1 thing stopping me now..
OK almost there.. 1 thing is still not right and I can't find answers searching… probably right in front of me.. LOL
all axis move correctly, but Z end stop isn't registering.. it's the same mechanical one as X & Y which are both work fine. thinking it's something to do with "probe" but I don't have a probe and not sure how to shut off... just a guess though.
Please post your config.g here, we need that to know how you've set things up so far.
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Mon Oct 16 2017 05:23:05 GMT-0400 (EDT); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X230 Y210 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; Define mesh grid; Drives
M569 P0 S1 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes backwards
M569 P3 S0 ; Drive 3 goes forwards
M92 X80 Y80 Z400 E97 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S245 ; Set maximum heater temperature to 245C
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PMax Micron ; Set machine name
M552 S1 ; Enable network
M587 **********; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Custom settings are not configured
just did a M119 and I get this if that helps? …. M119
Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped -
thinking it's in this section.. but no clue what to change/delete/ncomment…
M557 X15:215 Y15:195 S20 ; Define mesh grid -
If you're not using a Z-probe, then you shouldn't have the M558/G31/M557 lines (delete the whole line).
Use M119 to test if the Z-endstop is wired properly - trigger it manually and check that it says "at min stop".
Have you read https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z ?
no.. I hadn't ,… sweet!!! sooo much info and sooo little brain . . thanks .
ya, thought that line(s) weren't needed but still WAY to new to this code/board and didn't want to make things worse (I have a habit of that )
No worries, we all start somewhere! Happy to help.
That worked !!! thanks for pointing to that!! printed out the whole section, need to read through it throughly
OK new issue.. might be nothing? just did the PID auto tune thing.. after it came up with a warning..
"warning, heater one appears to be over powered and a fire risk!! If left on at full power, it's temp is predicted to reach 757C"Umm ….ack?
now the PID tune should prevent this correct?
is there a way to lower the power coming out of the board? looked at the "hotend" settings but nothing says "hot end power", or voltage or something.. -
All a PID tune does is help the controller hold the desired temperature better, i.e. with less variation. Think of PID tuning as practicing walking on a tightrope - once your brain is trained (the PID gains are tuned), there's less wobbling around (temperature variation).
A heater that powerful is a fire risk if the controller were to fail. I would guess you're using a 12v heater on 24v, or a 40w heater with a sock or other insulation?
nope, 12v system with 12v heater heater is stock MK8.. there is a sock on it I made.
Ya I get the basis of the PID tune.. and got to say, it's WAY more stable than with marlin's.. getting like a 0.5º variation where marlin I was get +/-2º or more.
Sounds like a 40 watt heater with a sock. That is too much heat/too much insulation, if the Duet's FETs ever failed on, the hotend would reach ~700C, melt the heater block, and likely start a fire. Would recommend a 30w heater if you plan to use a sock.
The PID tune won't prevent a fire as no matter what the gains are, it can't compensate for a hardware failure.
