Duet 3 MB6HC Questions
@jay_s_uk
Thanks for the reply. I'm really frustrated with this thing. I've looked at the updating firmware link you posted but since the board is new (and shouldn't need fallbacks), I never read down through the fallback procedures.I forgot to mention it in my initial post. When I operate the board with a Pi in SBC mode it "works" but everything is slow, it won't upload files, won't update firmware, etc. --but the DIAG LED light is off on the board in SBC mode.
However, when I try to run/connect to the board in standalone mode, that DIAG led light is on (and very faint). It's weird. I thought that maybe I had a bad board or something. But since that DIAG LED is on like that...
Should I go through the procedure of fallback#2 (erase jumper, reset, sam-ba to re-flash)?
Is it at all possible that I could have something running on my machine that could be interfering with the mb6hc in standalone mode? It is Ubuntu 18.04 (desktop) with nvidia sdk development software for jetson xavier and nano as well as software for google coral ai dev and dev mini boards. It talks to all of these boards (nvidia, google, etc.) via various usb protocols.
Where should I start assuming I have a mb6hc board with a faint/dim DIAG led in standalone mode and a blank/formatted MicroSD card?
@winstontj if the DIAG led is faintly lit, that usually means that the board has no valid firmware installed. If you connect the USB port to a PC, you may find that it is providing the Bossa port ready to receive firmware.
@dc42 I have a bossa port in Windows Device Manager (Win 10 Pro) and in Ubuntu 20.04 I see Bus 004 Device 002: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader when I 'lsusb'.
I am getting a Windows SAM-BA error: "SAM-BA error h_handle returned zero".
I am getting a Windows BOSSA error "Could not connect to device on COM9".In Linux:
~/BOSSA/bin/bossac -e -w -v -b /home/nvidia/Downloads/Duet3Firmware_MB6HC.bin
No device found on /dev/ttyACM0Both Windows and Linux machines can see it yet it errors out or refuses to connect. Is this a permissions thing? Is it a configuration issue? Are there jumpers/pins that could be mis-configured?
The documentation is terrible. It is conflicting, confusing, outdated, etc. I have seen others ask about the ribbon cable: The documentation states that a cable over 150mm is a problem yet the board was shipped from the factory with a 200mm cable.
The documentation states to install SAM-BA v. 2.17 yet the photo on the website is of SAM-BA v. 2.16. It also says that you will get connection errors (I am getting connection errors) if you specify the wrong board. Exactly what version of SAM-BA should be installed on a Windows 10 machine and exactly how do I find out or confirm which board/chip I have?
The documentation does not mention a MicroSD card during the erase/re-flash procedure. Should the MicroSD card be installed in the MB6HC board during the erase/re-flash process? What state (file structure, format, etc.) should the MicroSD card be in during the failback#2 procedure?
USB Cable: The documentation states "if it doesn't work, try new/different usb cable" however the board does not ship with a USB cable. What are the required specifications of the USB connection/cable?
I'd appreciate any help trying to flash firmware onto this $250 paperweight. Thanks.
Is the jumper still fitted to the erase pins on the board?
The SD card is irrelevant for doing a firmware update over USB with Bossa.
A USB 3 cable that supports power and data should work. Some people find having a USB hub in between helps with the board being detected, but it sounds like your is being detected. This is why I ask about the jumper.
@winstontj we normally recommend using Bossa these days, not SAM-BA. Which version of Bossa have you installed? Is COM9 the Bossa port shown in Device Manager?
@winstontj Unfortunately the stock
bossa
program on older DuetPi versions and Debian Buster is quite outdated so it doesn't recognize the MB6HC. You can upgrade it this way:sudo curl -L "https://github.com/Duet3D/DuetPi/blob/master/stage-dsf/00-system/files/bossac?raw=true " -o /usr/bin/bossac
After that you can flash the firmware again:
bossac -e -w -v -b /opt/dsf/sd/firmware/Duet3Firmware_MB6HC.bin
That should get you going again provided you don't have the ERASE jumper fitted any more. If you do, remove it first. You may have to reset the board once using the push button when the firmware is upgraded.
Can you give me the link to the documentation where it mentions the ribbon cable? 200mm should be fine; longer cables may work as well but that isn't recommended at the default SPI speed.
@chrishamm said in Duet 3 MB6HC Questions:
https://docs.duet3d.com/en/User_manual/Overview/Getting_started_Duet_3_MB6HC#minimum-configuration
and
https://docs.duet3d.com/en/User_manual/Overview/Getting_started_Duet_3_Mini_5+#minimum-configuration
@chrishamm Sorry I walked away for a few days. It looks like @Phaedrux linked you some/the places in the docs.
I have no idea what the problem is or what I'm missing but this stupid board is still a paperweight.
