beta2. It probably won't change anything, but I need to know that the fault is still present.
      Pending your report, I have this on my list to look at tomorrow.
      • MrTundefined
        MrT
        Good evening
        Thanks for the quick responds
        I will update the firmware to 1.20beta 2 1st thing in the morning and revert with result
        Best Regards
        Manuel
        • MrTundefined
          MrT
          Dear I have done the update of the firmware per your request
          Situation is the same with a slight difference
          now when I select tool 0 from a fresh machine boot , it doesn't complete the full tool change, the gcode file is not fully processed,
          as opposed to before I could just type T0 and it will collect the tool without problem .
          after I put the T0 back in standby and do an other T0 I will get it correctly ,
          then I do a T1 command and it will fetch tool1 but after the selection is complete T0 is set to active.
          , I feel strange, for sure I am not the only guy owning a duet wifi with a tool change, but no one else is complaining about this problem
          Best Regards
          Manuel Topiol
          • MrTundefined
            MrT
            for info
            Firmware Name: RepRapFirmware for Duet WiFi
            Firmware Electronics: Duet WiFi 1.0
            Firmware Version: 1.20beta4 (2017-10-28)
            WiFi Server Version: 1.20beta2
            Web Interface Version: 1.19.3
            best regards
            • MrTundefined
              MrT
              Dear DC42
              There is some improvement and possibly resolved !!!!
              I just updated the firmware as per previous msg
              tried again the tool change, the problem of the 1st boot and T0 command disappeared, then I did a T1 command and I got an error MSG Error: Bad command: Lift Z relatively to current position
              I removed the Z lift command and now when I change tools the correct tool is active 🙂
              some thing strange is that the z lift is the same in pre0 then in pre1 but the error is only appearing in T1
              Best Regards
              Manuel Topiol
                I'm glad the main issue is resolved. I think you have the text "Lift Z relatively to current position" in your tpre1.g file, without the semicolon at the start to indicate that it is a comment.
                • MrTundefined
                  MrT
                  I will check right away
                  • MrTundefined
                    MrT
                    🙂 you are right
                    the ; was missing , but it has always been missing cause I did not edit the file 🙂
                    the error msg is gone but the stop in the middle of the tool change remains on T1
                    T0 is being parked and collected correctly
                    but when it goes back to collect tool1 seems that to stops before finished and immediately wait for the tool to get to temp then continue printing but the tool1 is not loaded
                    Thanks
                    Best Regards
                    Manuel Topiol
                      OK, it's back on my list to look at.
                      • MrTundefined
                        MrT
                        Dear DC42
                        just to see what happens I have let the printer continue to print
                        the behavior is as follow
                        start printing
                        T0 is loaded waiting till it reaches temp , start 1 layer
                        T0 is parked Tfree fully executed
                        T1 is in the process of being loaded the gcode executes to the 5th line of the tpre, and stops there
                        then remains there till the nozzle reaches the temperature ,
                        once the temperature is reached it continues to print , without the tool being loaded , but the tool is active like it should .
                        once the layer without loaded tool is completed it executes Tfree1 successfully
                        Then execute tpre0 successfully and tool0 is correctly loaded wait for temp to be reached and start printing.
                        hope it will help u to find the glitch
                        Best Regards
                        Manuel Topiol
                        I have put back the 1.18 firmware and the switching is back to normal no stopping at T1 command
                        • foehnsturmundefined
                          foehnsturm
                          This is probably not closely related but I'm running 1.19.2 (2017-09-01) and noticed that the final line of my tfree macros is not reliably executed (when using the select tool command in the WebUI). It sometimes finishes the macro without performing the last move but will perfectly execute any following command (which ofc could cause a crash into the dock). I ended up with duplicating the final line to safeguard its execution.
                          Magnetic tool changer on a corexy.
                          [[language]]
                          ; tfree0.g
                          ; called when tool 0 is freed
                          M83
                          G0 E-5 F1200
                          M82
                          G0 X252 Y215 F16000
                          G91
                          G0 Y47
                          G0 X30 F4000
                          G0 X4 F2000
                          G90
                          G0 Y215 F6000
                          G0 Y215 F6000
                          • MrTundefined
                            MrT
                            Dear foehnsturm
                            I am also using a magnetic tool change , with the 1.18 firmware I can confirm that all is working well ,
                            I never managed to get 1.19 working ,since I always had the wrong tool active. did you experience something similar ?
                            The issue with wrong tool being active got solved with the latest 1.2 beta4 but I am still facing some issues with the tpre file as it is not fully executed.
                            Best Regards
                            MT
                            • MrTundefined
                              MrT
                              Dear DC42 & foehnsturm
                              Seems foehnsturm is correct !!
                              I have tried to add the last line of tpre1 2 times and it seems to work 🙂
                              If I may ask what slicer are you guys using ?
                              thanks to both of you
                              Best Regards
                              MT
                                foehnsturm
                                Great that I could help.
                                @dc42, could there be an issue with always completely executing the macro?
                                @topiolm@hotmail.com, no yet using a slicer 😉 Just finished the park and pickup sequences.
                                • MrTundefined
                                  MrT
                                  foehnsturm
                                  do you use something similar to mark2 for your tool change ?
                                  Best Regards
                                  MT
                                    foehnsturm
                                    A little more complicated: multiple toolheads but only one stepper.
                                    • MrTundefined
                                      MrT
                                      I have tried some similar approach some time ago without much success I was clogging my nozzle 2 often with the retract , then I just dropped it. since I have limited time for my hobbies 😞
                                      If you don't mind could you post some picture just for my curiosity 🙂
                                      Best Regards
                                      MT
                                      Ps if you intrested something I have tested with great success ,the use of compressed air for cooling the part during printing , for small part worked miracles only problem was the amount of air used and the noise, my neighbor became crazy , the compressor was working to much and for to long :-). so reverted to the traditional fan,
                                      the advantaged was less weight on the head and vibration was reduced ,not that there is a lot of vibration , but any improvement is an improvement how ever small 🙂
                                      • MrTundefined
                                        MrT
                                        Dear DC42
                                        I found an other issue , if I cancel a print the tool change macro are not being executed
                                        to better explain , if I cancel a print and a tool is still loaded , I and I click on the tool to put it back in standby and go back to its parking place , I get no responds
                                        Best regards
                                        MT
                                          Chrishamm put an option in DWC to not run the tool change macros when you change tool in DWC. Perhaps you have that option selected?
                                          • MrTundefined
                                            MrT
                                            Once again you are right got over exited to have my printer working again , and was to quick to post,
                                            pls accept my apologies
                                            Thanks again for your support
                                            Best Regards
                                            MT
