IDEX motor jitter
@dc42 said in IDEX motor jitter:
@maxgyver do you have any toothed belts running over smooth idlers?
Nope. I am a little offended by that.
This is what I have done so far:
- checked for loose pulleys
- checked belt and belt path
- checked if linear rails run smooth
- checked motor cables and connectors
- checked CAN cable (All from Kenable)
- deactivated bed leveling
- deactivated demon.g
I have also rewritten most of my config file without success.
@maxgyver said in IDEX motor jitter:
I am fairly certain that this is a firmware issue, since the problem is also present when U is driven from the main board and the same jittering is present in X when the second extruder (U-axis) is printing and the first extruder (X-axis) is only moving in Y.
Right now, I am printing at 200mm/s with 5000mm/sยฒ accelerations on X, Y and U. Although the jittering is less severe at lower speeds, it is still noticeable.
EDIT:
It is really hard to tell by watching the print. But I got the strong impression that the jitter only courses when the Y-Axis moves! When Y is stationary, the jitter is goneI see you are using x32 micro-stepping for X, Y and U.
And the speeds you mentioned (200mm/s) are rather fast.
Perhaps the 6HC system cannot keep up?
Could you try x16 micro-stepping at 100mm/s?
I agree it may be the firmware. I am seeking to determine if there is a threshold condition that when crossed the problem appears.
Disclaimer: I am still on firmware 3.3.0 as I am letting others deal with the issues in 3.4.x.
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 05 2020 11:42:30 GMT+0200 (Mitteleuropรคische Sommerzeit) ; General preferences M550 P"Factory500" ; set printer name ; Blower M950 F0 C"!out4+out4.tach" C"Blower" Q25000 ; create fan 0 on pin out4 and set its frequency M106 P0 X0.40 B0 H1:2 T80 ; Chamer Fan M950 F4 C"!out5+out5.tach" A"Filter Fan" M106 P4 X0.30 B0 H0:1:2 T60 ; Power ON M81 C"pson" M80 ; switch power on G4 S4 ; wait for expansion boards to boot ; Drives M569 P0 S0 ; Drive 0.0/Z1 motor (rear left) M569 P1 S1 ; Drive 0.1/Z2 motor (rear right) M569 P2 S1 ; Drive 0.2/Z3 motor (front right) M569 P3 S0 ; Drive 0.3/Z4 motor (front left) M569 P4 S1 ; Drive 0.4/E1 motor M569 P5 S0 ; Drive 0.5/E2 motor ; Closed loop drives M569 P123.0 S0 ; X-Motor M569 P124.0 S0 ; U-Motor M569 P125.0 S0 ; Y1-Motor M569 P126.0 S1 ; Y2-Motor M569.1 P123.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 123 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P124.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 124 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P125.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 125 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P126.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 126 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. ; Motion System M584 X123.0 Y125.0:126.0 Z0:1:2:3 U124.0 E4:5 ; set 4 Z drivers and add one U driver -> Must come earlier than M350,M906,M92, M201, M203, M208, M350, M566, M574, M667 and M669 M350 X32 Y32 Z16 U32 E16:16 I1 ; Configure microstepping with interpolation M92 X160 Y160 Z640 U160 E400:400 ; Set steps per mm M203 X42000 Y42000 Z1800 U42000 E10000:10000; A40000 B40000 ; Set maximum speeds (mm/min) M566 X600 Y600 Z200 U600 E600:600 ; set maximum instantaneous speed changes (mm/min) M201 X30000 Y30000 Z500 U30000 E30000:30000 ;A6000 B6000 ; Set maximum accelerations (mm/s^2) M906 X2400 Y2400 Z1200 U2400 E900:900 I25 ;A300 B300 ; Set motor currents (mA) and motor idle factor in per cent M84 S5 ; Set idle timeout M917 X50 Y50 Z50 U50 ; Set holding current in percent ; Kinematics M669 K11 Y1:-1:0:-1 ; Matrix mapping for Axis - X:Y:Z:U ;M669 K11 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1 ; Matrix mapping for Axis - X:Y:Z:U ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1 M671 X-41:495.5:495.5:-41 Y353:353:23:23 S10 ; lead screw positions and maximum allowed correction S in mm G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ; Axis Limits M208 X0 Y0 Z0 U0 S1 ; set axis minima M208 X405 Y323 Z350 U405 S0 ; set axis maxima ; Endstops M574 X1 S1 P"123.io1.in" ; configure active-high endstop for low end on X via pin io1.in M574 Y2 S1 P"126.io1.in" ; configure