In Diag mode (at least connected to Win 10 Pro) the MicroSD card being installed matters a lot. Right now the red diag led is faint/dimly lit and the erase jumper pins are open. On Win10pro with no microsd card I get "unknown usb device" in the windows device manager (device driver is installed). With the microsd card installed (doesn't seem to matter whether the microsd card is formatted, blank, has data on it, etc. it's just whether or not a microsd card is present in the board) So with the microsd card installed, win10pro sees "Bossa Program Port (COM10)"... But then I get: Error: "Could not connect to device on COM10".
If I right click and run elevated same thing: could not connect to device on COM10.
Not sure if it matters --the physical machine is an old Dell Optiplex 755. It's something I dug out and put a clean windows image on for this firmware issue. I believe it's a USB2.0 port. The Dell machine is old, mfg. date says 01/15/08 so I don't think there should be any compatibility issues. So Win10pro I'm having no luck with SAM-BA or BOSSA. I can see the board in device manager, it's recognised, etc. it just won't connect.
I then tried it on an Ubuntu 20.04 machine and an Ubuntu 18.04 machine. There seemed to be no difference between the two operating systems. The only thing I noticed was that was a little strange was that SAM-BA would only run the 64-bit application. The 32-bit would not open. The 64-bit would open and then as soon as I hit connect, the dialog box would vanish and the program would quit.
With BOSSA on Ubuntu 20.04: The documentation says update & install, etc. and FYI in Ubuntu 20.04, package libwxgtk3.0-dev has changed to libwxgtk3.0-gtk3-dev so you get a "no install candidate" error with libwxgtk3.0-dev. So with BOSSA, the way that you suggested in your post above: (sudo curl -L... etc.) I think something similar to the SAM-BA 32/64-bit thing is happening.
When I ran
bossac -e -w -v -b /home/user/Desktop/Duet3/Duet3Firmware_MB6HC.bin
I got back:
bash: /usr/bin/bossac: cannot execute binary file: Exec format error
When I ran with sudo:
sudo bossac -e -w -v -b /home/user/Desktop/Duet3/Duet3Firmware_MB6HC.bin
I got back:
/usr/bin/bossac: 1: Syntax error: word unexpected (expecting ")")
A brief Google search shows that you often get the syntax word unexpected error when you are trying to run a 32-bit binary/program on a 64-bit OS (or the other way around)... Since I also was getting something weird with SAM-BA where the 32-bit would not open and the 64-bit would open, then closed upon attempted connection (similar to what I was getting in Win10pro, disconnect after cannot connect).
Is this a 32 vs 64 bit issue?
Next I tried a Pi 3B+ with the Duet Pi.zip (I am typing this from the desktop on the DuetPi).
pi@duet3:~ $ bossac -e -w -v -b /home/pi/Desktop/Duet3Firmware_MB6HC.bin No device found on /dev/ttyACM0 pi@duet3:~ $ sudo bossac -e -w -v -b /home/pi/Desktop/Duet3Firmware_MB6HC.bin No device found on /dev/ttyACM0 pi@duet3:~ $ ls -l /dev/tty* crw-rw-rw- 1 root tty 5, 0 May 13 20:02 /dev/tty crw--w---- 1 root tty 4, 0 May 13 20:02 /dev/tty0 crw------- 1 pi tty 4, 1 May 13 20:02 /dev/tty1 crw--w---- 1 root tty 4, 10 May 13 20:02 /dev/tty10 crw--w---- 1 root tty 4, 11 May 13 20:02 /dev/tty11 crw--w---- 1 root tty 4, 12 May 13 20:02 /dev/tty12 crw--w---- 1 root tty 4, 13 May 13 20:02 /dev/tty13 crw--w---- 1 root tty 4, 14 May 13 20:02 /dev/tty14 crw--w---- 1 root tty 4, 15 May 13 20:02 /dev/tty15 crw--w---- 1 root tty 4, 16 May 13 20:02 /dev/tty16 crw--w---- 1 root tty 4, 17 May 13 20:02 /dev/tty17 crw--w---- 1 root tty 4, 18 May 13 20:02 /dev/tty18 crw--w---- 1 root tty 4, 19 May 13 20:02 /dev/tty19 crw--w---- 1 root tty 4, 2 May 13 20:02 /dev/tty2 crw--w---- 1 root