Ratrig Vcore 3.1 4028 Fan and Duet 3 Mini 5+ - Current Draw
@dc42 Thanks, for now i already have the external 12V hooked up, but good to know in the future i could probably go back to fully pulling from the board.
Update, i have the fan connected and seemingly working correctly. I am getting accurate RPM readings in the Duet web interface up to 25,000 RPMs. The only problem is at 0% the fan still spins at 8000 RPM, which i've read somewhere that this is normal behavior for some PWM fans.
out4- (brown PWM wire from 4028 fan)
out4.tach (yellow sensor wire from 4028 fan)
V_OUTLC1+ (not used, already connected to buck converter)
Ground (not used, already connected to buck converter) -
@rogerpodacter said in Ratrig Vcore 3.1 4028 Fan and Duet 3 Mini 5+ - Current Draw:
Sanyo SanAce40 fan 9GAX0412P3S001
64 dBA
I know, but i wont be using all that power and will mostly keep it very low. Just nice to know i have it if needed.
My issue still kinda remains, i cannot have this fan completely off between 0-20%, it stays at 8000 RPM. From my research, this is part of the standard where many manufacturers dont define hard requirements in this range. But surely there must be a work around. Right now the printer/fan combo is not usable because this loud fan is always on even when i tell it to turn off.
@rogerpodacter according to the datasheet at https://docs.rs-online.com/f732/0900766b815bd5ae.pdf the 9GAX0412P3S001 should not rotate at zero PWM; whereas the 9GAX0412P3S003 will rotate at 7800 rpm. Have you checked which version you have?
@dc42 thanks I missed that in the manual. I definitely have the 001 model, here is a pic I took.
EDIT: i am on firmware version 3.4.
So I think my setup and wiring must still be incorrect. I will reply with my gcode when I get to work.
EDIT: here is my fan config.g file. Fan0 is my server PWM 4 pin fan.
; Fans ;M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M950 F0 C"!out4+out4.tach" Q25000 M106 P0 C"Layer Fan" S0 L0.0 X1.0 H-1 ;M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out3" Q500 ; create fan 1 on pin out3 and set its frequency M106 P1 C"Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on
My wiring is as follows:
GND (open not connected, fan black wire goes to buck converter)
V_OUTLC1+ (open not connected, fan red wire goes to buck converter)
out4.tach (fan yellow tach sensor wire connects here)
out4- (fan brown PWM wire connects here)everything seems to work normal, but just the scale of the PWM is not quite right.
@rogerpodacter that sounds good, assuming your buck converter output ground is common with its input ground.
You could try temporarily connecting the fan PWM input to ground (i.e. brown wire to black wire instead of to out4-) to see whether the fan turns off.
@dc42 I just grounded the PWM wire and the fan still spins at around 8000 RPM. Is it possible i damaged the fan? i do recall i first connected the fan and did not have out3 inverted, and the entire board and power supply went dark when i turned on the printer. But i simply unplugged, corrected, and then plugged in and seemingly no damage. But maybe that is the issue?
I somewhat suspect its something else. But definitely right now it seems to be the fan moreso than the board or the settings.
I just received a new fan, AVC Model DBTB0428B2G 12 volt 1 amp 4-wire PWM fan, and the behavior is identical to the San Ace fan. This new fan is a 15,000 RPM fan, but it spins at 2,000 RPM on idle at 0%. It also ramps up very unevenly, but it does reach 15,000 RPM at 100% so that's good. i will ground the control pin and see if that changes the behavior.
Is it possible the PWM 4 wire protocol is somehow not functioning correctly? Or is it possible my board is damaged/malfunctioning?
I guess perhaps i could test by using out3 instead of out4 to rule that out?
EDIT: grounding the PWM control wire does not stop the fan, it still spins slowly. Maybe this new model fan has this behavior by default? i couldnt find the datasheet. this just seems so strange.
@rogerpodacter it's common for fans to spin at a minimum speed even when you feed them 0% PWM through the PWM input (i.e. ground it). However, Noctua fans do turn off, and the datasheet for the -001 variant of your original fan says it is supposed to turn off too.
@dc42 Just to close this topic, RatRig seems to confirm they got a bad order of 4028 fans which were really 003's labeled as 001's. So here i am thinking i'm crazy or wiring incorrectly. Anyone who reads this in the future maybe will have an easier time!