active-high endstop for low end on Y via pin io1.in M574 U2 S1 P"124.io1.in" ; configure active-high endstop for high end on U via pin io1.in M574 Z2 S1 P"io3.in" ; configure active-high endstop for high end on Z via pin io0.in ; Z-Probe M558 P5 C"io5.in" H2 A10 S0.01 R0 F300:150 T60000 ; IR Z-Probe 1: set Z probe type and the dive height + speeds M376 H10 ; Set height (mm) over which to taper off the bed compensation (should be 20x max mesh error) G31 P500 X0 Y20 Z1.5 ; Set Z probe parameters, lower Z-value -> nozzle further down ; Bed Heater M308 S0 P"temp0" A"Bed" Y"thermistor" T100000 B3950 ; define bed temperature sensor M950 H0 C"out8" Q10 T0 ; create bed heater output on bed output and map it to sensor 0 M143 H0 S125 ; set temperature limit for heater 0 to 120C M307 H0 R0.383 K0.269:0.000 D2.81 E1.35 S1.00 B0 ; enable PWM mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 ; Hotend1 Heater M308 S1 P"temp1" A"Extruder1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M143 H1 S300 ; set temperature limit for heater 1 to 280C M307 H1 R2.872 K0.252:0.115 D1.45 E1.35 S1.00 B0 V23.8 ; Hotend2 Heater M308 S2 P"temp2" A"Extruder2" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M143 H2 S300 ; set temperature limit for heater 2 to 280C M307 H2 R2.872 K0.252:0.115 D1.45 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit ; Tools ; tool 0, X-axis M563 P0 D0 H1 X0 F1 ; tool 0 uses extruder1 and heater 1 with fan 1 as the print cooling fan M568 P0 R0 S0 ; set standby and active temperatures for tool 0 G10 P0 X0 Y0 Z0 S0 R0 ; set tool 0 offsets and temperatures M950 F1 C"out6" ; T0 Fan ; tool 1, U-axis M563 P1 D1 H2 X3 F2 ; tool 1 uses extruder2 and heater 2 with fan 2 as the print cooling fan and maps X to U M568 P1 R0 S0 ; set standby and active temperatures for tool 1 G10 P1 X0 U1.6 Y0 Z0 S0 R0 ; set tool 1 offsets and temperatures. (increase U to move nozzle to the left) M950 F2 C"out7" ; T1 Fan ; Create a tool that prints 2 copies of the object using both carriages''' ;M563 P2 D0:1 H1:2 X0:3 F1:2 S"Duplication Mode" ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U ;G10 P2 X0 Y0 U-205 S0 R0 ; set tool offsets and temperatures ;M567 P2 E1:1 ; set mix ratio 100% on both extruders ; Create a tool that prints 2 mirrored copies of the object using both carriages''' ;M563 P3 D0:1 H1:2 X0:3 F1:2 S"Mirror Mode" ;tool 3 uses both extruders, hot end heaters and fans, and maps X to both X and U ;G10 P3 X0 Y0 U-465 S0 R0 ; set tool offsets and temperatures ;M567 P3 E1:1 ; set mix ratio 100% on both extruders ; Temp sensors M308 S7 Y"mcu-temp" A"MCU" ; configure sensor 5 as thermistor for MCU M308 S3 P"124.temp0" Y"pt1000" R2180 A"Chamber Temp." ; Setup temp 0 on 1HCL at CAN address 50 as sensor 3 - sensing the chamber temperature M308 S4 P"temp3" A"Blower Temp." Y"thermistor" T100000 B3950 ; define bed temperature sensor ; LED lights M950 P3 C"out3" M42 P3 S1 ; Pressure Advance M572 D0:1 S0.02 ; Extruder Drive Number, Pressure advance amount ; Accelerometer ;M955 P0 C"io4.out+io4.in" I05 ; input shaping ;M593 P"none" F99 M501 ; set the active parameters to those stored in sys/config-override.g M291 P"The printer is not homed, home now?" R"Homing" S3 G28```
@maxgyver if the vibration occurs when both U and Y motors are driven from the main board, then I don't see how it can be a firmware issue, because in that configuration I can't see any way that the steps would get out of sync.
I had the same isue with duet wifi and duex5- double makfoged IDEx machine. In the end it was fualty driver on wifi board. New duet wifi solved the isue
@martin7404 said in IDEX motor jitter:
Since he was tried different drivers on the 6HC and on the three 1HCLs do you think a driver problem is likely?
The vibrations are still present when both U and Y motors are driven from the main board.
@fcwilt x16 microstepping makes no difference
What would be the theoretical maximum achievable speed for a system with dual mark forged belts?
I am interested in the math behind this.I am using GT2 belts with 20teeth pulleys.
I managed to get a slow motion shot of the U axis jitter. This was captured with U and Y driven from the main board.
You are referring to the left/right motion?
Yes, quite obvious.
