Is there a terminal like YAT for RPI?
@tecno said in Is there a terminal like YAT for RPI?:
Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)Are you using 3.4 on the mainboard?
You can update the bootloader to 2.4 via these instructions: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_bootloader
As for the config.g going missing, I think we should replace the board. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Since last mid april printer has been working OK. This morning I got heater fault.
OK so I decided to do the updates of bootloader as well as FW for toolboard.Now I can not get hotend heater to work.
m122 B121
Diagnostics for board 121:
Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
All averaging filters OK
Never used RAM 2680, free system stack 88 words
Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,349) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
Last reset 00:02:43 ago, cause: power up
Last software reset data not available
Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 16237, writes 9, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -2/9, peak Rx sync delay 209, resyncs 0/0, no step interrupt scheduled
VIN voltage: min 23.9, current 24.0, max 24.7
MCU temperature: min 32.9C, current 36.8C, max 36.9C
Last sensors broadcast 0x00000002 found 1 107 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 3260, send timeouts 0, received 1485, lost 0, free buffers 37, min 37, error reg 0
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
Accelerometer: LIS3DH, status: 00
I2C bus errors 0, naks 3, other errors 0Any idea what is wrong? Is it the FET again?
I can activate the bed heater but not hotend heater!
@tecno the tool is in the Off state. Have you selected a tool that uses that heater?
Same config and settings as before update.
M563 P1 D0 H1 F0 ; P1 = tool1 D0 = ext drive H1 = heater1 F1 = fan1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first tool -
2022-05-03 14:45:45 Error: Response timeout: CAN addr 121, req type 6049, RID=26
2022-05-03 14:45:40 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23 -
Email sent for warranty exchange
@tecno please verify that you are using firmware 3.4.0 or 3.4.1 on the main board and on all tool/expansion boards. The CAN protocols change between major firmware versions, so incompatible firmware may be the reason for problems such as the hot end heater not working.
Good Morningm122
RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: 0SBLN-A396U-D65J0-40KMQ-2R03Z-RQHV7m122 b121
Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)Cheers
Bengt -
@tecno Better upgrade the mainboard to 3.4.0 final or 3.4.1-rc1.
@chrishamm
Latest rc1 did the trick THANK YOU! -