tty 4, 20 May 13 20:02 /dev/tty20 crw--w---- 1 root tty 4, 21 May 13 20:02 /dev/tty21 crw--w---- 1 root tty 4, 22 May 13 20:02 /dev/tty22 crw--w---- 1 root tty 4, 23 May 13 20:02 /dev/tty23 crw--w---- 1 root tty 4, 24 May 13 20:02 /dev/tty24 crw--w---- 1 root tty 4, 25 May 13 20:02 /dev/tty25 crw--w---- 1 root tty 4, 26 May 13 20:02 /dev/tty26 crw--w---- 1 root tty 4, 27 May 13 20:02 /dev/tty27 crw--w---- 1 root tty 4, 28 May 13 20:02 /dev/tty28 crw--w---- 1 root tty 4, 29 May 13 20:02 /dev/tty29 crw--w---- 1 root tty 4, 3 May 13 20:02 /dev/tty3 crw--w---- 1 root tty 4, 30 May 13 20:02 /dev/tty30 crw--w---- 1 root tty 4, 31 May 13 20:02 /dev/tty31 crw--w---- 1 root tty 4, 32 May 13 20:02 /dev/tty32 crw--w---- 1 root tty 4, 33 May 13 20:02 /dev/tty33 crw--w---- 1 root tty 4, 34 May 13 20:02 /dev/tty34 crw--w---- 1 root tty 4, 35 May 13 20:02 /dev/tty35 crw--w---- 1 root tty 4, 36 May 13 20:02 /dev/tty36 crw--w---- 1 root tty 4, 37 May 13 20:02 /dev/tty37 crw--w---- 1 root tty 4, 38 May 13 20:02 /dev/tty38 crw--w---- 1 root tty 4, 39 May 13 20:02 /dev/tty39 crw--w---- 1 root tty 4, 4 May 13 20:02 /dev/tty4 crw--w---- 1 root tty 4, 40 May 13 20:02 /dev/tty40 crw--w---- 1 root tty 4, 41 May 13 20:02 /dev/tty41 crw--w---- 1 root tty 4, 42 May 13 20:02 /dev/tty42 crw--w---- 1 root tty 4, 43 May 13 20:02 /dev/tty43 crw--w---- 1 root tty 4, 44 May 13 20:02 /dev/tty44 crw--w---- 1 root tty 4, 45 May 13 20:02 /dev/tty45 crw--w---- 1 root tty 4, 46 May 13 20:02 /dev/tty46 crw--w---- 1 root tty 4, 47 May 13 20:02 /dev/tty47 crw--w---- 1 root tty 4, 48 May 13 20:02 /dev/tty48 crw--w---- 1 root tty 4, 49 May 13 20:02 /dev/tty49 crw--w---- 1 root tty 4, 5 May 13 20:02 /dev/tty5 crw--w---- 1 root tty 4, 50 May 13 20:02 /dev/tty50 crw--w---- 1 root tty 4, 51 May 13 20:02 /dev/tty51 crw--w---- 1 root tty 4, 52 May 13 20:02 /dev/tty52 crw--w---- 1 root tty 4, 53 May 13 20:02 /dev/tty53 crw--w---- 1 root tty 4, 54 May 13 20:02 /dev/tty54 crw--w---- 1 root tty 4, 55 May 13 20:02 /dev/tty55 crw--w---- 1 root tty 4, 56 May 13 20:02 /dev/tty56 crw--w---- 1 root tty 4, 57 May 13 20:02 /dev/tty57 crw--w---- 1 root tty 4, 58 May 13 20:02 /dev/tty58 crw--w---- 1 root tty 4, 59 May 13 20:02 /dev/tty59 crw--w---- 1 root tty 4, 6 May 13 20:02 /dev/tty6 crw--w---- 1 root tty 4, 60 May 13 20:02 /dev/tty60 crw--w---- 1 root tty 4, 61 May 13 20:02 /dev/tty61 crw--w---- 1 root tty 4, 62 May 13 20:02 /dev/tty62 crw--w---- 1 root tty 4, 63 May 13 20:02 /dev/tty63 crw--w---- 1 root tty 4, 7 May 13 20:02 /dev/tty7 crw--w---- 1 root tty 4, 8 May 13 20:02 /dev/tty8 crw--w---- 1 root tty 4, 9 May 13 20:02 /dev/tty9 crw-rw---- 1 root dialout 166, 0 May 13 20:13 /dev/ttyACM0 crw-rw---- 1 root dialout 204, 64 May 13 20:02 /dev/ttyAMA0 crw------- 1 root root 5, 3 May 13 20:02 /dev/ttyprintk pi@duet3:~ $ sudo bossac -e -w -v -b /home/pi/Desktop/Duet3Firmware_MB6HC.bin No device found on /dev/ttyACM0 pi@duet3:~ $ lsusb Bus 001 Device 004: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader Bus 001 Device 006: ID 0461:4d08 Primax Electronics, Ltd Bus 001 Device 005: ID 413c:2107 Dell Computer Corp. Bus 001 Device 007: ID 0424:7800 Standard Microsystems Corp. Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub pi@duet3:~ $
Is this thing just a junk paperweight? What am I missing? With the DuetPi OS, all I did was connect it to the internet, update it & reboot, add the username (pi) to the dialout group, and then I ran:
and
I'm at a bit of a loss. I need to start hooking up wiring/electric on this machine. If I can't get this board to be functional in the next 24-48 hours I'm going to have to buy a different board. This is ridiculous. What needs to be done to flash firmware on a MB6HC board that has been erased and is in diag mode?
