Brake motors 1XD
@3dream the easiest way would be to use M17 Z followed by a short G4 delay command in your homing file, before the homing move.
a thousand thanks
very kind as always -
Good morning DC42,
even after inserting home Z and home all, M17 (not specific Z) and G4 P800 in the file, sometimes (not always) only 2 or 3 Z motors start. I switch the machine off and on again and everything works correctly. Can you give me some other solution to this problem please? Thank you -
@3dream do you have a G4 delay call near the start of config.g, earlier than any commands that refer to devices on expansion boards such as the M569.7 commands used to configure the brakes?
I put G4 S2 as the first line in config.g -
Perhaps I have not explained myself well, I mean that in the config.g there is already the G4 command in the first line. Maybe I need to insert it just before M569.7? or even before M569?
ThanksG4 S2; Pausa per avvio 1XD
G21; Unit millimetri
G90; Posizioni assolute
M83; Estrusore posizione relativa
;Impostazioni rete
M550 P3Dream 1300 HYBRID ; Nome macchina
M552 P192.168.44.30
M554 P192.168.44.10
M553 P255.255.255.0
M552 S1
M586 P0 S1
M586 P1 S0
M586 P2 S0
M669 K0
;Impostazione motori
M569 P40.0 R0 S1 T5:5:5:5; Senso rotazione motori Z0 Ant DX
M569 P41.0 R0 S1 T5:5:5:5; Senso rotazione motori Z1 Ant SX
M569 P42.0 R0 S1 T5:5:5:5; Senso rotazione motori Z2 Post SX
M569 P43.0 R0 S1 T5:5:5:5; Senso rotazione motori Z3 Post DX
M569 P44.0 R0 S0 T5:5:5:5; Senso rotazione motori X
M569 P45.0 R0 S1 T3:3:5:0; Senso rotazione motori E Antiorario visto da alto
M569 P46.0 R0 S1 T5:5:5:5; Senso rotazione motori Y0 Ant SX
M569 P47.0 R0 S1 T5:5:5:5; Senso rotazione motori Y1 Ant DX
M569.7 P40.0 C"out1";Freno Z0
M569.7 P41.0 C"out1";Freno Z1
M569.7 P42.0 C"out1";Freno Z2
M569.7 P43.0 C"out1";Freno Z3 -
G4 S2 at the start of config.g should be enough, but perhaps try increasing that to G4 S4 to give it another couple seconds just in case it's a bit slower.
@phaedrux
ok, I'll try thanks -
Good morning,
even after inserting a 4 second pause the problem persists.
It would seem that the problem is always at the first start in the morning where 1 or 2 Z motors don't want to go.
I switch the machine off and on again several times and the problem disappears. The problem occurs only if the machine remains off for a few hours. Do you have any other ideas please? -
@3dream said in Brake motors 1XD:
Good morning,
I switch the machine off and on again several times and the problem disappears. The problem occurs only if the machine remains off for a few hours. Do you have any other ideas please?G4 S4; Pausa per avvio 1XD G21; Unit millimetri G90; Posizioni assolute M83; Estrusore posizione relativa ;Impostazioni rete M550 P3Dream 1300 HYBRID ; Nome macchina M552 P192.168.44.30 M554 P192.168.44.10 M553 P255.255.255.0 M552 S1 M586 P0 S1 M586 P1 S0 M586 P2 S0 M669 K0 ;Impostazione motori M569 P40.0 R0 S1 T5:5:5:5; Senso rotazione motori Z0 Ant DX M569 P41.0 R0 S1 T5:5:5:5; Senso rotazione motori Z1 Ant SX M569 P42.0 R0 S1 T5:5:5:5; Senso rotazione motori Z2 Post SX M569 P43.0 R0 S1 T5:5:5:5; Senso rotazione motori Z3 Post DX M569 P44.0 R0 S0 T5:5:5:5; Senso rotazione motori X M569 P45.0 R0 S1 T3:3:5:0; Senso rotazione motori E Antiorario visto da alto M569 P46.0 R0 S1 T5:5:5:5; Senso rotazione motori Y0 Ant SX M569 P47.0 R0 S1 T5:5:5:5; Senso rotazione motori Y1 Ant DX M569.7 P40.0 C"out1";Freno Z0 M569.7 P41.0 C"out1";Freno Z1 M569.7 P42.0 C"out1";Freno Z2 M569.7 P43.0 C"out1";Freno Z3 M584 X44.0 Y46.0:47.0 Z40.0:41.0:42.0:43.0 E45.0 P3; Assegnazione motori M92 X400 Y400:400 Z1280:1280:1280:1280 E224.6; Step