And if you connect the X driver to the U axis hardware and the U driver to the X axis hardware the problem moves to the X axis hardware?
@fcwilt said in IDEX motor jitter:
I can test this tomorrow, but when I print with the secondary extruder on the U axis, the same left/right motion is present in X. So I suppose it is not a problem with the U axis hardware.
@maxgyver do X, Y and U axes have the same steps/mm?
Yes.
I did also test different microstepping settings with no improvement.; Drives M569 P0 S0 ; Drive 0.0/Z1 motor (rear left) M569 P1 S1 ; Drive 0.1/Z2 motor (rear right) M569 P2 S1 ; Drive 0.2/Z3 motor (front right) M569 P3 S0 ; Drive 0.3/Z4 motor (front left) M569 P4 S1 ; Drive 0.4/E1 motor M569 P5 S0 ; Drive 0.5/E2 motor ; Closed loop drives M569 P123.0 S0 ; X-Motor M569 P124.0 S0 ; U-Motor M569 P125.0 S0 ; Y1-Motor M569 P126.0 S1 ; Y2-Motor M569.1 P123.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 123 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P124.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 124 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P125.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 125 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. M569.1 P126.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 126 with a quadrature encoder on the motor shaft that has 20 steps per motor full step. ; Motion System M584 X123.0 Y125.0:126.0 Z0:1:2:3 U124.0 E4:5 ; set 4 Z drivers and add one U driver -> Must come earlier than M350,M906,M92, M201, M203, M208, M350, M566, M574, M667 and M669 M350 X32 Y32 Z16 U32 E16:16 I1 ; Configure microstepping with interpolation M92 X160 Y160 Z640 U160 E400:400 ; Set steps per mm M203 X42000 Y42000 Z1800 U42000 E10000:10000; A40000 B40000 ; Set maximum speeds (mm/min) M566 X600 Y600 Z200 U600 E600:600 ; set maximum instantaneous speed changes (mm/min) M201 X30000 Y30000 Z500 U30000 E30000:30000 ;A6000 B6000 ; Set maximum accelerations (mm/s^2) M906 X2400 Y2400 Z1200 U2400 E900:900 I25 ;A300 B300 ; Set motor currents (mA) and motor idle factor in per cent M84 S5 ; Set idle timeout M917 X50 Y50 Z50 U50 ; Set holding current in percent ; Kinematics M669 K11 Y1:-1:0:-1 ; Matrix mapping for Axis - X:Y:Z:U ;M669 K11 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1 ; Matrix mapping for Axis - X:Y:Z:U ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1 M671 X-41:495.5:495.5:-41 Y353:353:23:23 S10 ; lead screw positions and maximum allowed correction S in mm G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ; Axis Limits M208 X0 Y0 Z0 U0 S1 ; set axis minima M208 X405 Y323 Z350 U405 S0 ; set axis maxima
@maxgyver if the axes have identical steps/mm and microstepping, then the step pulses should be precisely synchronised. So I think it must be a mechanical problem.
Is there any vibration when you move each of the 3 motors individually? You can use G91 followed by G1 H2 commands to test that.
@dc42 In double makfoged he can move individually X and U but for Y he moves all the motors
Yes but you can still command the motors to move individually, and see whether the resulting movement is smooth or not.
@dc42 Individual motor moves are no problem, the jitter only courses when they have to work in conjunction.
If the axes have identical steps/mm and microstepping, then the step pulses should be precisely synchronised. So I think it must be a mechanical problem.
When printing with the U-Axis extruder, the jitter is present in the X-Axis extruder and vice versa. The active extruder is moving just fine and the print turns out okay. So I do not see how this can be a mechanical issue.
If it is not a firmware issue, then maybe a CAN related problem?
@maxgyver Can you show your belt arrangement scheme
You could possibly rule out CAN bus problems by running all drivers off the 6HC and disconnecting the expansion boards (and make the needed adjustments to the config file).
So, after almost a week of trying and testing, I found the reason for the strange extruder jitter.
It is due to how the belts are arranged. In short, the X and U belts start oscillating when the extruders are in their respective home positions.
At the home position, the axis belt has one short and one long section from the extruder mounting point to the axis motor pulley. Although I have 9mm gates belts and an overall very sturdy construction, this extra length adds enough springiness to the system that the extruders start to oscillate during moves with strong acceleration. The vibration becomes less prominent the further the extruder is from its home position, since the belt section between extruder and motor-pulley become evenly balanced when the extruder is in the middle of the bed. Hence, I was able to print with one extruder in the middle of the bed while the other extruder was oscillating in its home position.
@dc42 You were absolutely right to assume a mechanical issue.
Thank you all for your suggestions and support.
@maxgyver stil.I would like to see your belt arrangment, please
Thank you