@winstontj EDIT: I think that in Win10Pro SAM-BA 2.17 is connecting to the board. When the initial dialog box opens, if I choose the USB COM10 (not just COM10) I don't get an error message, but the pop-up dialog box just vanishes and goes away. Nothing pops up that would allow me to browse for an upload firmware file. However... If I unplug the MB6HC from the Win10Pro machine, I get a SAM-BA error pop-up as if the device disconnected unexpectedly.
@winstontj have you tried Bossa.exe from https://github.com/Duet3D/BOSSA/releases under Windows?
@dc42 said in Duet 3 MB6HC Questions:
All of the following is under Windows 10 Pro, build 19044.1706
BOSSA gives me a choice in the dropdown of COM1, COM3 and COM10. Windows Device Manager shows (under Ports, COM & LPT) "Bossa Program Port (COM10)". When select the BOSSA dropdown "COM10", it errors immediately with a small gui box with white X in red circle: "Error Could not connect to device on COM10".
How do I get BOSSA to connect to device \USBserial\COM10?
The SAM-BA v.2.17 dropdown shows COM1, COM3, COM10 and \USBserial\COM10. In SAM-BA, when I connect to COM10, it errors out immediately. However, when I connect to "\USBserial\COM10" (and select at91sam4e8-ek), I do not get an error (but the window box just goes away... no more GUI).
I don't know what to say. The computers see the board (bossa com port) it's just that none of the software will connect to it.
@chrishamm mentioned something about stock BOSSA being outdated and not recognizing the MB6HC board. Could this be a Windows (and/or Linux) driver issue? I installed the board drivers from here:
link text. Is there a newer, different or more appropriate Windows driver I should be using? (or maybe try??) The board is there... This is the difference between getting BOSSA to connect via \USBserial\COM10 vs. COM10EDIT: Is there a Windows command line (powershell??) version of BOSSA where I could use flags or tell it to talk to the MB6HC specifically at \USBserial\COM10?
@winstontj said in Duet 3 MB6HC Questions:
The command line version is called bossac (with a c at the end).
Did you try the Duet3D build of bossa linked there?
bossa
Following those exact instructions gives me this:
ubuntu@temp-duet:~/Desktop/Duet$ bossac -e -w -v -b Duet3Firmware_MB6HC.bin bash: /usr/bin/bossac: cannot execute binary file: Exec format error
I think that means it could be an application written for ARM (that I tried to run on Intel x86) however when I try to run it on various ARM boards --I tried both on a RbPi3B+ and NVIDIA Xavier AGX (8-core A53), no matter what I tried, I kept getting
nvidia@jetson:~$ sudo ./bossac -e -w -v -b Duet3Firmware_MB6HC.bin sudo: ./bossac: command not found
I tried every way I could to add, override, move, copy, etc. to $PATH and kept getting the same error. I put it in /usr/bin, /usr/local/bin, ~/bossac, etc. every time I got the same error above.
@Phaedrux
Below is Windows cmd output. I purposely changed the COM port from COM10 to COM2 because I read somewhere that sometimes applications look for COM ports numbered 1-4 and double-digit COM ports (like com10) don't always play nice with some things. Either way, COM2 is correct port and Windows Device Manager shows:BOSSA Program Port (COM2)
This is the result:
C:\Users\duet-temp\Desktop\Duet3_6HC>bossac -e -w -v -b Duet3Firmware_MB6HC.bin No device found on COM2
@Phaedrux I tried several ways with Windows cmd.exe. I tried to add the flag --port=COM2 and --port=\USBserial\COM2. Both did not work. Nothing works. What software do I need?
This is either a documentation issue, a Duet3D software issue or both. Several different machines can see the MB6HC board yet there is an issue, problem or fatal error every single time. Flashing this board should be an easy task yet going back as far as 2017 there have been similar issues:
https://forum.duet3d.com/topic/2715/bossac-command-structure/11What exactly do I need to get this board going? This has been an extremely frustrating process to the point that I regret buying a Duet3D product. Duet3D please help resolve this. I have many machines with various hardware (Intel x86, ARM, Apple) and various software (windows, various *nix flavors, etc.). What do the developers use? What configuration can I create to avoid as many variables as possible as well as mirror the existing documentation?
Duet3D please bring your documentation up to date. This is extremely frustrating!
There usually isn't this level of difficulty. I think it's a hardware issue with the board.
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
