First time cura and my problem
Hey guys, good morning from Germany. I would like to try Cura once. Have loaded it now, inserted my normal start and end codes as in superslicer and created a Voron. If I now slice and simulate this file, I get an error in the console. But he still simulates to the end.
M37 P"0:/gcodes/bbbbbbbbbbb.gcode"
Simulating print of file 0:/gcodes/bbbbbbbbbbb.gcode
Error: Bad command: mperature]
Error: in GCode file line 19 column 11: M109: expected number after 'r'
Error: Bad command: mperature]Can someone tell me what could be the reason? an approach? Thanks in advance
@jamaicarasta my guess is that the GCode file contains a line that is meant to be a comment but lacks the semicolon at the start.
@dc42 Yes, 2 lines ;G32 and ;G1 X175 Y175 F18000 it was dir testing… In my start code
@dc42 i check that. without semikolon ist the same issue
@jamaicarasta You have an error in your start gcode:
It appears the error in the line that sets the hotend temperat.ure. The mperature] is missing the part of the line. -
@stephen6309 but it works in superslicer perfect.
It is different in Cura? -
@jamaicarasta You'll have to check the documetation, Cura may use different variable names.
Make sure it was copied fully.
@stephen6309 I will check that, thanks
@dc42 I solved the problem. Deleted the M190 and M109 in the start code First temp bed and layer.
@jamaicarasta I use this SuperSlicer start gcode, thought it would help.
T-1 ; deselect tool, tool to standby temp M1000 Q"[filament_type]" ;custom M gcode to set G31 Z offset for filament_type G10 P0 S[first_layer_temperature] R140 M190 S[first_layer_bed_temperature] M98 P"/macros/EnableHoming" G32 ; bed calibration G29 ; bed mesh M98 P"/macros/DisableHoming" T0 ; select T0 and go to active temp M116 ; wait for temp G1 E6 ; extrude a bit
/sys/M1000.g, sets the G31 Z offset and retraction:
; M1000 Q"[filament_type]" echo "Set G31 Z offset for ",param.Q if param.Q == "PETG" M98 P"/sys/PETGOffset.g" elif param.Q == "PLA" M98 P"/sys/PLAOffset.g" elif param.Q == "TPU" M98 P"/sys/TPUOffset.g"
@stephen6309 thanks, i solved the problem. Deleted the M190 and M109 in the start code First temp bed and layer.
@stephen6309 and my first print with cura was better than superslicer
I will try it tomorrow with a few prints.
greetings from germany