giro motori M566 X500 Y500:500 Z40:40:40:40 E300; Jerk motori M203 X5000 Y5000:5000 Z600:600:600:600 E9000; Velocita motori M201 X500 Y500:500 Z40:40:40:40 E2000; Accelerazione motori ;M572 D0 S0.05 ;Corse macchina M208 X0 Y0 Z0 S1; Posizione corsa minima M208 X1300 Y1290 Z1030.3 S0; Posizione corsa massima era 1031.5 ;Finecorsa M574 X1 S1 P"io2.in" M574 Y1 S1 P"46.io0.in+47.io0.in" ; doppio finecorsa microswitch su assi Y SU 1XD 46.io0.in M574 Z2 S1 P"!40.io0.in+!41.io0.in+!42.io0.in+!43.io0.in" ; quadruplo finecorsa proximity su assi Z SU 1XD ;Posizione proximity e bed levelling M558 P8 C"^!io8.in" H8 R1 F120 T8000 G31 P600 X-28 Y60 Z0.5; era Z-0.8 con pellicola PP M557 X100:1200 Y100:1200 S550:550 ;limiti temperatura estrusione M302 P0 S150 R150 ;Piano riscaldato M308 S0 P"temp_0" Y"thermistor" A"Piano" T100000 B3950 M950 H0 C"out0" T0 M143 H0 S120 M307 H0 B1 S1.00 M140 H0 M570 H0 P1000000 T1000000 ;Estrusore Alto M308 S1 F60 P"spi.cs0" Y"rtd-max31865" A"Alto" ; definizione M950 H1 C"out1" T1 Q100 ; heater 1 uses the high current output pin sensor 1 M143 H1 S400 ; set temperature limit for heater 1 to 300C M570 H1 P1000 T1000 M307 H1 S0.50 ;Estrusore Centro M308 S2 F60 P"spi.cs1" Y"rtd-max31865" A"Centro" ; define E0 temperature sensor M950 H2 C"out2" T2 Q100 ; heater 1 uses the high current output pin sensor 1 M143 H2 S400 ; set temperature limit for heater 1 to 300C M570 H2 P1000 T1000 M307 H2 S0.50 ;Estrusore Ugello M308 S3 F60 P"spi.cs3" Y"rtd-max31865" A"Nozzle" ; define E0 temperature sensor M950 H3 C"out3" T3 Q100 ; heater 1 uses the high current output pin sensor 1 M143 H3 S400 ; set temperature limit for heater 1 to 300C M570 H3 P1000 T1000 M307 H3 S0.50 ;Camera M308 S4 P"temp_1" Y"thermistor" A"Camera" T100000 B3950 Attivazioni varie M950 P8 C"43.out0" ; Creazione GPIO pin 8 su 1XD Can 43 out0 alimentazione proximity finecors Z3 M42 P8 S1 ; abilita uscita 24V proximity Z3 M950 P9 C"42.out0" ; Creazione GPIO pin 9 su 1XD Can 42 out0 alimentazione proximity finecors Z2 M42 P9 S1; abilita uscita 24V proximity Z2 M950 P10 C"41.out0" ; Creazione GPIO pin 10 su 1XD Can 41 out0 alimentazione proximity finecors Z1 M42 P10 S1; abilita uscita 24V proximity Z1 M950 P11 C"40.out0" ; Creazione GPIO pin 11 su 1XD Can 40 out0 alimentazione proximity finecors Z0 M42 P11 S1; abilita uscita 24V proximity Z0 M950 P12 C"45.out0" ; Creazione GPIO pin 12 su 1XD Can 45 out0 alimentazione sensore granulo M42 P12 S1; abilita uscita 24V sensore granulo M950 P13 C"45.out1" ; Creazione GPIO pin 13 su 1XD Can 45 out 1 alimentazione valvola exair granulo tramoggia M42 P13 S1; abilita uscita 24V sensore granulo tramoggia ;M950 J7 C"45.io0.in" ; Creazione input Pin7 su 1XD Can 45 per sensore granulo M591 D0 P2 C"45.io0.in" S1 ;M950 J14 C"^io0.in" ; Creazione input Pin 14 sensori porte ;M581 P14 S1 T6 R1 ; invoca trigger 6 apertura porte ;Ventole M950 F0 C"out7" Q250 M106 P0 S0 H-1 ; Tools M563 P0 D0 H1:2:3 S"Pulsar" ; define tool 0 G10 P0 X0 Y0 Z0 G10 P0 S0 R0 ; set tool 0 axis offsets ;Autopoweroff ;M911 S23 P"G91 M83 G1 Z3 E-2 F1000" M106 S0 M671 X1450:-150:-150:1450 Y-150:-150:1450:1450 S5 M501
These are incorrect. Only multiple extruder motors require multiple values. If the axis is made up of multiple motors, there only needs to be a single value for the axis, not for each motor. So remove the duplicate Y and Z values. I don't know if this would cause an issue like what you are seeing, but it isn't helping.
You can also send M98 P"config.g" to get a syntax check of your config.g file.
It may also help to see the results of M122 and M122 B# where # is the can address of your expansion boards.
